AMD ZEN - nova X86 Jedra
Predator X ::
grašek ::
Sklepam, da bo imel R5 1600X okoli 1200 CB scora. (70% več od 7600K stock CB scora oz. 700).
Predator X ::
AapocalypseE ::
Old news.
Predator X ::
AapocalypseE je izjavil:
Old news.
OLD? Glej clocke na 1600Xu. in CB je 69% hitrejši kot i5 7600K.
AapocalypseE ::
Postaš že postane zadeve...
AapocalypseE ::
hojnikb ::
#brezpodpisa
  • spremenil: hojnikb ()
ziga1990 ::
no fantje s čim boste hladili Ryzene jaz se odločam med noctuo NH-D15S in Crosair H115i ?
hojnikb ::
z svojo staro u12p
#brezpodpisa
GenZNPC ::
 zanimiv test za ryzena
Zame bi sicer bolj zanimivo bil realen test z recimo, kaka bi razlika pri uporabi RX 480 in GTX 1060.....
kolko slo-techovcev pa ma TitanXP ane :))
Lahk pa se naredijo test z 1080Ti, ko pride in AMDjevim ekvivalentom,
da bi videli katera graficna je boljsa za Ryzen 8-)
Pa vsaj en test z 4K in ca. 50-60fps nastavitvami.
skibidi
Koliko vidim.
Core-count matters.
GenZNPC ::
Seveda, sej test pool ima v izboru samo take spile a_n
skibidi
AMD Ryzen 1700X Beats Kaby Lake In Single Threaded Performance Despite A Lower Clock Speed In Userbench
The 1700X entry in question is clocked at 3.4GHz, with Turbo disabled. Which means it's actually running at 3.4GHz at all times. On the Kaby lake side we have a Core i5 7500 with a base clock speed of 3.4GHz but with Turbo enabled at 3.8GHz. Because in single-threaded workloads the i5 7500 operates at its maximum Turbo frequency of 3.8GHz this means we're looking at a 3.4GHz vs 3.8GHz single-core vs single-core comparison.
The Ryzen 7 1700X manages to match Kaby Lake exactly, scoring 111 points despite a ~12% clock speed deficit.
http://wccftech.com/amd-ryzen-1700x-ben...
  • spremenilo: Telbanc ()
Miha20 ::
GTA V
  • spremenil: Miha20 ()
Miha20 ::
Miha20 je izjavil:
GTA V
Intel na 4.5 ghz , Zen na 3,4 ghz...LOL.
Mal čudna primerjava.
Jup.
Na isti frekvenci bi spušil Intel.
Miha20 ::
Ja avg fps je kar precej dober glede na frekvenco.
Evolve ::
GTX 1060 with those settings and with 4xMSAA is limiting FPS for 7700K, so it would not make sense that RYZEN gives 15-20fps improvement when GPU already should be limiting factor with 7700K.
heck this CPUZ screenshot of the 1700X released by XFastest a few days back --
Compare that with what this bloke has uploaded in his video -- https://ibb.co/fTgGLa
Notice the L1 L2 L3 caches carefully.
ya. Actually i am an engineer at AMD and was not allowed to upload anything like this :p But i did xD
ne vem no :D mislem da tem posnetkom nebi lihk verjel
Pro_moted ::
Me zanima prodaja Ryzena, glede na to da prvo, kar izjavi 80% kupcev, ki pridejo po PC v trgovino je " ali ima Intel procesor " ? " ali je i7, ker to rabim in hočem imet ". Dvomim da se bo sedaj kljub čisto konkurenčnim izdelkom pri AMD kaj spremenilo. Večina itak ne ve kaj kupuje, palijo samo na ime, isto kot pri telefonih, avtih itd. . Upam v dobro vseh nas da se bo to spremenilo.
Drugače pa bo Ryzen 1800 vrhunska render mašina za tako ceno. Komaj čakam da ga stisnem v PC !
AMD FX8120;GB 990FXA-UD3
Predator X ::
D3m je izjavil:
Jup.
škoda, ker je res testiral GTA V. Nč ni omenil DDR4 clock ...
neo5468 ::
Intel je spustu 7700k že na 80€. :))
http://www.mindfactory.de/product_info....
Predator X ::
dxx ::
Predator X je izjavil:
http://www.bolha.com/racunalnistvo/proc...
Ampak...
Glede na njegove ostale oglase je CPU delidan,tako brez garancije. Torej ni niti 240 več vreden.
AapocalypseE ::
Odvisno kakšen kupec se najde. Nekomu ni všeč, da je delidan, drugemu pa bo.
Drugače pa upam, da se bo ryzen navijal tam na 4.5GHz na zraku. Pomemben podatek za igre kot vidimo zgoraj.
Hydros ::
Tapravi se oglaša. Par postov za tem, ko sem jaz že dal info o Ryzenih nižjega ranga si se ti zbudil in postal enako.
One thing that we shouldn't fail to mention is that all of the results we're seeing, including the record breaking performance of an overclocked Ryzen 1800X is only the tip of the iceberg. These chips are fresh off the production line and how high they can clock will only get better as the 14nm LPP process AMD is using matures. It's impressive enough that the company can already get its first ever 14nm CPU iteration to hit 4.0GHz straight out of the gate. It took Intel several years before its 14nm process was mature enough to produce quad-core CPUs that can hit 4.0GHz, let alone 8-cores chips.
http://wccftech.com/amd-ryzen-7-1700-ov...
D3m0r4l1z3d ::
Očitno je AMD zadel sveti gral: Ryzen's Clock Speeds Will Only Get Better With Time
Jp, za božič bodo dali ven 1900X s 4Ghz base frekvenco za 599$.
D3m0r4l1z3d je izjavil:
Ja, tko nekako.
Jaz zadevo vidim tkole.
Zen je hitrejši clock to clock, od Intela, prvi čipi so dost na nivoju, odločitev o preskoku 10nm in da se gre na 7nm...je na mestu, ker bo Intelu prinesla minimalno pohitritev, ki jo bojo z peglanjem čipa na 14nm po moje zlahka presegli.
Zadeva res obeta, kot smo že trdili. In tud čipov je ko salate....aleluja...aleluja...
D3m0r4l1z3d ::
Jah, spet se bo obrnilo enkrat, tako to gre.
AapocalypseE ::
FireSnake je izjavil:
Kje to? :'(
hojnikb ::
pebi, kako visoko se clocka zadeva je v prvi vrsti odvisno od arhitekture, ne od faba. tko da prosim ne primerjat clock ceiling broadwella pa ryzena.
#brezpodpisa
GenZNPC ::
AMD je izbral pravo pot in ima konkurencne izdelke na poti.
Ce jim bo slo tako naprej in izdajo cez par lez se izboljsane proce, torej clock bumb in quad channel, bom presedlal na AMD, razen ce jih intel prehiti vmes.
Zaenkrat vse kaze, da bo najboljsi p/p za Render masine. Po drugi strani pa je vedno bolj popularno GPU pospesevanje.
Osebno bo 1600X sel za med in bo za priporocit, dokler intel ne ponudi vec.
skibidi
Ampak v bistvu se končno pokaže kaj je bla AMDjeva glavna slabost vsa desetletja (čeprav zadnjih par let je bilo še kaj drugega).
Global Foundries(prej del AMDja) je bil vedno korak za Intelom. Sedaj pa je licenciral 14nm LPP tehnologijo od Samsunga in evo ti Ryzen in bodočo Vego.
  • spremenil: Lonsarg ()
hojnikb ::
zelo verjetno znajo bit kaki ryzeni direkt iz sammy fabrik >:D
#brezpodpisa
Predator X ::
GenZNPC je izjavil:
A SW encoding že izkorišča Quad?
Rabiš to za server ali določeno občutljivo aplikacijo?
  • spremenil: D3m ()
dottor ::
http://www.mlacom.si/amd-ryzen-7-1700x-...
Nevem če je že kdo linkal; Mlacom ima predanročila za 1700 po 403EUR, 1700X po 489EUR ter 1800X po 612EUR.
Xeon X5650@3.8GHz |Asus P6T|
2x4GB+4x2GB|ASUS R9 280X@1100MHz|
WD Green 240GB SSD + 4x1TB Hitachi
  • spremenil: dottor ()
Všečno, da opozorijo potencialnega kupca.
Ryzen je nova serija AMD procesorjev, ki temeljijo na arhitekturi ZEN.
Modeli s končnico X nimajo priloženega hladilnika, saj imajo odklenjen množilnik in jih bodo zato večinoma uporabljali entuziasti v kombinaciji z zmogljivimi AIO vodnimi in zračnimi hladilniki.
Prvič AMD uvaja tudi tehnologijo avtomatskega navijanja (OC), poimenovano Extended Frequency Range (XFR), katera omogoča, da se odvisno od zmogljivosti ostalih komponent frekvenca lahko avtomatsko zvišuje celo preko Boost frekvence!
Za poln izkoristek procesorja svetujemo matično ploščo s čipovjiMD X370 ali B350 in čim zmogljivejši procesorski hladilnik.
dottor ::
Raje dopišejo 2 vrstice kot da jim pol folk pošilja neumne mejle, ker ni bil sposoben googlat pred nakupom :P
Sem imel nekomu za sestavit PC pa je na vsak način hotu imet i5 K procesor in najcenejšo možno ploščo, pa sem mu proval razložit da je to neumno ampak pač stranka ima vedno prav. No čez par mescev se ta spet javi zakaj on ne more navit svojega K procesorja (šlo se je za H61 ploščo)
AapocalypseE ::
neo5468 ::
Računej not še plato pa rame in te na koncu pride dražje kot mindfactory.
tt2 ::
A uradne teste lahko pričakujemo 2. marca?
ziga1990 ::
Fantje koliko je pa ta novim leakom benchmarkov za vrjeti, ker da ima Ryzen 1700 skoraj enake FPS-je kot jih ima i5 7700k je malo težko vrjeti?
tt2 je izjavil:
Da.
D3m0r4l1z3d ::
ziga1990 je izjavil:
Zakaj, ke4 ima več jeder ali ker ima nižjo frekvenco?
AapocalypseE ::
Ryzen se mora nujno overclockat za igre ;)
105 / 626
