AMD ZEN - nova X86 Jedra
najbolje vse krivit provizvodni proces...
D3m0r4l1z3d ::
Misliš hitrost.
Miha20 ::
  • spremenil: Miha20 ()
U zanimivo 2005 so bili praktično na 50%.
klinker ::
Sej bodo spet tu nekje. Ryzen je super, tako kot takrat Athlon64.
scipascapa ::
Ryzen je res super, moj naslednji sistem bo 100% Ryzen.
Miha20 je izjavil:
http://wccftech.com/amd-takes-10-4-cpu-...
Tržni delež
Ne, to ni tržni delež. Je lahko samo indikacija.
Kar je pommebno povdariti, ko prikazujemo tale graf je:
– This graph counts the baselines submitted to us during these time period and therefore is representative of CPUs in use rather than CPUs purchased.
– The Quarters are by the calendar year rather than financial. (i.e. Q1 starts January 1st)
– Baselines can be submitted from anywhere therefore these are global statistics.
– We do receive a small number of submissions of CPU types other than AMD and Intel however the percentage is so small as to make it not worth graphing. This combined with rounding off the percentages to 2 decimal places will account for each quarter not always adding up to exactly 100%.
– This chart only includes x86 processors and does not include other chip architectures these manufacturers may sell.
– This chart only includes CPUs installed into PCs and does not include game consoles.
– As the PerformanceTest software only runs on Windows OS and counts on user submitting their benchmarks. This chart may be non reflective of non Windows user base.
D3m0r4l1z3d ::
Karkoli bi že AMD izdal novega, bo odžrlo nekaj marketshare od Intela, ker sta edina konkurenta. Glede na nastavljeno ceno bo ta delež dokaj velik, dobiček pa verjetno ne kot bi si želeli pri AMD.
Dobiček bo, če imajo dober wafer yield.
http://www.guru3d.com/news-story/amd-ry...
klinker ::
Buldi ni nic odzru, prej povecal prednost Intela, Ryzen je druga zgodba.
Se z grafami naj kaj nacarajo, pa bodo spet na zeleni veji, ampak sem zelo skepticen glede Vege.
D3m0r4l1z3d ::
D3m je izjavil:
Z nulo nisem niti mislil, da bodo delali, seveda bo dobiček, samo kolikšen?
klinker je izjavil:
Vsak prodan Buldi je bil en Intel manj prodan, tako da logika je osnovna, če imaš le dva x86 konkurenta.
Predator X ::
D3m0r4l1z3d je izjavil:
D3m je izjavil:
klinker je izjavil:
Okey,
Intel ima svojo tehnologijo, ki je daleč večji strošek kot si ti misliš.
Facts:
1. Ryzen ima die size 192mm^2 vs RX 480 232mm^2
2. Ryzen ima CCX design (4+4,3+3,2+2) - in EPYC,threadripper mu omogočata tudi (1+1)
3. R7 1700 se prodaja za 300EUR+, R7 1700X za 350EUR+, R7 1800X za 450EUR+
4. Ryzen je uspešen in je že v prodaji (najhujše je mimo).
D3m0r4l1z3d ::
Prodigy, relax, AMDju ni hudega
A new report pegs AMD market share for x86 computer processors at 31% in Q2, 2017.
Zavoljo vseh upajmo, da tele številke držijo (podatki so za Q2 2017).
D3m0r4l1z3d ::
A, sigurno, Ryzen je soliden proc, cene so super glede na performance, Intel bo zgubil kar lep delež.
roller2 ::
A, sigurno, Ryzen je soliden proc, ....
Si predstavljaš kakšna budala mora bit tisti, ki je ob izidu vztrajno ponavljal "Ryzen je fail" ... aja čak mal, to si bil ti :))
ombre ::
Hah, a pol je moj nakup ryzna že v tej razpredelnici. :)
OmbreMan - Galaxy of knowledge
D3m0r4l1z3d ::
roller2 je izjavil:
Niti ne.
OvCa77 ::
Ali so kakšne bistvene razlike med B350 in X370? Katero matično z 4xRAM in ATX velikostjo priporočate?
Trenutno imam nagledano MSI X370 Gaming Plus in MSI B350 PC Mate.
Laptop: Probook 440 G3 | i5-6200U | 12GB DDR3L | SSD Plus 240GB
Desktop: Ryzen 1600X | Gigabyte AX370 K3 | 8GB DDR4 | MX100 256GB
  • spremenilo: OvCa77 ()
X370 za OC, kar je pa tudi B350.
Ostalo so samo malenkosti in število USB, PCI, M.2 priklopov.
D3m0r4l1z3d ::
X370 je dražja
Predator X ::
A kdo uporablja samsung E die 2x4GB?
mojster_joni ::
D3m je izjavil:
Yield bi mogu bit super, če dobr pogledaš je cela arhitektura zasnovana na način, ki praktično zagotavlja minimalne probleme kar se tiče yieldov. Relativno majhni ccxi, ki so pol povezani v čipe z želenim številom jeder. Se pravi tudi če je cel ccx za v smeti ni hude izgube (pa ponavadi ni ampak je kvečjemu fuč samo kako jedro/del l3 cacha se pravi se ga še vedno da uporabit). Sicer imaš zaradi tega rahle težave pri hitri komunikaciji med ccxi, ampak pridobiš pa hkrati ogromno ker praktično nimaš izgub + lahko delaš ogromne čipe če je treba. V bistvu je AMD tuki naredil genialno potezo, tko da kapo dol...
Predator X ::
Tole je pa extrem za intela.
https://www.techpowerup.com/235092/inte...
trerorist ::
Predator X je izjavil:
Koliko pa vi zipate da se vam splača vzet Ryzena?
Zeeelo veliko.
Predator X ::
trerorist je izjavil:
Jst mam ryzena. In se splača
Kerga si vzel?
Predator X ::
D3m je izjavil:
Kerga si vzel?
Hotu sm R5 1600.. pol pa sm skeširal za R7 1700.
D3m0r4l1z3d ::
D3m je izjavil:
Kerga si vzel?
Si prepričan, da ni tvoj brat vzel 1700, ti pa si še vedno na fx 6300?
Predator X ::
D3m je izjavil:
Kerga si vzel?
Ma, ne drgač sm na P4.
D3m0r4l1z3d ::
Prej na Phenom II 1060t ker ti je bil super cool s 6 jedri.
Predator X ::
Sledi test 720P ultra .
Windowsa nisem ponovno naložil, imam trenutno samo 8GB DDR4 in imam 3200MHz 16 18 18 38.
Predator X ::
bf1 720p@ULTRA (3,6GHz/3200MHz DDR4)
Frames: 17440 - Time: 127453ms - Avg: 136.835 - Min: 111 - Max: 169
GPU bottleneck:O
D3m0r4l1z3d ::
Zamenjaj fx 6300 in prastaro platformo pa postaj prave rezultate.
LuiIII ::
Vse kar trenutno lahko Intel počne je damage kontrol, upanje, da se bo AMD-ju zataknilo pri EPYC splavitvi in na visoko inercijo, ki jo na trgu predstavlja ime Intel. AMD bo Intel-u odvzel na server segmentu gotovo kar nekaj procentov kar je za AMD velik uspeh, no pa za nas kupce tudi.
Predator X ::
Potem je tale FX dal 2x več avg fpsjev kot i7 3770.
kiro plato maš ?
Kok gre OC ?
Predator X ::
iloveboobz je izjavil:
kiro plato maš ?
Kok gre OC ?
C6H
Sam, da ne bo že spet kakšen predator X ("double space" že spet kaj trollal)
Predator X ::
16C 3K CBR15 1000$
#rip intel
Predator X ::
C6H
Ma bug na maunal V, karkoli nastavim na manual vCore (V) se proc postavi na 1550MHz
Offset+- deluje
dal sem na +-0,05V offset, LLC lvl1 dram na 3200MHz 1,35V, 36x100 Deluje.
Voltaža je maxed pri 1,225vCore. Stock cooler. WTF? Proc leti napram i7 3770 3,7GHz DDR4 2x8GB 1600MHZCL10.
Latenca rama je 77ns (za oba sistema).
Zdej 3466MHz mi tudi uspe, ampak je nestabilen pri 1,35V in s trenutnimi nastavitvami.
Nisem imel časa nalagat nov windows in se ukvarjat s stabilnostjo rama... bios je latest.
SimplyMiha ::
Walletripper.
klinker ::
C6H
Offset+- deluje
A bos se kako drugace pokazal kaj, razen pisanja >:D
Predator X ::
klinker je izjavil:
C6H
Offset+- deluje
Za slotech, sure. Za take kekce kot si ti je potrata časa.
Do it man!
Do it for the S-T community!
Predator X ::
2 različna(#mirror) die-a.
ryzen laptop benhcmarked
https://bit-tech.net/previews/tech/lapt...
markic222 ::
Men po novem updatu biosa na msi x370 carbon vse dela kot treba. Rami so na 3200 z latencami 14 (x-amp) . Ryzen 1700 pa overclockan na 3700 mHz. Koncno dela kot je treba, so kar rabili da so bios zrihtali.
Kako drugače? Zadovoljen?
