Forum » Igre » S.T.A.L.K.E.R. 2: Heart of Chornobyl
Izi ::
Ima še kdo probleme v Rostoku okoli tistih treh prodajalcev? Tam mi vedno po nekaj minutah zmrzne igra. Drugje dela brez problemov.
Winter envelops the world, and even the Zone cannot resist its embrace -- though She always does it in her own anomalous way. Sudden blizzards sweep across the land like Emissions, transforming once-familiar grasslands into an endless snowy wasteland. The piercing cold grips your bones if caught outside during these fleeting moments of frozen wonder. And yet, as quickly as it comes, it vanishes, leaving no trace but an everlasting memory.
Is it a new psy-induced phenomenon, a sinister forewarning, or perhaps a true Christmas miracle? Stalkers, as always, adapt and get used to it. They stash supplies under spruces, sharing their coordinates with trusted buds while resting by the camps. Preparing for the year's adventures, they find warmth in shared tales and thousands of new colleagues that finally made their way into the Zone.
In these frozen winds, a familiar tune echoes -- a melody so native to these lands, resonating far beyond its borders and into the hearts of the Mainland.
S.T.A.L.K.E.R.2: Heart of Chornobyl -- Christmas Eve at the Zone
GSC Game World has praised Game Pass in our recent interview.
The team revealed that this subscription played a key role in bringing the series to a new audience on consoles.
https://tech4gamers.com/stalker-2-game-...
garrv ::
Hm, tudi jaz imam fps drop v Rostoku pri punci ki prodaja armor (Birch), drugje dela ko šus. Sem pa naredil BIOS update, na novo dodal mode, reshade, morda je pomagal tudi zadnji patch.
https://www.nexusmods.com/stalker2heart...
Pa mislim, da se je kri z zadnjimi parchi kar popravila. Zgleda veliko lepše.
yayo ::
Sem na tisti točki, ko po vrnitvi iz Clear Sky baze dobiš nalogo iti v SIRCAA. Pred tem sem se odločil vrniti v Garbage, ker se mi je na mapi prikazal kup novih stashev ampak je razočaranje. Ko prodaš vsebino stasheh in lootano opremo dobiš ravno toliko, da popraviš svojo in ti ostane tistih par jurjev kreditov za najem vodiča, da te popelje nazaj v Zaton.
Izi ::
Jaz imam pa že čez milijon kuponov. Po SIRCAA misiji se mi zdi da so sovražniki dobili boljša orožja in loot mi sedaj nosi toliko da se utapljam v kuponih
yayo ::
To si ti fasal dobičkonosni glitch zaradi dvojnega namizja.
Pa wish granter te bo v zlato spremenil kot včasih Laro Krof (takrat se je še klical kralj Midas)
- spremenil: yayo ()
Meizu ::
Splača se prodat vse stage 1 artefakte, ker niso nikoli del side misij za artefakte, hkrati pa tudi nimajo dovolj konkretnega efekta. To je vedno direkt cash. Stage 2 artefakti so načeloma iskani preko tistih side misij, legendary artefakti so pa itak top of the line, tega ne prodajat razen če res ne rabiš.
Denar trenutno v igri ni problem, ko dejansko rabiš veliko denarja za popravila te misije načeloma vedno dobro nagradijo, hkrati pa je fino imet en carry setup artefaktov da loot lažje preneseš domov. Vedno prodajat pri friendly traderjih, jaz dobim na eno rundo prodaje loota okrog 15-20k kuponov poleg nagrade misij. To je več kot dovolj za bilokakšna popravila ali nadgradnje opreme - igram pa na najvišji težavnosti, nižje težavnosti prinesejo še več denarja na misijo.
yayo ::
76 ur igranja, ravno vstopil v SIRCAA. Fora z optičnim merkom, Saiga in neuničljiva Skifova pokalica. Armor, tisti Wanderer Suit z anti PSI zščito katerega najdeš v eni podrtiji v Clear Sky bazi. Btw, do baze sem prišel v Ecologist suitu katerega sem našel dosti prej in ga šparal.
BTW, kdaj se gre v Concrete factory? Je levo od Garbagea in mi tam kaže en Shahov stash. Zgleda mi kot, da bi moral biti del samega Garbagea. Te pelje glavna misija tja?
Misliš cement factory ? Tja greš lahko kadar hočeš tam ni nobene glavne misije pa tudi še naprej v coling towers greš lahko.
yayo ::
Hvala, se mi je zdelo, da bo nekaj takega. Verjetno so rezali kake naloge pred izidom igre.
https://imgbox.com/kU2za9iA
Ti je uspelo dobiti artefakt iz slike ?
yayo ::
Ja, sem bral prejšnje poste v tej temi pa si ravno ti nekaj o weird water pisal, se mi zdi. Potem sem ga šel iskati, ker podrobno raziskovanje map nima nobenega smisla, če ne moreš izplena odnesti s seboj.
Posebno ker okvarjene puške in plesnive klobase ne prinesejo veliko denarja.
Samo ta artefakt weird water se ne splača prodati. Pa ne samo zaradi teže ampak tudi zaradi radiacije. Npr če imaš na obleki 5 praznih slotov za artefakte in, da 4 artefakti npr imajo vsi radiacijo v negativno smer ti bo weird water zdravil vso radiacijo sproti.
yayo ::
v bistvu je to official cheat koda. Imam občutek, da malce varam igro ampak jebemti, ne moreš vsakič za dva-tri stashe izvajati nočni trekking po polovici mape. Se mi je že parkrat zgodilo, da sem bil obtežen do maximuma in sem z ugašeno svetilko počasi vandral v noči prisluškujoč, če se bo oglasil kak bloodsucker. Potem pa petnajst energy drinkov enega za drugim.
Enaplusdva ::
Katere vrste nabojev največ uporabljate ?
Za ljudi armor piercing za mutante regular ?
Kaj pa expansive in flat ?
Gregor459 ::
Enaplusdva je izjavil:
Flat je za dolge razdalije kjer ima krogla manj padca.
Expansive pa dela hudo škodo mesenim predelom nima pa penetracijske moči recimo proti body armorju.
- spremenilo: Gregor459 ()
Predsednik11 ::
Kako se pa pride v Pripayat ? Samo preko glavne zgodbe ?
Sem prehodil celotno želežnisko progo pa ni nokjer vstopa.
Jaz imam trenutno za pasom
Weird ball
Shoop Class (Endurance weak v plus, bleeding resistance weak v plus in minus efekt radiation medium)
Compas ( Psyical protection Maximum v plus in Radiation mayimum v minus)
Magic Cube (Psyhical protection strong v plus in Radiation maximum v minus)
Weird water
Če umaknem weird water iz inventorija mi začne radiacija zelo hitro rasti tako,da weird water je po moje najboljši artefakt za radiacijo.
- spremenil: oo7 ()
Upam, da enkrat nekdo naredi zimski mod za Stalker 2 :)
Nekaj v tem stilu
Nekaj v tem stilu
- spremenil: oo7 ()
yayo ::
1. Sem bil prepričan, da me hecajo hroščati shaderji pa potem opazim, da ima Weird Water svoj efekt na percepcijo. Škoda, da jo niso imenovali kar Weird Vodka.
2. Kako kul, da je v Duty bazi v Garbageu postelja in vse ostalo kar utrujeni Stalker potrebuje za preživetje (no kopalnice niso ne vem kaj).
In pravite, da, če jo ne obiščeš spontano v to bazo ne vodi nobena naloga?
yayo ::
Bil tudi v Cooling Towers in našel okvarjen Dnipro. Žal jih nisem še podrobno preiskal. Ognjene anomalije so najbolj antipatične v celi igri, ker ni variante, da bi poceni prišel skozi, če iščeš artifakte.
Gregor459 ::
Ko imaš enkrat Veles detector greš mimo anomalij brez težav.
Tam v cooling towerju je arch anomalija in artefakt.
Enaplusdva ::
Coling towers na desni strani kjer je pokopališče in še bolj desno je ograja in manjši stolp. Tam je en sniper katerega se ne, da ubiti.
yayo ::
Na Redditu pišejo, da ni prav nepremagljiv ampak, da ne dobiš ničesar posebnega, če ga uspeš ubiti. Verjetno je tam, da onemogoči izhod iz predvidene cone igranja.
Enaplusdva ::
Sem ga ene 10x s M701 zadel v glavo pa ni padel s tem, da sem tam porabil še ene 10 medpackov potem sem pa raje odnehal.
Meizu ::
Evo končal Stalker 2 na veteran. 107 ur igranja, 117 smrti ahehe.
Sem ohranil simpl logiko - hotel sem hišo, dobil sem hišo - kdor ve za kaj gre, ve, za ostale bi bil itak spoiler. :)
Gregor459 ::
yayo ::
Enako, anomalije, padci. Velikokrat sem lik kar pustil umreti, da sem prišel do loading screena in šel od začetka, ker sem želel čimmanj obrabiti opremo.
Je prav ena višina v tej igri. Če npr skočiš iz 2 metrov je vredu, če iz 2,5 se začasno na hitro poškoduješ če pa greš na 2,6 metra si pa takoj mrtev :)
Sem imel v DUGI problem, ko sem šel na opazovalnico dol pa nikakor niso prijele lestve tako, da edino če sem skočil kar je bila takojšnja smrt tako,da sem moral dati en starejši load.
Končno dobil svojo prvo Gauss puško. Dela ogromno škode edino v Yaniv tisti prodajalec ne prodaja baterij za Gauss.
GSC Game World confirms they will continue to support S.T.A.L.K.E.R. 2 for the next years, and even re-add cut content.
Me zanima kaj so zrezali ven :)
yayo ::
Cooling Towers, tista zgradba na Zahodu, Red Fortress ali nekaj takega, ki ima na eni strehi zrušen helikopter. Je tam kaj zanimivega, oziroma vodi tja kak quest?
Gregor459 ::
yayo ::
Je pa območje okoli Duty baze prav lepo za raziskovanje. Pravo Stalker vzdušje je tam, ker imaš že dovolj dobro opremo, da te zalega ne ubije v trenutku in lokacije so polne teh miniugank z iskanjem stashev. Pa jutra v Zoni, po dolgih nočeh, ko si fajtal, se skrival in bežal, so prekrasna.
https://ibb.co/JdTcHzd
yayo ::
Tale achievement sem danes dobil pa ne vem niti kje. Sem bil namreč pijan.
Baje ga je dobilo le 0,6% Stalkerjev.
Keeping your hands steady
Shoot an enemy in the head, through an obstacle, having the intoxication effect.
Perform a headshot through an obstacle while under the influence of alcohol. You can equip Weird Water arch-artifact and have at least 50kg of items to ensure constant intoxication effect.
Jaz sem pijan samo še od weird water.
Vodko sem pil samo na začetku igre, ko je bilo treba zbit radiacijo.
Piva pa ne pobiram.
Piva pa ne pobiram.
Zadnje čase, ko je ura 20h grem nazaj proti bazi spat. Prvič zona je prelepa, da bi po njej hodil ponoči in drugič s tisto svetilko ponoči se je zunaj malo smotano boriti. ;)
Izi ::
GOG ima malo igralcev Stalkerja 2, pa še tisti niso tako zagnani
Na Steam ima ta dosežek 7% igralcev. Jaz sem ga dobil isti dan ko sem našel Weird Water.
Moj najredkejši je "BOOM!", celo na Steamu ga ima samo 0,5%
20 enemies killed by blowing up the surroundings. Save on hand grenades and enjoy the fireworks.
(Naše bombe ne štejejo, moraš streljati v eksplozivne kontejnerje in z eksplozijo ubiti sovražnike.)
| » | S.T.R.A.N.G.E.R. Bermuda SOSOddelek: Igre | 539 (345) | Seljak |
| » | Metro Exodus [Metro 2035] (strani: 1 2 3 4 … 12 13 14 15 )Oddelek: Igre | 172779 (56857) | oo7 |
| » | S.T.A.L.K.E.R. (strani: 1 2 3 4 … 8 9 10 11 )Oddelek: Igre | 110455 (28335) | Meizu |
| » | ArealOddelek: Igre | 6079 (5808) | Heavy |
| » | Igre podobne Fallout 3 (New vegas)Oddelek: Igre | 9447 (9163) | yayo |
