Forum » Pomoč in nasveti » Deep freeze-a ne morem odmrzniti
pintpj ::
Živjo! Na stacionarnem računalniku z Windows XP imam nenavaden problem. Gor je nameščen Deep freeze (licenčni, seveda), ki je v Boot Frozen načinu. Težava se pojavi, da v taskbaru nimam ikone, niti kombinacija CTRL+ALT+SHIFT+F6 ne prime. Vidim, da je nameščen na c-disku, a v registrih programa ne najdem (običajno bi ga našel pod Current Users > Local Machine > Faronics. Ali obstaja način, da odmrznem računalnik in pri tem ne nameščam na novo Windows sistema?
crniangeo ::
ne štekam zakaj bi ga našu pod current users, dej preveri raj pod hklm :)
Convictions are more dangerous foes of truth than lies.
GTX970 ::
http://support.faronics.com/Knowledgeba...
B,c opcija če imaš Enterprise.
http://en.kioskea.net/forum/affich-4021...
bluserver Oct 31, 2009 02:04AM
1. Restart your PC.
2. Press DEL or F2 shortcut to CMOS setup in short goto CMOS setup.
3. Change the date 10 years backward or forward. Then save it and restart PC.
4. Before the windows logo shows up Press F8. There you can select safe mode, safe mode with network, etc.
5. Choose Debug mode or Debugging Mode.
6. In Debug mode select the OS you use for example windows xp pro.
7. (This is need a little quicker of hands) When the windows XP starts wait the welcome screen appears and make your fingers get ready to press CTRL+ALT+DEL shortcut key for taskmanager.
8. After the windows XP welcome screen the Windows desktop will appear. Quickly hit CTRL+ALT+DEL.
9. Press D 'D is the shortcut key to locate the process DFServ' or you can locate it using your mouse. After locating it press Del 'to kill the process DFServ.'
10. If you succeed restart your PC and boot it in normal mode. There you can see the deepfreeze icon will be mark X means it is disabled. Now you can uninstall it using deepfreeze installer.
After making those steps don't forget to change back your time in CMOS.
MIHAc27 ::
Če je pod verzijo 6.0 je obstajal defrezer programček... Nad verzijo 6.0 so pa verzije še dodatno zaščitene in ne pomaga niti to.
Druga opcija. da se tega programa znebiš je reinstal windowsow.
Spajky ::
Mislim, da je treba komp zagnat z DEEPFreeze programom, kot za njegov instal v "Dos-u", pa tam izklopit zaščito; se mi zdi da je potreben vnos master gesla v program predtem ...
MIHAc27 ::
Tko je imel Radix... ki je dejansko hardvesko zaklenil zadevo (ena kartica na PCI).
Deep freeze je pa čisto softwareski program. Da ga odstraniš mora biti odklenjen.
| » | Win7 Domena Remote: Ni Windows Security dialogaOddelek: Operacijski sistemi | 2231 (2085) | MrStein |
| » | Oživljanje starih računalnikovOddelek: Novice / Ostala programska oprema | 7071 (4991) | krneki0001 |
| » | Ikone v win XP izginile po uporabi programa Spybot Search & Destroy. Kako dobiti ikonOddelek: Pomoč in nasveti | 2704 (2660) | riba43 |
| » | Logitech MouseWare bug (?)Oddelek: Pomoč in nasveti | 2613 (2209) | Swiwer |
| » | NTFSOddelek: Operacijski sistemi | 1780 (1631) | andrej |
