Visual Basic
Visual Basic
Plezalec ::
Oj, imam program v VB. Notri sta dva textboxa in gumb. Naredil sem compiler. (V Prvi Textbox napišeš kodo, v drugem pa ti izpiše komentarje)
VB mi pa javlja napako ki je ne najdem. Prosim POMOČ:
Imports System.IO
Imports System.Reflection
Imports System.CodeDom
Imports System.CodeDom.Compiler
Imports Microsoft.VisualBasic
Public Class Form1
    Private Sub Button1_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button1.Click
        ' read code from textbox
        Dim Code As String = TextBox1.Text
        ' clear output textbox
        TextBox2.Clear()
        ' create fully functional assembly string
        Code = ("Imports System" & vbCrLf &
                "Imports System.Windows.Forms" & vbCrLf &
                "Imports Microsoft.Visualbasic" & vbCrLf &
                "Public Class TempClass" & vbCrLf &
                "Public Sub MyCode(ByVal Textbox2 As TextBox)" & vbCrLf &
                Code & vbCrLf &
                "End Sub" & vbCrLf &
                "End Class")
        ' create the compiler
        Dim vbProv = New VBCodeProvider()
        ' create parameters to pass to the compiler
        Dim vbParams = New CompilerParameters()
        ' add referenced assemblies.
        vbParams.ReferencedAssemblies.Add("System.dll")
        vbParams.ReferencedAssemblies.Add("System.Windows.Forms.dll")
        vbParams.ReferencedAssemblies.Add("Microsoft.VisualBasic.dll")
        ' generate an assembly in memory
        vbParams.GenerateExecutable = False
        vbParams.GenerateInMemory = True
        ' give it a name
        vbParams.OutputAssembly = "MyCode"
        ' compile the code and get the compiler results
        Dim compResults = vbProv.CompileAssemblyFromSource(vbParams, Code)
        ' check for compile errors
        If compResults.Errors.HasErrors Then
            Dim ErrorMsg As String = compResults.Errors.Count.ToString & " Errors:"
            For x As Integer = 0 To compResults.Errors.Count - 1
                ErrorMsg = ErrorMsg & vbCrLf & "Line: " & compResults.Errors(x).Line.ToString & " - " + compResults.Errors(x).ErrorText
            Next
            TextBox2.Text = ErrorMsg & vbCrLf & vbCrLf + Code
        Else
            ' create instance of the temporary compiled class
            Dim obj As Object = compResults.CompiledAssembly.CreateInstance("TempClass")
            ' use textbox 2 for output
            Dim args() As Object = {Me.TextBox2}
            Try
                ' execute the code
                Dim result As Object = obj.GetType().InvokeMember("MyCode", BindingFlags.InvokeMethod, Nothing, obj, args)
            Catch Oops As Exception
                ' oops
                MessageBox.Show(Oops.Message)
            End Try
        End If
    End Sub
End Class
  • spremenil: Mavrik ()
darkolord ::
Kakšna je napaka?
Plezalec ::
Tole Mi kaže:
Slika:
https://www.dropbox.com/s/vh19ah607iv53...
podčrtano mi kaže samo rdeče besedilo
  • spremenil: Plezalec ()
AndrejS ::
Probaj vse v eni vrstici napisat. Ali pa na koncu vrstice uporabi : _
cekr ::
Sem potegnil vse od "code" v IDE in ni napake.
Možno, da ti sam VS vidi kakšen neviden znak in ti zato joka, da nekaj ni OK.
Poskusi samo:
Dim Code As String = ""
Code = "Imports System" & vbCrLf &
Code & vbCrLf &
"End Class"
Katero verzijo Studia imaš?
Če je kakšna starejša, boš moral uporabljat "_" za novo vrstico.
Inštaliraj si "Visual Studio Community 2013".
  • spremenilo: cekr ()
win64 ::
AndrejS je izjavil:
Tole bo najverjetnejša napaka.
Določene(ali vse) verzije visual basic-a ne podpirajo ukazov čez več vrstic kot drugi jeziki.
Uporabiti moraš znak _ , da prevajalniku poveš da se ukaz nadaljuje v naslednji vrstici.
Podobno uporabiš znak : , ko bi rad napisal več stavkov v eni vrstici.
Plezalec ::
Trenutno uporabljam Visual basic 2008, bom poskusil kar ste predlagali :)
cekr ::
Plezalec je izjavil:
To je to.
Pri sestavljanju stringa dodaj na koncu vsake vrstice še underline.
Plezalec ::
Živjo, underline popravi napako ampak "pojavi se mi nova". Ko želim "compile" nek preprost ukaz npr MsgBox("123") mi stavek v kodi pobarva rumeno
Program:
https://www.dropbox.com/s/z2ifi6fd9bbam...
Napaka:
https://www.dropbox.com/s/g7rd8ua98aaxl...
win64 ::
Po napaki sodeč ne najde datoteke(ali pa nimaš dostopa do nje) (FileNotFoundException)
Plezalec ::
Ja, kaj lahko naredim da bi odstranil ta problem. Naredil sem compiler, malo pogooglou pa sestavu tole kodo skupaj. (CodeDOM)
Če se kdo spozna naj mi prosim malo svetuje kaj narediti
win64 ::
Pokaži malo več informaciji, stack trace napake bi recimo pomagal zelo.
cekr ::
V referencah za program poskusi nastaviti tako, da se ti bodo vsi dll-ji, ki jih rabiš, kopirali v folder programa (npr. Debug) - na isto raven kot imaš exe.
Plezalec ::
Napiše mi tole:
"A first chance exception of type 'System.IO.FileNotFoundException' occurred in System.dll"
Pa če kliknem Call Stack
> COMPILER-ERROR.exe!WindowsApplication1.Form1.Button1_Click(Object sender = {Text = "Compile"}, System.EventArgs e = {X = 117 Y = 49 Button = System.Windows.Forms.MouseButtons.Left}) Line 35 + 0x55 bytes Basic
Hja in kako bi lahko to naredil?
Plezalec ::
Nevem kaj moti kodo. "MyCode.dll" ki jo ustvari je v isti mapi kot *.exe ampak zmeraj napiše da ne najde fajla. Se komu sanja kaj narediti??
nikigre22 ::
Zdravo imam en problem. Rad bi naredil program ki bi uporablajal datoteke iz usb ključka. Ko bi bil program zagnan in ko bi vstavim ključeki bi prebral neko datoteko in program bi nadaljeval. Ampak ne vem kako naj to naredim. Uporablam visual basic.
In kaj je narobe kaj še manjka v tej odi da mi bo izpisalo podatke v textbox1.
Private Sub Timer1_Tick(sender As Object, e As EventArgs) Handles Timer1.Tick
My.Computer.FileSystem.ReadAllText("G:\denar.money")
cekr ::
Pred my.computer..... napiši:" Dim x as string je "
Potem pa to vrednost nafilaj v svoj obrazec.
Imas pa tudi gradnik, ki ti prozi,ko pride do spremembe v datoteki.
nikigre22 ::
hvala ampak ne deluje..
cekr ::
Ti napiše kakšno napako?
textbox1.text=My.Computer.FileSystem.ReadAllText("G:\denar.money")
Yacked2 ::
Nevem kako je pri Visual Basicu ampak pri C# bi jaz dal tole branje v try, catch oklepaje, ker se ti zna zgodit, da dobi pogon drugo črko, ni pogona, ni datoteke itd...
Korak naprej ni vedno ustrezen...sploh če si na robu prepada!
cekr ::
Yacked2 je izjavil:
To je res, vendar bi mu že VS ven vrgel napako, če ne vidi datoteke.
Če je fiksno definirana črka pogona, ne bo šel drugam gledat.
Razlike med VB.net in C# v funkcionalnosti ni. Imata isto osnovo. Kakšne stvari so v VB malo bolj dodelane. (npr. delo z XML), kar pa ne pomeni, da v drugem ne moreš priti do istega rezultata.
Tu velja pravilo; vse je isti jezik, razlike so samo v narečjih.
nikigre22 ::
Mi je uspelo mogel sem neki com importat. Zdaj pa imam nov problem.
Zakaj mi pokaže spodnji error ali je kaj narobe v kodi?
Imports System
Imports System.IO
Imports System.Text
Public Class Form9
Private Sub Button1_Click(sender As Object, e As EventArgs) Handles Button1.Click
Dim path As String = "j:\dogodki\dogodek.txt"
' Create or overwrite the file.
Dim fs As FileStream = File.Create(path)
' Add text to the file.
Dim info As Byte() = New UTF8Encoding(True).GetBytes("Datum in ura dogodka:" & TextBox1.Text And "Dogodek:" & TextBox2.Text)
fs.Write(info, 0, info.Length)
fs.Close()
Form6.Show()
Me.Hide()
End Sub
Private Sub Form9_Load(sender As Object, e As EventArgs) Handles Me.Load
TextBox1.Text = TimeOfDay
End Sub
error:
Additional information: Conversion from string "Datum in ura dogodka:7:52:06 PM" to type 'Long' is not valid.
Hvala
darkolord ::
Kaj je tisti "And" tam?
nikigre22 ::
Mislil sem kot to and to
darkolord ::
cekr ::
Ti kaj napiše, v kateri vrstici je napaka?
Sicer pa: "And" zamenjaj z & pa bi moral skoz.
nikigre22 ::
Trenutno deluje ampak ne vem kako bi dokument program dopolnjeval da bi vedno ko je gumb pritisnjen šel v naslednjo vrstico in dokumwnt dopolnil
darkolord ::
Namesto vsega tega:
fs.Close()
Napišeš
File.AppendAllText(path, "Datum in ura dogodka:" & TextBox1.Text & "Dogodek:" & TextBox2.Text)
  • spremenilo: darkolord ()
nikigre22 ::
aha.
Kako bi pa lahko vsakič naredil datoteko in jo poeminoval.
Kajti koda za e pošto ne deluje in ne vem zakaj.
Dim smtpServer As New SmtpClient
Dim mail As New MailMessage()
smtpServer.Credentials = New Net.NetworkCredential("admin@nikigre.com", "geslo")
smtpServer.Port = 465
smtpServer.Host = "smtp.domenca.com"
smtpServer.EnableSsl = True
mail = New MailMessage()
mail.From = New MailAddress("admin@nikigre.com")
mail.To.Add(
mail.Subject = "Dvig denarja na bankomatu"
mail.Body ="Datum in ura dogodka:" & TextBox1.Text And "Dogodek:" & TextBox2.Text& "Dvignjeno denarja:" form3.textbox2.text
smtpServer.Send(mail)
Form6.Show()
Me.Hide()
  • spremenilo: nikigre22 ()
darkolord ::
Kako misliš vsakič naredil datoteko? Prej si rekel da bi rad v isto dodajal ...
Kaj javi ta koda za pošto?
nikigre22 ::
Oboje v primeru da ni interneta jo shrani če pa je pa pošlje podatke.
cekr ::
Takole imaš
Ponovno delaš napake z "&"
mail.Body ="Datum in ura dogodka:" & TextBox1.Text & "Dogodek:" & TextBox2.Text & "Dvignjeno denarja:" & form3.textbox2.text
Pazi na presledke pred in za "&". Sicer bo napaka.
visual basic 2008 express edition
Oddelek: Programiranje
222168 (1595) sel
[VB] Komunikacija s serijskimi napravami
412729 (2003) mNeRo
[VB 2005] branje teksta
241980 (1648) mNeRo
[ASP.NET] send mail
51633 (1570) Microsoft
[Visual studio .NET] Rabim pomoč
91996 (1838) darkolord
