Forum » Programiranje » priključjitev cURL knjižnic v Qt [c++]
killa bee ::
Mogoče kdo ve kako bi vključil curl knjižnico v Qtcreator?
Rad bi pognal ta program. Zanj potrebujem knjižnico curl ki se nahaja na http://curl.haxx.se/download.html. Z downlovdal sem 3ji link od vrha. Kako sedaj zdownlowdan .zip file povežem s Qtcreator-jem da mi bo program deloval.
/*************************************************************************** * _ _ ____ _ * Project ___| | | | _ \| | * / __| | | | |_) | | * | (__| |_| | _ <| |___ * \___|\___/|_| \_\_____| * * Copyright (C) 1998 - 2013, Daniel Stenberg, <daniel@haxx.se>, et al. * * This software is licensed as described in the file COPYING, which * you should have received as part of this distribution. The terms * are also available at http://curl.haxx.se/docs/copyright.html. * * You may opt to use, copy, modify, merge, publish, distribute and/or sell * copies of the Software, and permit persons to whom the Software is * furnished to do so, under the terms of the COPYING file. * * This software is distributed on an "AS IS" basis, WITHOUT WARRANTY OF ANY * KIND, either express or implied. * ***************************************************************************/ #include <stdio.h> #include <curl/curl.h> int main(void) { CURL *curl; CURLcode res; curl = curl_easy_init(); if(curl) { curl_easy_setopt(curl, CURLOPT_URL, "http://example.com"); /* example.com is redirected, so we tell libcurl to follow redirection */ curl_easy_setopt(curl, CURLOPT_FOLLOWLOCATION, 1L); /* Perform the request, res will get the return code */ res = curl_easy_perform(curl); /* Check for errors */ if(res != CURLE_OK) fprintf(stderr, "curl_easy_perform() failed: %s\n", curl_easy_strerror(res)); /* always cleanup */ curl_easy_cleanup(curl); } return 0; }
- spremenilo: killa bee ()
Senitel ::
Daj se že navadi. Qt je GUI knjižnica, Qt Creator je razvojno orodje. Tebe torej zanima kako v Qt Creatorju v svoj C++ projekt vključit CURL. Odgovor je tako.
