Kako narediti bazo e-mailov
betmen ::
Kako da v Outlooku naredim bazo e-mailov. Želim dati not mejle od podjetij in jim potem pošiljati e-maile mesečno.
Teh mejlov bo vedno več, zato bo vedno dodajanja na listo.
Nočem pa, ko pošljem enemu, da se potem zgoraj vidi, da je šlo še ostalim 20-tim.
Pa še neki. Kako recimo hiša daril pošilja svoje mejle? Namreč nekje so dobili moj mejl in zdej vsak teden dobivam njihova sporočila. Bi lahko tudi jaz kako tako naredil za svoje klijente?
betmen ::
zdej vidim, da se to imenuje tudi newsletter.
Kako da si vzpostavim kej takega?
black ice ::
Mailchimp recimo.
Yacked2 ::
Če ne drugače lahko nardiš svoj program:
maili shranjeni v .txt, program bere po vrsticah in vsakemu pošlje mail =D
Korak naprej ni vedno ustrezen...sploh če si na robu prepada!
black ice ::
Če hočeš, da vsi maili pristanejo v spam boxu.
Yacked2 ::
black ice je izjavil:
zakaj, enkrat sem delal z VB.net (http://www.tutorialspoint.com/vb.net/vb...
takrat sem se lahko logiral z drugim username kot je bil potem pošiljatelj, sedaj so to popravili.
black ice ::
Yacked2 je izjavil:
Zato (vzeto iz konteksta):
Deliverability and Control of Sender Reputation: A second area of email marketing best practices that is often enhanced by using an outsourced email sending solution is deliverability and control of your sender reputation (the degree to which internet service providers and email service providers consider you a trusted sender of email). An outsourced email marketing platform will have built in tools to help control your spam complaints, inbox deliverability and inbox performance. Most importantly, it will be the outsourced email provider who has to do the work to remain a trusted sending source with a high sender reputation, thus removing that responsibility for your marketing team.
psychoshorty ::
Tudi jaz ti priporocam MailChimp. Sam sicer uporabljam samostojno resitev, pri kateri "ni potreben" double opt-in, kar je pri MailChimpu obvezno. In to tudi podpiram, ampak eni pac zelijo imeti agresivno oglasevanje, katero se potem navadno konca z groznjami tozb ipd.
betmen ::
TOP! Hvala
Seveda ne bom imel agresivnega oglaševanja, ker tudi sam ne maram le tega. Kakšna 3 mejla na leto poslat, tko da lih opozoriš nase malo.
Tiste kuponkote ki pošiljalo po 5, 10 mejlov na dan pa sam z brenerjem grrrr
Šimpanz ::
Če boš pošiljal emaile ne pozabi na dnu dati možnost da se prejemniki odjavijo.
donski ::
Šimpanz :: 24. jul 2014, 15:36
Mislim, da je to kar zakonsko določeno, da mora biti v vsakem mailu možnost odjave.
Phantomeye ::
donski je izjavil:
Ne samo to, to je tudi eden izmed indicev, ki jih MENDA gmail preverja, ko filtrira spam.
Gmail blokada
142635 (2251) Zdvedkidiegs
Program za mailing kampanije
Oddelek: Programska oprema
132738 (2320) MartinKrpan
Spamerji kuponko.si in ostali
Oddelek: Omrežja in internet
74858 (3579) marS
Lastni poštni strežnik(kako ne biti označen kot spam)
214193 (3753) BlackPanx
Checkiranje prebranih mejlov
Oddelek: Izdelava spletišč
122517 (2190) Tody
