Forum » Pomoč in nasveti » Blue screen
Blue screen
DosDominator ::
Zanima me, kako ugotoviš, kaj sporoča blue screen. Iz katere kode lahko razbereš za kaj gre, če se sploh da ali pač pogooglaš za prvo kodo, če je kdo že imel podoben problem?
- spremenil: DosDominator ()
Cold1 ::
Tole je eden izmed rezultatov, ki jih da Google, če vtipkaš understand windows blue screen
Understanding the Blue Screen of Death
http://social.msdn.microsoft.com/Forums...
The BSOD is actually an error screen that is displayed by specific operating systems informing the user that a critical system error has occurred.
It should be noted that when a stop error occurs and your computer displays the Blue Screen of Death, you will also usually be able to see a message. The message might state a FILE_SYSTEM and a number: 0×00000022. Copy this number down, it can be used later to understand and determine why the error occurred. Usually you can visit Microsoft.com [ali pa kar Google.com] and input the error number into their database to find out more information, a description regarding the error and possible fixes for the error.
| » | Kako ugotoviti kaj mi serje? Bluescreeni...Oddelek: Pomoč in nasveti | 3345 (2736) | Cold1 |
| » | Windows XP - lsass.exeOddelek: Operacijski sistemi | 3229 (2045) | Rauf |
| » | sata/ide nepravilno razumevanje pojma!Oddelek: Strojna oprema | 3719 (3392) | Icematxyz |
| » | BSODOddelek: Operacijski sistemi | 1453 (1346) | andrej |
| » | nasvet za XPOddelek: Pomoč in nasveti | 4273 (3865) | [t502] |
