Forum » Programiranje » Android random znaki
Xpie ::
Rabil bi pomoč v 63 vrstici kode, kako bi naredil, da vsakič ko kliknem na gumb chkCmd, da se mi izpiše random tabela 20 znakov.
package com.example.buttons.projekt;
import java.util.Random;
import android.app.Activity;
import android.graphics.Color;
import android.os.Bundle;
import android.text.InputType;
import android.view.Gravity;
import android.view.View;
import android.widget.Button;
import android.widget.EditText;
import android.widget.TextView;
import android.widget.ToggleButton;
public class TextPlay extends Activity {
@Override
protected void onCreate(Bundle savedInstanceState) {
// TODO Auto-generated method stub
super.onCreate(savedInstanceState);
setContentView(R.layout.text); //naredimo novo okno kateri se nahaja v mapi layout
Button chkCmd = (Button) findViewById(R.id.bResults);
final ToggleButton passTog = (ToggleButton) findViewById(R.id.tbPassword);
final EditText input = (EditText) findViewById(R.id.etCommands); // poščemo kje se nahajajo
final TextView display = (TextView) findViewById(R.id.tvResults);
passTog.setOnClickListener(new View.OnClickListener() {
@Override
public void onClick(View arg0) {
if(passTog.isChecked()){
input.setInputType(InputType.TYPE_CLASS_TEXT | InputType.TYPE_TEXT_VARIATION_PASSWORD ); //prvo damo text na vidno potem pa spremenimo na password
}else{
input.setInputType(InputType.TYPE_CLASS_TEXT); //če ne pa damo na vidn text
chkCmd.setOnClickListener(new View.OnClickListener() {
@Override
String check = input.getText().toString(); //vnost texta ki ga spremenimo v string
if(check.contentEquals("left") | check.contentEquals("Left")){ // preverimo če je string enak left
display.setGravity(Gravity.LEFT);
}else if(check.contentEquals("center") | check.contentEquals("Center")){
display.setGravity(Gravity.CENTER);
}else if(check.contentEquals("right") | check.contentEquals("Right")){
display.setGravity(Gravity.RIGHT);
}else if(check.contentEquals("blue") | check.contentEquals("Blue")){
display.setTextColor(Color.BLUE);
}else if (check.contains("WTF") | check.contains("wtf") ){
Random crazy = new Random();
char c;
display.setText(check);
display.setTextSize(crazy.nextInt(75));
display.setTextColor(Color.rgb(crazy.nextInt(265), crazy.nextInt(265), crazy.nextInt(265)));
}else{
display.setText("invalid");
display.setGravity(Gravity.CENTER); //kako se bo besedilo nahajalo
spletne-novice.si
vraGG_ ::
Enojni pipe ( | ) deluje za or?
Also,tam kjer preverjas stinge poskusi mojSting.toLowerCase().equals("beseda"), da nimas dveh checkov.
Vprasanja pa ne razumem najbolje.
Xpie ::
Razmišljal sem tako:
1. Da naredim for zanko, ki bo polnila tabelo z naključnimi znaki(ASCII).
2. Ko bi bila tabela 20 znakov polna bi jih poskušal pretvorit v niz(String).
3. Niz bi potem izpisal na zaslon tako kot je v 63 vrstici.
spletne-novice.si
| » | [Android] Bluetooth aplikacijaOddelek: Programiranje | 1488 (1351) | marjan_h |
| » | Android - ZačetnikOddelek: Programiranje | 2214 (1539) | hurlimannxt |
| » | android črtaOddelek: Programiranje | 2967 (2238) | g333kk |
| » | [android] vstavljanje slikeOddelek: Programiranje | 1658 (1555) | messi |
| » | [android] crashOddelek: Programiranje | 1812 (1621) | messi |
