IPS vs reg LCD
IPS vs reg LCD
fantasycamp ::
Zanima me ali je res velika razlika za tistih 30€
http://www.comshop.si/shop/RaCunalniStv...
vs
http://www.mlacom.si/monitor-lg-23en43v...
bluefish ::
Seveda - TN vs. IPS.
beži stran od tn, razn če rabiš 120Hz..
fantasycamp ::
pač za gledanje filmov, ytube,pisanje kakih mailov,word. Ni za nč zahtevnega!
bluefish ::
Načeloma bi že preživel s TN, vendar je 30€ tako mala razlika, da raje izberi IPS.
fantasycamp ::
As you have probably gathered by now, there is no single type of LCD that is good at everything. What panel type you choose must be a compromise based on how you use the monitor. Gamers will generally be happy with TN panels and their exceptional response time. Photographers and graphic designers should buy an IPS monitor instead.
If you are a writer or work in any other field where contrast is an important factor you should have a look at a monitor with an MVA or PVA panel. If you use the screen to the little bit of everything, you might choose a TN-based monitor to save money or a high-end IPS with low response time if you won't settle for just the mere basics.
Kaj so to MVA ali PNA?
Se pri nas to prodaja?
bluefish ::
MVA ter PVA so tudi dobri. Za filme pravzaprav še bolj kot ti poceni IPS.
tudi ips niso vsi dobri, sploh tisti z 6bit+FRC
skyline ::
Bullshit. 6-bit+FRC je v vseh ekranih pod 500 eur, pa ne pomeni da so vsi zanič.
Obešajte se na druge lastnosti, recimo backlight bleed in PWM frekvenco pri nižji nastavitvi svetilnosti, ki pri folku povzroča glavobol. Razlike med 8-bit in 6+FRC pa nihče ne bo opazil.
  • spremenil: skyline ()
ni vsak frc in panel kot tak enako dober...
In kar se tiče cene; korjeca dobiš z 8bit za slabih ~300€
fantasycamp ::
Vprašaš za nasvet pa začne folk bluzit o drugih stvareh ki nimajo veze samo da pohvalijo znanje ki nima veze s temo..
piek ::
Vzames IPS model in uzivas. Primerjava med TN (se posebej najcenejsimi TN) in IPS monitorji je taka, da se ti zdi, da so na TN modelih vsi piksli "mrtvi". :))
--- Finish it off if you started it! ---
54j0 ::
Moj glas za IPS. Barve so neprimerljivo boljše od TN modelov in tudi s strani se lepo vidijo barve. Res je, da veliko modelov prepušča nekaj svetlobe in je to opazno, ko je na zaslonu veliko črnine - ni pa pretirano moteče, če se v to ne vpikneš. Odzivni čas je dovolj nizek, da lako brez težav gledaš tudi filme in igraš igre (nisem opazil neke razlike med 2ms TN in 8ms IPS).
to črnino se da rešit tako, da nastaviš output range na 16-255 v medijskih predvajalnikih..
vsaj jst z primernimi nastavitvami v samem monitorju nimam nekih problemov z light bleed..
Prevelik IPS Glow/BLB?
Oddelek: Zvok in slika
202777 (2341) neocodexx
Življenska doba monitorja (strani: 1 2 )
5110570 (8552) dela
Monitor do 300 EUR
253897 (3116) SloBiscuit
Kupujem monitor (27")
173021 (2660) gddr85
Kateri monitor (strani: 1 2 )
7619229 (17638) skyline
