Forum » Mobilne tehnologije » Pomoč: rootanje in Romanje ;) SGS 3 mini
Zvezdica27 ::
lp,
pomagajte: kako naj rootam in romam glaxy s3 mini... zanj ni skor nič, rabim pa 4.2 ker je 4.1.2 obup...
lahko se tudi kdo javi, plačam
hvala,
blaž
hvala,
blaž
Xserces ::
- spremenil: Xserces ()
Xserces ::
http://maclaw.pl/installation-guide-gol...
How to install CyanogenMod 10.2?
First installation
You need to download these files:
Odin v3.07 for Windows: Download
Samsung USB driver: Download
Latest CM10.2 for Odin from our download page. Download
Google Apps Download
And then perform this steps:
Unzip SAMSUNG_USB_Driver.zip and install drivers
Unzip Odin_golden.zip
Unzip downloaded package with latest CM10.2. You should get file with *.tar.md5 extension
In opened window, click on PDA button and select file with *.tar.md5 extension from previous step
Make sure that only Auto Reboot and F.Reset Time are selected on the left side
Turn off your phone, and then use VOL- & HOME & POWER buttons combination
If you see Warning screen, use VOL+ button
You should see Android and some information
Connect phone to computer and make sure it is detected by Odin (it will appear as COM device). If it doesn't, try to use other USB port
Use Start button. Wait until flash process will finish
Your phone will restart, but probably won't boot. Pull down your battery and use VOL+ & HOME & POWER buttons combo to boot into recovery
Click on Wipe, then use slider on the bottom to let process begin
Click on Home icon, and then Reboot -> System
Wait for boot. Now you should have CM10.2
If you want to install Google Apps (Play Store, Gmail etc.):
Get Google Apps for CM10.2 from our download page and copy it to main directory of your internal storage
Shutdown your phone
Use VOL+ & HOME & POWER buttons combo to boot into recovery
When recovery will boot, go to install, select downloaded package with Google Apps and then use slider on the bottom to let process begin
When installation will finish, use Reboot to system option to boot your phone
First installation
Shutdown your phone
Zvezdica27 ::
hvala vsem... nisem vedel da je že, še pred mesecem ni bilo. prebral, probal... samo kaj ko ne doma niti na šihtu nimam win računala... sem že probal preko Heimdall pa ne gre, Wine ne prime...
ampak bom že našel win računalo, jebemu...
zz
zz
| » | Samsung predstavil trpežni Xcover 3 (strani: 1 2 )Oddelek: Novice / Android | 22935 (18270) | CitroX |
| » | [Galaxy S2] Težava z zagonom Cyanogen modaOddelek: Mobilne tehnologije | 2132 (1697) | Lonsarg |
| » | Samsung galaxy note BRICKOddelek: Mobilne tehnologije | 4620 (4107) | CaqKa |
| » | Dober Singleplayer campain FPS špil?Oddelek: Igre | 5803 (4977) | Bor H |
| » | Iščem alternativo vudujuOddelek: Kaj kupiti | 2450 (2214) | Arthur |
