Forum » Igre » ISO IGRE
ISO IGRE
badboy ::
kaj sploh so ISO igre in programi ???
imam skopiran z neta eno igro ki naj bi bila iso ko pa sem odpakiral pa je ratal en fajl ime.img ... sam ta img mi ne dela pod nobenmu programom za CD-R ce naj bi bil to image fajle...s kermu bi to delal ce je to to ?
info@badboy.bihosting.com
whatson ::
uporabi NEROta
evo ti navodila:
1.Start Nero
2.Choose the menu command "File"->"Burn CD image"
3.Choose as file type: all files (*.*)
4.Select the ISO image file
5.Now you will see a dialog, asking you, if you want to supply detailled
image parameters. This is necessary, since Nero needs to know
exactly, what format the image file has to be able to burn it correctly.
6.Enter the following parameters:
- Mode 1 (assuming, that you created a mode 1 image)
- 2048 bytes per sector (corresponds to a mode 1 sector)
- 0 bytes header and trailer (assuming, the image contains
only "pure" ISO data and no other special header
or trailer)
- no swapping or scrambling (assuming, that the file contains
bytes in the correct order to be written without word swapping)
7.Click on "burn" and (for safety considerations) use an empty cdr.
evo ti navodila:
1.Start Nero
or trailer)
| » | Kako instalirati ubuntu brez usbja/cdja/dvdjaOddelek: Pomoč in nasveti | 2710 (2458) | AC_DC |
| » | LG GSA-4120B dela probleme pri pečenju DL DVD+RjevOddelek: Strojna oprema | 2190 (1999) | mtosev |
| » | SnemanjeOddelek: Programska oprema | 1319 (1205) | matej97 |
| » | Peka .iso datoteke...Oddelek: Programska oprema | 1678 (1565) | tha_man |
| » | ISO file - Kako zapect na CDOddelek: Programska oprema | 1945 (1820) | frudi |
