TrueCrypt audit project
denial ::
SELECT finger FROM hand WHERE id=3;
nurse013 ::
you gotta be kidding me...
denial ::
I don't have any inside knowledge about TrueCrypt, and there's a lot about it that makes me suspicious. - Bruce Schneier
Vir
Highlag ::
Ja če hočeš zaupati eni enkripciji je najbolje, da jo napišeš sam. Seveda če si dovolj kompetenten za takšno opravilo. Seveda je tudi dobro, da jo pogleda še kdo, ki se na te stvari zastopi in mu zaupaš. Vendar kdo je danes res vreden zaupanja? To je verjetno večji problem kot samo naredit en program za enkripcijo.
denial ::
@Highlag:
Se popolnoma strinjam.
Uporabnik ::
Truecrypt je čist ok, dokler ni tvoj enenmy kakšna "država", ki to zarvija.
Matija82 ::
Highlag je izjavil:
Enkripcija, ki je ne znata zlomit avtor in njegov prijatelj je več ali manj ničvredna, ker ima adversary mnogo več in mnogo pametnejših ljudi kot je ta duo.
denial, a ne bi linkal še prejšnjega stavka ki pravi "I downloaded and installed OpenOffice, a PDF reader, a text editor, TrueCrypt, and BleachBit" ;)
Vse te teorije zarote glede TC-ja so zaenkrat mešanje megle (ala OMG NSA HAS ALL THE NODZ!) in temeljijo večinoma na licenčni zmedi, ne pa na samem dizajnu programja. Je pa tale audit super ideja in upam, da se izpelje do kraja.
  • spremenilo: Matija82 ()
denial ::
The Windows version of TrueCrypt 7.0a deviates from the Linux version in that it fills the last 65,024 bytes of the header with random values whereas the Linux version fills this with encrypted zero bytes. From the point of view of a security analysis the behavior of the Windows version is problematic. By an analysis of the decrypted header data it can't be distinguished whether these are indeed random values or a second encryption of the master and XTR key with a back door password.
Vir
denial ::
I have not looked at the TrueCrypt license (in depth) in quite some
time, but when Fedora and Red Hat reviewed it in 2008, not only was it
non-free, it was actually dangerous.
Vir
fiction ::
denial je izjavil:
Vir
S stališča audita je vse skupaj nočna mora. Ampak za praktično uporabo lahko po generiranju voluma, če si dovolj paranoičen enostavno teh 65024 bajtov prepišeš z vsebino /dev/random ali se motim? Potem si tisto vsebino shraniš in primerjaš, če jo TrueCrypt prepiše s čim svojim. V kolikor ja, je to lahko že indic za "evilness" (če so tisti bajti res "doesn't care").
Vprašanje, če je šifrirana 0 boljša kot random, prvo ti namreč teoretično lahko pomaga, če bi se šel kak known-plaintext napad...
denial ::
micka15 ::
Highlag je izjavil:
pa svoj compiler, pa ves hw, vse firmware, ...
Karen ::
Ja, pa software v čipu na disku kontrolerja, ker ti enkripcija na disk nič kaj dosti ne pomaga če kontroler prebere dešifrirano vsebino.
terryww ::
ne rabiš niti nedokumentiranih čipov. dovolj je proprietary bios in te nobena čarovnija več ne spasi.
It is the night. My body's weak.
I'm on the run. No time to sleep.
Jst ::
Jaz sem ravno hotel odpreti temo o TrueCrypt Audit crowdfunding kampanji, tako da še dobro, da sem prvo uporabil iskanje.
Iz članka mi je zanimiv tale del:
Also, the most common TrueCrypt packages are downloadable binaries for Windows that cannot be compared to the original source code; those binaries behave differently than versions compiled from source code, experts say.
Nisem pa našel ničesar, kjer bi se s tem dejansko ukvarjali. Kdo so ti "Experts," ki to trdijo?
jkreuztzfeld ::
Great minds run in great circles.
Revizija TrueCrypta gre dalje
Oddelek: Novice / Varnost
2210523 (6061) Satoshi
heknili http://truecrypt.sourceforge.net, ki zdaj svari pred uporabo truecrypa
4410043 (7862) root987
Izšel TrueCrypt 7.0 (strani: 1 2 3 )
Oddelek: Novice / Zasebnost
11939973 (36473) Jst
TrueCrypt 5.0 (strani: 1 2 )
7012814 (10226) poweroff
Izšel TrueCrypt 4.0
265827 (4968) poweroff
