Forum » Loža » Manuka med in herpes
Alen716 ::
Po netu je veliko govora o tem da se z manuka medom odpravlja herpes na obrazu in tudi genitalnega, torej oba, HSV-1 in HSV-2.
Je kdo sprobal ta med, če res deluje?
Kle je še klinična študija: http://www.ncbi.nlm.nih.gov/pubmed/1639...
- spremenil: Alen716 ()
Alen716 ::
Manuka med je res neki posebnega. Glavna razlika med navadnim in manuka je ravno v vsebnosti hidrogen peroksida, zato ljudje uporabljajo ta med tudi za čiščenje sinusov.
UMF-Active Manuka Honey guarantees consumers that the important hydrogen peroxide contained in it remains stable unlike those present in ordinary honey that can easily be destroyed by light, heat and water. Moreover, it is also better in fighting against wide range of bacteria including helicobacter pylori, the bacteria which causes most stomach ulcers; staphylococcus aureus, the bacteria which causes infection in wounds; and streptococcus pyogenes, the bacteria which causes sore throats in person.
Spajky ::
... saj Propolis tudi, sam preveril: čim se začne delat, takoj namažeš ...
zee ::
Marketspeak. Vodikov peroksid pod vplivom svetlobe, toplote, prisotnih kovinskih ionov spontano razpada na kisik in vodo. Ne vidim kemijskega nacina, da bi ga Manuka med lahko stabiliziral.
zee
Alen716 ::
Ljudje ki so uporablal navadn med ali manuka 5+ recimo, so podal komentarje, da ni delovalo najbolje. Zato je potrebno vzet vsaj manuko faktor 10+ in več, da je efekt glede antibakterijskega učinka.
JA očitno je obratno od peroksida.
UMF - A Quality Trademark Protecting Your Rights as a Consumer
UMF stands for Unique Manuka Factor.
UMF is a quality trademark identifying natural unadulterated manuka honey that has a special unique natural non-peroxide antibacterial activity found only in some strains of manuka honey.
UMF is a quality trademark protecting your rights as a consumer because not all manuka honey has the unique non-peroxide activity and among those that do the strength varies.
UMF is a quality trademark that can be used only by licensed users who must be a New Zealand company and meet set criteria.
Posebej naj bi bil učinkovit za bakterijo MRSO.
Vikking ::
V bistvu katerikoli slovenski med, ki ni industrijsko predelan, bo deloval antibakterijsko in protivnetno. Zato se ga tudi priporoča za dajanje na rano.
Tale manuka med pa kolikor razumem gre za Novozelandsko pogruntavščino kako prodat poceni med, dražje. Pač način trženja, ki ga bomo mogoče mi razumeli šele čez 10-20let, ali pa ne želimo zakrivati dejstev, jah sej katerikoli drugi med to omogoča. Res je da obstoja veliko različnih medov, z različno vrsto in količino cvetnega prahu.
Če bi ugibal bi rekel, da slovenski kostanjev med bi moral delovati enako če ne bolje od manuka. Glede na to da pri nas v obdobju ko cveti kostanj, precej manj cvetijo druge rastline, zato se ga da dobiti po širni sloveniji v precej čisti obliki. Tudi čebelarji ponavadi ciljajo na začetek druge runde, prav z pašo na kostanju.
V Sloveniji pridelamo zelo kakovosten in odličen med. Najboljšega boste dobili po vsej verjetnosti pri lokalnemu čebelarju. Cena sicer odbija, ampak boste dobili vsaj pravi med in ne cukrano vodo.
Pa še za finiš: 5x večja verjetnost je da boste kupili "ponarejen" manuka med kot pravega. Zakaj? zato ker ga pridelajo cca. 1.700ton letno, pod manuka oznako pa se ga proda seveda po tapravi ceni 10.000ton.
Kaj naredi par znanih osebnosti da ga omenijo in navaden med rata dražje kot zlato.
| » | Krema za boljše celjenje ranOddelek: Šport | 10930 (9482) | GupeM |
| » | Vaše mnenje o slavnem manuka meduOddelek: Loža | 8034 (7086) | louser |
| » | Kateri med je dober in najbolj zdrav? (strani: 1 2 )Oddelek: Loža | 37395 (27697) | Tilen |
| ⊘ | Opeku sm se z vročim oljem... (strani: 1 2 )Oddelek: Loža | 12981 (11459) | zee |
| » | S čim proti prehladu (strani: 1 2 )Oddelek: Loža | 22269 (21124) | BigWhale |
