HP Pavilion dv7 reboot problem
Yacked2 ::
Pozdravljeni,
danes se mi je ponovno računalik sam od sebe rebootal. Imel sem odprt predvajalnik glasbe ter nekaj zavihkov pri Firefoxu. Po rebootu se mi je prikazala tista stran kjer lahko izbiram med safe mode in tako naprej. Sedaj deluje normalno. Se mi to večkrat dogaja. Sem imel računalik že na servisu pa so mi rekli da ni nič narobe. Očitno je....
Nato sem pogledal v event viewer. Pod applications se mi nahaja samo ta napaka, poleg gmote obvestil:
- <Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
- <System>
  <Provider Name="Microsoft-Windows-WMI" Guid="{1edeee53-0afe-4609-b846-d8c0b2075b1f}" EventSourceName="WinMgmt" />
  <EventID Qualifiers="49152">10</EventID>
  <Version>0</Version>
  <Level>2</Level>
  <Task>0</Task>
  <Opcode>0</Opcode>
  <Keywords>0x80000000000000</Keywords>
  <TimeCreated SystemTime="2013-07-24T10:56:39.000000000Z" />
  <EventRecordID>3741</EventRecordID>
  <Correlation />
  <Execution ProcessID="0" ThreadID="0" />
  <Channel>Application</Channel>
  <Computer>Prenosnik-PC</Computer>
  <Security />
  </System>
- <EventData>
  <Data>//./root/CIMV2</Data>
  <Data>SELECT * FROM __InstanceModificationEvent WITHIN 60 WHERE TargetInstance ISA "Win32_Processor" AND TargetInstance.LoadPercentage > 99</Data>
  <Data>0x80041003</Data>
  </EventData>
  </Event>
Pod setup imam nekaj zaporednih takih napak, z tem da se thread number spreminja:
- <System>
  <Provider Name="Microsoft-Windows-WUSA" Guid="{09608C12-C1DA-4104-A6FE-B959CF57560A}" />
  <EventID>3</EventID>
  <Level>2</Level>
  <Task>0</Task>
  <Opcode>0</Opcode>
  <Keywords>0x8000000000000000</Keywords>
  <TimeCreated SystemTime="2013-07-02T21:42:46.170995000Z" />
  <EventRecordID>629</EventRecordID>
  <Correlation />
  <Execution ProcessID="11560" ThreadID="7676" />
  <Channel>Setup</Channel>
  <Security UserID="S-1-5-21-3653945580-4026675252-2180356715-1000" />
  </System>
- <EventData>
  <Data Name="UpdateTitle" />
  <Data Name="ErrorCode">2149842967</Data>
  <Data Name="ErrorString" />
  <Data Name="CommandLine">"C:\Windows\System32\wusa.exe" "C:\Program Files (x86)\Hewlett-Packard\ESU for Microsoft Windows 7\HotFix\x64\Windows6.1-KB974560-v2-x64.msu" /quiet /norestart"</Data>
  </EventData>
  </Event>
Pod system imam nekaj zaporednih opozoril zaradi driverjev, ker imam Vmware nameščen na računaliku. Ter še nekaj drugih opozoril. Nato pa tale critical:
- <System>
  <Provider Name="Microsoft-Windows-Kernel-Power" Guid="{331C3B3A-2005-44C2-AC5E-77220C37D6B4}" />
  <EventID>41</EventID>
  <Version>2</Version>
  <Level>1</Level>
  <Task>63</Task>
  <Opcode>0</Opcode>
  <Keywords>0x8000000000000002</Keywords>
  <TimeCreated SystemTime="2013-07-26T20:09:22.833611100Z" />
  <EventRecordID>11710</EventRecordID>
  <Correlation />
  <Execution ProcessID="4" ThreadID="8" />
  <Channel>System</Channel>
  <Security UserID="S-1-5-18" />
  </System>
- <EventData>
  <Data Name="BugcheckCode">0</Data>
  <Data Name="BugcheckParameter1">0x0</Data>
  <Data Name="BugcheckParameter2">0x0</Data>
  <Data Name="BugcheckParameter3">0x0</Data>
  <Data Name="BugcheckParameter4">0x0</Data>
  <Data Name="SleepInProgress">false</Data>
  <Data Name="PowerButtonTimestamp">0</Data>
  </EventData>
  </Event>
Pod njim je še tale error:
- <System>
  <Provider Name="EventLog" />
  <EventID Qualifiers="32768">6008</EventID>
  <Level>2</Level>
  <Task>0</Task>
  <TimeCreated SystemTime="2013-07-26T20:09:33.000000000Z" />
  <EventRecordID>11706</EventRecordID>
  <Security />
  </System>
- <EventData>
  <Data>22:08:07</Data>
  <Data>&#8206;26.&#8206;7.&#8206;2013</Data>
  <Data />
  <Data />
  <Data>8880</Data>
  <Data />
  <Data />
  <Binary>DD07070005001A001600080007000B02DD07070005001A001400080007000B02600900003C000000010000006009000000000000B0040000010000001F400000</Binary>
  </EventData>
  </Event>
Nižje je še tole opozorilo:
- <System>
  <Provider Name="Microsoft-Windows-DNS-Client" Guid="{1C95126E-7EEA-49A9-A3FE-A378B03DDB4D}" />
  <EventID>1014</EventID>
  <Level>3</Level>
  <Task>0</Task>
  <Opcode>0</Opcode>
  <Keywords>0x4000000000000000</Keywords>
  <TimeCreated SystemTime="2013-07-26T19:31:47.524807000Z" />
  <EventRecordID>11688</EventRecordID>
  <Correlation />
  <Execution ProcessID="1864" ThreadID="4392" />
  <Security UserID="S-1-5-20" />
  </System>
- <EventData>
  <Data Name="QueryName">wpad.Home</Data>
  <Data Name="AddressLength">16</Data>
  <Data Name="Address">02000035C0A801010000000000000000</Data>
  </EventData>
  </Event>
Pod administrative logs imam od danes tole:
Log Name:      Microsoft-Windows-Dhcp-Client/Admin
Source:        Microsoft-Windows-Dhcp-Client
Date:          26.7.2013 22:11:43
Event ID:      1001
Task Category: Address Configuration State Event
Level:         Error
Keywords:
User:          LOCAL SERVICE
Computer:      Prenosnik-PC
Description:
Your computer was not assigned an address from the network (by the DHCP Server) for the Network Card with network address 0x00C0CA58B74D.  The following error occurred: 0x79. Your computer will continue to try and obtain an address on its own from the network address (DHCP) server.
Event Xml:
  <System>
    <Provider Name="Microsoft-Windows-Dhcp-Client" Guid="{15A7A4F8-0072-4EAB-ABAD-F98A4D666AED}" />
    <EventID>1001</EventID>
    <Level>2</Level>
    <Task>3</Task>
    <Opcode>75</Opcode>
    <TimeCreated SystemTime="2013-07-26T20:11:43.209459100Z" />
    <EventRecordID>497</EventRecordID>
    <Correlation />
    <Execution ProcessID="592" ThreadID="1144" />
    <Channel>Microsoft-Windows-Dhcp-Client/Admin</Channel>
    <Security UserID="S-1-5-19" />
  </System>
  <EventData>
    <Data Name="HWLength">6</Data>
    <Data Name="HWAddress">00C0CA58B74D</Data>
    <Data Name="StatusCode">121</Data>
  </EventData>
</Event>
Log Name:      Application
Source:        Microsoft-Windows-WMI
Date:          26.7.2013 22:10:06
Event ID:      10
Task Category: None
Level:         Error
Keywords:      Classic
User:          N/A
Description:
Event filter with query "SELECT * FROM __InstanceModificationEvent WITHIN 60 WHERE TargetInstance ISA "Win32_Processor" AND TargetInstance.LoadPercentage > 99" could not be reactivated in namespace "//./root/CIMV2" because of error 0x80041003. Events cannot be delivered through this filter until the problem is corrected.
Event Xml:
  <System>
    <Level>2</Level>
    <Task>0</Task>
    <Opcode>0</Opcode>
    <TimeCreated SystemTime="2013-07-26T20:10:06.000000000Z" />
    <EventRecordID>3905</EventRecordID>
    <Correlation />
    <Security />
  </System>
  <EventData>
    <Data>SELECT * FROM __InstanceModificationEvent WITHIN 60 WHERE TargetInstance ISA "Win32_Processor" AND TargetInstance.LoadPercentage &gt; 99</Data>
  </EventData>
</Event>
Log Name:      System
Source:        hcmon
Date:          26.7.2013 22:10:02
Event ID:      0
Task Category: None
Level:         Warning
Keywords:      Classic
User:          N/A
Description:
Detected unrecognized USB driver (\Driver\pci).
Event Xml:
  <System>
    <Provider Name="hcmon" />
    <EventID Qualifiers="32768">0</EventID>
    <Level>3</Level>
    <Task>0</Task>
    <TimeCreated SystemTime="2013-07-26T20:10:02.071878400Z" />
    <EventRecordID>11802</EventRecordID>
    <Security />
  </System>
  <EventData>
    <Data>\Device\hcmon</Data>
    <Data>\Driver\pci</Data>
    <Binary>00000000020028000000000000000080000000000000000000000000000000000000000000000000</Binary>
  </EventData>
</Event>
Log Name:      System
Source:        hcmon
Event ID:      0
Task Category: None
Level:         Warning
Keywords:      Classic
User:          N/A
Description:
Detected unrecognized USB driver (\Driver\ACPI).
Event Xml:
  <System>
    <Level>3</Level>
    <Task>0</Task>
    <EventRecordID>11801</EventRecordID>
    <Security />
  </System>
  <EventData>
    <Data>\Driver\ACPI</Data>
  </EventData>
</Event>
Log Name:      System
Source:        hcmon
Event ID:      0
Task Category: None
Level:         Warning
Keywords:      Classic
User:          N/A
Description:
Detected unrecognized USB driver (\Driver\iusb3xhc).
Event Xml:
  <System>
    <Level>3</Level>
    <Task>0</Task>
    <EventRecordID>11800</EventRecordID>
    <Security />
  </System>
  <EventData>
    <Data>\Driver\iusb3xhc</Data>
  </EventData>
</Event>
Log Name:      System
Source:        hcmon
Event ID:      0
Task Category: None
Level:         Warning
Keywords:      Classic
User:          N/A
Description:
Event Xml:
  <System>
    <Level>3</Level>
    <Task>0</Task>
    <EventRecordID>11799</EventRecordID>
    <Security />
  </System>
  <EventData>
  </EventData>
</Event>
Log Name:      System
Source:        hcmon
Event ID:      0
Task Category: None
Level:         Warning
Keywords:      Classic
User:          N/A
Description:
Event Xml:
  <System>
    <Level>3</Level>
    <Task>0</Task>
    <EventRecordID>11798</EventRecordID>
    <Security />
  </System>
  <EventData>
  </EventData>
</Event>
Log Name:      System
Source:        hcmon
Event ID:      0
Task Category: None
Level:         Warning
Keywords:      Classic
User:          N/A
Description:
Event Xml:
  <System>
    <Level>3</Level>
    <Task>0</Task>
    <EventRecordID>11797</EventRecordID>
    <Security />
  </System>
  <EventData>
  </EventData>
</Event>
Log Name:      System
Source:        Microsoft-Windows-Wininit
Date:          26.7.2013 22:09:40
Event ID:      11
Task Category: None
Level:         Warning
Keywords:
User:          SYSTEM
Description:
Custom dynamic link libraries are being loaded for every application. The system administrator should review the list of libraries to ensure they are related to trusted applications.
Event Xml:
  <System>
    <Provider Name="Microsoft-Windows-Wininit" Guid="{206F6DEA-D3C5-4D10-BC72-989F03C8B84B}" />
    <EventID>11</EventID>
    <Level>3</Level>
    <Task>0</Task>
    <Opcode>0</Opcode>
    <TimeCreated SystemTime="2013-07-26T20:09:40.312841800Z" />
    <EventRecordID>11748</EventRecordID>
    <Correlation />
    <Execution ProcessID="644" ThreadID="676" />
  </System>
  <EventData>
    <Data Name="StringCount">1</Data>
    <Data Name="String">C:\Windows\system32\nvinitx.dll</Data>
  </EventData>
</Event>
Log Name:      Security
Source:        Microsoft-Windows-Eventlog
Date:          26.7.2013 22:09:34
Event ID:      1101
Task Category: Event processing
Level:         Error
Keywords:      Audit Success
User:          N/A
Description:
Audit events have been dropped by the transport.  0
Event Xml:
  <System>
    <Provider Name="Microsoft-Windows-Eventlog" Guid="{fc65ddd8-d6ef-4962-83d5-6e5cfe9ce148}" />
    <EventID>1101</EventID>
    <Level>2</Level>
    <Task>101</Task>
    <Opcode>0</Opcode>
    <Keywords>0x4020000000000000</Keywords>
    <TimeCreated SystemTime="2013-07-26T20:09:34.159231000Z" />
    <EventRecordID>3701</EventRecordID>
    <Correlation />
    <Execution ProcessID="592" ThreadID="1076" />
    <Channel>Security</Channel>
    <Security />
  </System>
  <UserData>
    <AuditEventsDropped xmlns:auto-ns3="http://schemas.microsoft.com/win/2004/08/events" xmlns="http://manifests.microsoft.com/win/2004/08/windows/eventlog">
      <Reason>0</Reason>
    </AuditEventsDropped>
  </UserData>
</Event>
Log Name:      System
Source:        Microsoft-Windows-Kernel-PnP
Date:          26.7.2013 22:09:29
Event ID:      219
Task Category: (212)
Level:         Warning
Keywords:
User:          SYSTEM
Description:
The driver \Driver\WUDFRd failed to load for the device USB\VID_138A&PID_0018\bd38f4c37cdc.
Event Xml:
  <System>
    <Provider Name="Microsoft-Windows-Kernel-PnP" Guid="{9C205A39-1250-487D-ABD7-E831C6290539}" />
    <EventID>219</EventID>
    <Level>3</Level>
    <Task>212</Task>
    <Opcode>0</Opcode>
    <TimeCreated SystemTime="2013-07-26T20:09:29.978423700Z" />
    <EventRecordID>11723</EventRecordID>
    <Correlation />
    <Execution ProcessID="4" ThreadID="108" />
  </System>
  <EventData>
    <Data Name="DriverNameLength">34</Data>
    <Data Name="DriverName">USB\VID_138A&amp;PID_0018\bd38f4c37cdc</Data>
    <Data Name="Status">3221226341</Data>
    <Data Name="FailureNameLength">14</Data>
    <Data Name="FailureName">\Driver\WUDFRd</Data>
    <Data Name="Version">0</Data>
  </EventData>
</Event>
Log Name:      System
Source:        Microsoft-Windows-Kernel-Power
Date:          26.7.2013 22:09:22
Event ID:      41
Task Category: (63)
Level:         Critical
Keywords:      (2)
User:          SYSTEM
Description:
The system has rebooted without cleanly shutting down first. This error could be caused if the system stopped responding, crashed, or lost power unexpectedly.
Event Xml:
  <System>
    <Level>1</Level>
    <Task>63</Task>
    <Opcode>0</Opcode>
    <Correlation />
  </System>
  <EventData>
  </EventData>
</Event>
Log Name:      System
Source:        EventLog
Date:          26.7.2013 22:09:33
Event ID:      6008
Task Category: None
Level:         Error
Keywords:      Classic
User:          N/A
Description:
The previous system shutdown at 22:08:07 on &#8206;26.&#8206;7.&#8206;2013 was unexpected.
Event Xml:
  <System>
    <Level>2</Level>
    <Task>0</Task>
    <Security />
  </System>
  <EventData>
    <Data>
    </Data>
    <Data>
    </Data>
    <Data>8880</Data>
    <Data>
    </Data>
    <Data>
    </Data>
  </EventData>
</Event>
Log Name:      System
Source:        Microsoft-Windows-DNS-Client
Date:          26.7.2013 21:31:47
Event ID:      1014
Task Category: None
Level:         Warning
Keywords:
User:          NETWORK SERVICE
Description:
Name resolution for the name wpad.Home timed out after none of the configured DNS servers responded.
Event Xml:
  <System>
    <Level>3</Level>
    <Task>0</Task>
    <Opcode>0</Opcode>
    <Correlation />
  </System>
  <EventData>
  </EventData>
</Event>
Date:          26.7.2013 15:08:55
Event ID:      1001
Level:         Error
Keywords:
User:          LOCAL SERVICE
Description:
Event Xml:
  <System>
    <Level>2</Level>
    <Task>3</Task>
    <Opcode>75</Opcode>
    <TimeCreated SystemTime="2013-07-26T13:08:55.017561100Z" />
    <EventRecordID>488</EventRecordID>
    <Correlation />
    <Execution ProcessID="544" ThreadID="1048" />
  </System>
  <EventData>
  </EventData>
</Event>
Log Name:      System
Source:        hcmon
Date:          26.7.2013 15:07:07
Event ID:      0
Task Category: None
Level:         Warning
Keywords:      Classic
User:          N/A
Description:
Event Xml:
  <System>
    <Level>3</Level>
    <Task>0</Task>
    <TimeCreated SystemTime="2013-07-26T13:07:07.626262300Z" />
    <EventRecordID>11621</EventRecordID>
    <Security />
  </System>
  <EventData>
  </EventData>
</Event>
Log Name:      System
Source:        hcmon
Event ID:      0
Task Category: None
Level:         Warning
Keywords:      Classic
User:          N/A
Description:
Event Xml:
  <System>
    <Level>3</Level>
    <Task>0</Task>
    <EventRecordID>11620</EventRecordID>
    <Security />
  </System>
  <EventData>
  </EventData>
</Event>
Log Name:      System
Source:        hcmon
Event ID:      0
Task Category: None
Level:         Warning
Keywords:      Classic
User:          N/A
Description:
Event Xml:
  <System>
    <Level>3</Level>
    <Task>0</Task>
    <EventRecordID>11619</EventRecordID>
    <Security />
  </System>
  <EventData>
  </EventData>
</Event>
Log Name:      System
Source:        hcmon
Event ID:      0
Task Category: None
Level:         Warning
Keywords:      Classic
User:          N/A
Description:
Event Xml:
  <System>
    <Level>3</Level>
    <Task>0</Task>
    <EventRecordID>11618</EventRecordID>
    <Security />
  </System>
  <EventData>
  </EventData>
</Event>
Log Name:      System
Source:        hcmon
Event ID:      0
Task Category: None
Level:         Warning
Keywords:      Classic
User:          N/A
Description:
Event Xml:
  <System>
    <Level>3</Level>
    <Task>0</Task>
    <EventRecordID>11617</EventRecordID>
    <Security />
  </System>
  <EventData>
  </EventData>
</Event>
Log Name:      System
Source:        hcmon
Event ID:      0
Task Category: None
Level:         Warning
Keywords:      Classic
User:          N/A
Description:
Event Xml:
  <System>
    <Level>3</Level>
    <Task>0</Task>
    <EventRecordID>11616</EventRecordID>
    <Security />
  </System>
  <EventData>
  </EventData>
</Event>
Event ID:      10
Task Category: None
Level:         Error
Keywords:      Classic
User:          N/A
Description:
Event Xml:
  <System>
    <Level>2</Level>
    <Task>0</Task>
    <Opcode>0</Opcode>
    <TimeCreated SystemTime="2013-07-26T13:07:07.000000000Z" />
    <EventRecordID>3865</EventRecordID>
    <Correlation />
    <Security />
  </System>
  <EventData>
  </EventData>
</Event>
Log Name:      System
Date:          26.7.2013 15:06:55
Event ID:      11
Task Category: None
Level:         Warning
Keywords:
User:          SYSTEM
Description:
Event Xml:
  <System>
    <Level>3</Level>
    <Task>0</Task>
    <Opcode>0</Opcode>
    <TimeCreated SystemTime="2013-07-26T13:06:55.079640600Z" />
    <EventRecordID>11594</EventRecordID>
    <Correlation />
    <Execution ProcessID="660" ThreadID="692" />
  </System>
  <EventData>
  </EventData>
</Event>
Log Name:      System
Date:          26.7.2013 15:06:44
Event ID:      219
Level:         Warning
Keywords:
User:          SYSTEM
Description:
Event Xml:
  <System>
    <Level>3</Level>
    <Task>212</Task>
    <Opcode>0</Opcode>
    <TimeCreated SystemTime="2013-07-26T13:06:44.760023300Z" />
    <EventRecordID>11542</EventRecordID>
    <Correlation />
    <Execution ProcessID="4" ThreadID="96" />
  </System>
  <EventData>
  </EventData>
</Event>
Log Name:      System
Source:        Microsoft-Windows-WLAN-AutoConfig
Date:          26.7.2013 0:09:22
Event ID:      4001
Task Category: None
Level:         Warning
Keywords:
User:          SYSTEM
Description:
WLAN AutoConfig service has successfully stopped.
Event Xml:
  <System>
    <Provider Name="Microsoft-Windows-WLAN-AutoConfig" Guid="{9580D7DD-0379-4658-9870-D5BE7D52D6DE}" />
    <EventID>4001</EventID>
    <Level>3</Level>
    <Task>0</Task>
    <Opcode>2</Opcode>
    <TimeCreated SystemTime="2013-07-25T22:09:22.230832900Z" />
    <EventRecordID>11519</EventRecordID>
    <Correlation />
    <Execution ProcessID="668" ThreadID="10236" />
  </System>
  <EventData>
  </EventData>
</Event>
Log Name:      System
Date:          26.7.2013 0:09:21
Event ID:      10002
Task Category: None
Level:         Warning
Keywords:
User:          SYSTEM
Description:
WLAN Extensibility Module has stopped.
Module Path: C:\Windows\System32\IWMSSvc.dll
Event Xml:
  <System>
    <EventID>10002</EventID>
    <Level>3</Level>
    <Task>0</Task>
    <Opcode>0</Opcode>
    <TimeCreated SystemTime="2013-07-25T22:09:21.981232500Z" />
    <EventRecordID>11518</EventRecordID>
    <Correlation />
  </System>
  <EventData>
    <Data Name="ExtensibleModulePath">C:\Windows\System32\IWMSSvc.dll</Data>
  </EventData>
</Event>
Log Name:      System
Event ID:      10002
Task Category: None
Level:         Warning
Keywords:
User:          SYSTEM
Description:
Module Path: C:\Windows\system32\RAIHV.dll
Event Xml:
  <System>
    <Level>3</Level>
    <Task>0</Task>
    <Opcode>0</Opcode>
    <TimeCreated SystemTime="2013-07-25T22:09:21.404031400Z" />
    <EventRecordID>11517</EventRecordID>
    <Correlation />
  </System>
  <EventData>
    <Data Name="ExtensibleModulePath">C:\Windows\system32\RAIHV.dll</Data>
  </EventData>
</Event>
Log Name:      System
Source:        Microsoft-Windows-DistributedCOM
Date:          26.7.2013 0:09:00
Event ID:      10010
Task Category: None
Level:         Error
Keywords:      Classic
User:          N/A
Description:
The server {F9717507-6651-4EDB-BFF7-AE615179BCCF} did not register with DCOM within the required timeout.
Event Xml:
  <System>
    <Provider Name="Microsoft-Windows-DistributedCOM" Guid="{1B562E86-B7AA-4131-BADC-B6F3A001407E}" EventSourceName="DCOM" />
    <EventID Qualifiers="49152">10010</EventID>
    <Level>2</Level>
    <Task>0</Task>
    <Opcode>0</Opcode>
    <TimeCreated SystemTime="2013-07-25T22:09:00.000000000Z" />
    <EventRecordID>11474</EventRecordID>
    <Correlation />
    <Security />
  </System>
  <EventData>
    <Data Name="param1">{F9717507-6651-4EDB-BFF7-AE615179BCCF}</Data>
  </EventData>
</Event>
E to je to. Če je kakšen mojster tukaj, ki bi mi znal svetovati.
Hvala za pomoč,
Yacked2
Korak naprej ni vedno ustrezen...sploh če si na robu prepada!
#000000 ::
Preveri Ram, disk in spucaj prah. Za prvo silo recimo, kok se pa kej greje ?
Imajo pa teli DV7 napako na neme od čipov, ne rečem da jo ima tvoj ampak veliko jo ima.
Yacked2 ::
takle je ko je prižgan skype,firefox
Priporočaš kakšne programe za disk ter ram ? Ali je dovolj da samo z kompresorjem popiham skozi ventilator, ali je potrebno še kaj odpirati ?
#000000 ::
Prvo spihaj, čeprav bi bilo najbolje odpret, samo če je še v garanciji pol to ne pride v poštev, lahko pa mirne duše menjaš disk, in rame.
Program je pa tko, memtest najdeš mislm da na ubuntu ali celo na vsakem linux dvd-ju, testirat ram v windowsih je blesavo, za disk pa pač pogledaš kater disk imaš in greš na proizvajalčevo stran ter poiščeš njihov program za diagnostiko.
Aja lahko ja tudi samo kak popravek ki mu ne paše ? probaj se spomnit kda je to začel delat in pogledaš če je kak update dobil takrat ?
Uglavnem lahko je svašta in lahko samo ugibamo.
#000000 ::
edit: aja vzameš ven eno palčko rama in udarip test, za recimo pol urce, sej če je kaj narobe s njim bo pokazalo kar hitro par minut, potem zadevo ponoviš še z drugim ramom. če pokaže errorje slikaj in prilepi sliko sem.
Yacked2 ::
Ko sem kupil računalik je bilo nekaj časa dobro, potem pa mi je to začelo delati, nato sem naredil fresh reinstall pa je bilo nekaj časa dobro, sedaj pa spet. Za disk sem pregledal kar z temu programom, ki je že na WinOS, pa ni našlo nobenih bad sectors ali pa kaj takega. Bom memtest pognal sedaj. Se pravi ga poženem za vsak ram posebej ?
Hayabusa ::
Izklopi "auto restart on error" za začetek.
http://pcsupport.about.com/od/tipstrick...
Yacked2 ::
Aha pametno, sem izklopil. BurnInTest V7.1 mi je na patriciji D našel tole napako:
Error while searching for files on optical data disk
An error occurred while searching for files on a optical data disk. This can be the result of a corrupted (Error code 1117) or blank optical disk (Error code 21).
Ker sem nisem imel CDja noter je to pač logično. Sedaj pa memtest...
Yacked2 ::
Evo...memtest je šel skozi, ni nobenih napak. Sem se spolnil da sem včeraj zjutraj ko sem prižgal računalik dobil 90B fan cooling error. Mogoče ima kakšno povezavo
Yacked2 ::
Rešeno....problem je bil pri HP power plan, ki je bil nastavljen na balance, sedaj sem prestavil na high performance in dela super =D
Igre mi zmrzujejo
121795 (1440) TheBlueOne
Težava Microsoft-Windows-Kernel-Power (strani: 1 2 )
8610260 (7270) Anney
Problem z ramom ali diskom? Prosim za nasvet.
111596 (1498) Duhec
težava z računalnikom (počasno delovanje, brenči...)
162397 (2051) legendary
Nestabilen sistem
91165 (1064) homer007
