Windows 7
Windows 7
gik1999 ::
Kupiti si nameravam nov računalnik,ki pa nima operacijskega sistema.Prijatelj mi bo posodil CD za Windows 7.
Zanima me kako se ga namesti ?
Hvala za odgovore !
...:TOMI:... ::
Po navodilih.
Tomi
gik1999 ::
Kakih navodilih ?
...:TOMI:... ::
Navodila za namestitev sistema Windows 7. Najbrž nisi mislil, da moraš prebrati in upoštevati navodila za upravljanje z gasilnim aparatom ob namestitvi sistema?
Tomi
Mr Johnny ::
To start Windows 7 from an installation disc or USB flash drive
1. Turn on your computer, insert the Windows 7 installation disc or USB flash drive, and then turn off your computer.
2. Restart your computer.
3. Press any key when prompted to do so, and then follow any instructions that appear.
4. When the Install Windows page appears, click Install now to begin the installation process or click Repair your computer to access system recovery options.
A bo šlo?!
težava inštaliranja windows 8
Oddelek: Operacijski sistemi
51348 (1193) solatko
Težave z namestitvijo sedmice na staro kišto
182629 (2376) Ozric
Windows 7 in UEFI
302781 (2446) FX6300B
problem z inštalacijo windows 7
184302 (2844) jest10
Ne predvaja novega audio CD
52616 (2572) Tea Time
