Vlada 2013
Vlada 2013
WizmoTo ::
Meni ni čisto jasno, kam se namerava izseliti s tega socialističnega raja ? Pa ja ne v kakšno neoliberalno kapitalistično državo, kjer človek ni enak človeku ? Mogoče pa je dobil dobro ponudbo s Severne Koreje ? Sicer so menda tam tudi nekateri bolj enaki kot drugi.
Mufasa ::
"Being adequate at your job is a relatively new invention - at least in the public sector. In the mid-19th century the Civil Service was stuffed full of drooling idiots put there by relatives. A parliamentary paper from 1855 refers to "the most feeble sons in families which have been so fortunate as to obtain an appointment, yes, and others too, either mentally or physically incapacitated, enter the Service". But then came the reforms of the 1870s and the revolutionary idea that to get a job you needed not only to refrain from drooling but also to know some mathematics and Latin, too."
Vir
No, očitno je slovenija še 150 let za časom. ;((
"Es ist nicht genug, zu wissen, man muss auch anwenden;
es ist nicht genug, zu wollen, man muss auch tun."
- Johann Wolfgang von Goethe
Mufasa je izjavil:
Vir
Na tem viru najdemo med ostalim tudi slednje:
3. Women
Women in offices were a late 19th-century innovation, introduced as an experiment to cope with growing workload, but became a huge hit. They were cheap, and didn’t need promoting because as soon as they got married, they left and cheaper replacements could be found. Until the first world war, “lady clerks” had separate entrances, staircases and dining rooms. They often worked behind screens and, in some cases, in cages to ensure their morals weren’t messed with.
At Barclays they were allowed on to the roof at lunchtime, where they marched around and sang the company song. There was only one perk enjoyed by lady clerks not available now: they were allowed to knit in quiet periods.
Obožujem tole ekonomistično gledanje na ljudi kot na živino in predstavljanje istega kot nekaj naprednega :|
USS Wasp ::
in dokler obstajajo v tej državi gnide, ki bi socialne transferje ukinile, dokler jih same ne potrebujejo, je morda bolje, da mene v njej ni.
socialne transferje pri nas vedno najbolj klestijo tvoji, to je t.i. levi.
http://en.wikipedia.org/wiki/USS_Wasp_%28CV-18%29
Mufasa ::
Nevem od kje tebi da je to napredno...jest pravim ravno obratno, da v slovenistanu je nenapredno. >:D
WizmoTo> Ne bo šlo v neskončnost, samo do bankrota.
Ne. Bankrot ne pomeni nič.
oldguy> Opa! Kim Yong Yipe v pravi desničarski maniri "grozi" z izselitvijo. Res presenečaš zadnje čase, hehe...
Življenje med naraščajočo količino intelektualno zavrtih egotistov ni niti izziv, niti ni posebno prijetno. Preselil se bom, jasno, med hipije.
USS Wasp> socialne transferje pri nas vedno najbolj klestijo tvoji, to je t.i. levi.
Niso niti moji, niti levi - ampak da bi to razumel, moraš najprej potegniti glavo iz riti.
  • spremenilo: jype ()
Da se ne bo spozabilo, kdo uničuje Državno RTV "zaradi Stroškov" : RTV Slovenija reže eno najbolj gledanih oddaj, pa to niso skupine socialno nečutečnih, nje...
Cervantes ::
Druga tema.
Moscas en la cabeza!
:D
PaX_MaN ::
Mr.B je izjavil:
Ja sej hočete da se iz javnega sektorja pomeče ven vse parazite.
Kaj je zdej spet problem?
Cervantes ::
BTW, tvoja vlada je sprejela sklep, da se z RTV pomeče ven vse honorarce.
Ne vem, kaj se zdaj čudiš.
Nje.
Cervantes je izjavil:
Nje.
Misliš naša vlada?
djordjevic ::
Gluposti delata obe. Kdor hvali eno, drugo pa qrca, je zaslepljen idiot. Vsaka ima (je imela) svoje genialne trenutke, a so ti, žal, tako redki kot biseri.
PaX_MaN ::
djordjevic je izjavil:
Aha, pa mamo potrditev da Janša še zmer vse vodi iz ozadja!
  • spremenilo: PaX_MaN ()
Lahko rečemo drugače : Da Javna RTV itak ni namenjena komercialnim ter ostalim vsebinam, ki bi poneumljala narod. Torej jih je potrebno ukinit.
Mislim da tako zadovoljimo vsem kriterijem, kvalitetno usmerjenih kulturnih oddaj...
PaX_MaN ::
Hej, tos ti reku.
IQ42 ::
Jaz se s tabo popoloma strinjam in vse vlade do zdaj so bile "tudi moje". In nisem jaz tisti, ki na tem forumu promovira naše : vašim. Tukaj to počnejo nekateri, ki imajo težave s tujimi jeziki.
I have learned from my mistakes
and I am sure I can repeat them exactly.
IQ42> Tukaj to počnejo nekateri, ki imajo težave s tujimi jeziki.
Ja, naši jih obvladajo!
Omg, avstrijski komunisti hočjo uničit še tist mal prostega trga kar ga je ostal: http://www.reuters.com/article/2013/07/...
Mipe ::
Naravni zakoni pač. Če prosti trg ne more obstati ob vsem tem, si pač obstoja ne zasluži.
oldguy ::
jype je izjavil:
Za razliko od naših komunistov, katerim podobnih postopkov sploh ni treba izvajat, ker imajo komplet telekom v lasti kar sami in podobne operacije oblast izvaja kar sama od sebe. Jebena zadeva, tale grdi-grdi prosti trg...namesto, da bi mirno nategovali stranke s pomočjo partijskih dekretov, kot se to dela na sončni strani alp, se morajo ubogi avstrijci zatekati k nepoštenemu lobiranju. :))
  • spremenil: oldguy ()
oldguy> Za razliko od naših komunistov
Kje mamo mi kšne komuniste? A nimamo sam neoconov pa neolibov?
Odkar je jype-jev izvoljenec Žerjev odstopil, je malo zmeden, koga voliti. Verjetno bo jeseni nekaj novih ne omadeževanih obrazov...
vostok_1 ::
jype je izjavil:
vostok_1> Po kaki logiki je bolje, če zahtevaš od posiljevalca, da te močneje nabija v rit? Razložte mi to?
Kakršnokoli posiljevanje je le desničarska blodnja. V resnici je država draga izključno zaradi neučinkovitosti, neučinkovita pa zaradi korupcije in klientelizma. Nič od tega dvojega ne more biti razlog za demontažo socialne države, ker s tem ni na noben način povezano. Moja davčna nepokorščina na noben način ne bi spremenila materialnega stanja kateregakoli od tistih, ki se s svojimi državnimi funkcijami materialno okoriščajo, bi pa povzročila, da bi se številnim prebivalcem življenje vdrlo preko socialnega minimuma - česar si jaz najmanj želim, ker je točno ta minimum tisto, kar meni omogoča, da počnem reči, ki me veselijo, hkrati pa ustvarjam veliko dodane vrednosti (ki poleg mojih igrač kupuje tudi hrano tvojim starim staršem - in jaz nisem kreten, ki bi jim želel storiti silo, tako kot nekateri objestneži tule).
vostok_1> NI pogoja, da gre tako naprej.
Neumnost. Tako bo šlo naprej v neskončnost, če _TI_ ne boš ponudil alternative. Slovenija je majhna. Tisti, ki so ponujali alternative, so že vsi razkrinkani. Vemo, da so bodisi popolnoma nesposobni, bodisi jih v resnici zanima izključno državna malha, za najboljše pa velja celo oboje hkrati. Dokler sedimo na svojih zavaljenih prašičjih zadnjicah, si vrtamo po nosu in se repenčimo po forumih, bo stanje vztrajalo.
No, jaz imam dejansko delo, sicer bi se že lotil političnega programa, ki presega okvir foruma, ampak zdaj je seveda prišlo do nove dileme - dobil sem nekaj razmeroma dobrih ponudb, ki mi vse po vrsti omogočajo domovino obesit na klin in dokler obstajajo v tej državi gnide, ki bi socialne transferje ukinile, dokler jih same ne potrebujejo, je morda bolje, da mene v njej ni. Nisem se še odločil, a če boste še naprej špilali kretene, se bom vsekakor lažje in hitreje.
No, najbrž veš, da nisem proti socialnim ustanovam. Ta naš posiljevalec nam vsaj da ljubča vsake tolko ja...to je res, ampak še vedno nas pošteno natepava v rit. Končali pa bomo na urgenci, je kr evidentno.
A ti res misliš, da je dvig davkov najboljša rešitev? Prekinit treba dodaten vnos novega denarja, pravzaprav zmanjšanje imo. Temeljita reorganizacija in preložitev dolgov na kasnejši čas, ko bi bili sposobni odplačevanja. Sedaj...koliko je to dejansko izvedljivo je pod vprašajem, je pa realna možnost IMO.
Ne bo šlo tako naprej. Nekaj težkih sprememb se bo zgodilo. Nekaj od teh bo tudi dobrih pomojem.
Na naslednjih volitvah bom vrjetno volil iste kot do sedaj ali idološko njim najbolj podobne.
Double_J ::
Če bo jype šel, pol bo propadla socialna država in bomo moral začet delat.:D
Dve šivanki...
Double_J je izjavil:
Nekako dvomim, da si ti v življenju kdaj kaj delal...razen cionistične propagande 8-)
V bistvu niti ne, ampak glede na to da trenutna vlada dela na dvojni potenci to kar je napovedoval JJ, bi rekel da nikoli niste bili proti, samo JJ-ja niste hoteli na mehki način v dupe. PA pustimo danes ZJ, bom rekel glede na odzive "protestnikov" bomo zelo kmalu videli tako kot v Angliji, blokado porna, ej potem se bodo šele Slovenci metali iz stolpnic. To bo prava formula za multikulturno zaplankanost naroda.
Cervantes ::
Ne zamerit Mr.B.-ju.
Amigo je evidentno pripadnik Cerkve katoliških Moronov, katere misionarji so po l.91 prispeli v komunistično provinco Slovenijo širit Gospodovo besedo, večina čez Južni, nekateri pa tudi čez Severni Atlantski Ocean.
Gre večinoma za potomce v WWII poraženih pripadnikov pomožnih enot SS, zato je potrebna toleranca in razumevanje.
Massacra ::
oldguy je izjavil:
jype je izjavil:
Izgube Telekoma iz prejšnjega obdobja so zasluge prvega med komunisti, Jajo Jajeca in prejšnje vodilne garniture z Dremljem na čelu? Res, ta Dremelj še ni v zaporu? V kakšnem hudem komunizmu živimo, da se tem kriminalcem ne sodi.... blah...
Aja, Planet TV, ki ga noben ne gleda je pa tud kumunističen TV. Spet ustanovljen od Jajo Jajeca, partijca i statog druga Josipa Broza! Iz Jajca!
). >:D@vostok_1
Dvig davkov je bil ukaz iz Bruslja. Kakor tudi odstranitev JJa in ZJa (no, to drugo je prišlo bolj iz Strasbourga!
  • spremenilo: Massacra ()
oldguy ::
Massacra je izjavil:
FYI, če ločuješ med levimi in desnimi komunisti in zraven vpletaš še take pojme, kot so dobiček/izguba, si nekako falil poanto...
friendbreez, sej vemo vsi grdi ukrepi so ukazi Bruselj-a in unih grdih Kapitalistov. Zato pa do danes nimajo nikakršnega efekta. Če hočeš razumeti kaj Bruselj zahteva si oglej profolijo implementiranih ukrepov s strani Bruselja, vključujoč nakup orožja, samo ti tega itak ne razumeš. Kako lahko terjajo od nas da naj špraramo, če pa smo šele 50 % zadolženi.
Massacra ::
oldguy je izjavil:
Malo moram vseeno ločiti, ker je Jajo Jajec vrhunski komunist, ki je, kot padli angel lucifer, prinesel "svetlobo" v desni, klerikalni, post domobranski in post argentinski tabor; in nato pod krinko noči izvajal vse strogo komunistične metode: ein folk, ene rase, eine partei, ein Jajo Jajec for immer und immer. In potem je začel sebi graditi/kupuvati vile, stanovanja, hiše, parcele, posestva...
Ajd, če bi kdaj kaj delal, konkretno... 22 let politike in pletenja mreže? In Rajko Janša...Ja ja, prihajajo še zanimive zgodbe...
komunistične, seveda.
vostok_1> A ti res misliš, da je dvig davkov najboljša rešitev?
Ne, je pa edina. Vsekakor je boljša rešitev, da v Postojni pristanejo vesoljci in nam pustijo tukaj napravo, ki nas naredi za energetsko velesilo evrope - ampak s tem računat morda ni najbolj pametno.
Za razliko od raznih oldguyev, ki nikoli niso znali seštevat in odštevat, meni to še vedno ne predstavlja težav, zato razumem, da lahko samo višji davki in dodatno zadolževanje zagotovijo čas, da se izvede reforme. To velja že zadnjih 20 let, reforme pa še vedno niso izvedene, ampak to je popolnoma ločen problem, ki nima nobene zveze s prvim.
jype +1
Massacra ::
Mr.B je izjavil:
Čuj, ne izponjujemo treh kriterijev maastrichtske pogodbe, ki smo jo podpisali! In zadilžujemo se preko "razumne in vzdržne meje" zadnjih 5 let!
In kaj je to v zvezi s pogoji psolvanja, kreditiranja, ukrepov, varčevanja, bla bla bla... To so NAŠI problemi, ki jih nismo v stanju rešiti. Z ministri "ups prodajalci rož", pa relano nismo sposobni.
oldguy ::
jype je izjavil:
Moja matematika takšna kot tvoja pač ne more bit, ker nimam kristalne kugle, svetniškega sija okoli glave ter presvetlega imena Kim Yong Yipe.
Zagovorniki statusa quo zgornje trosite že lep čas, reform pa še kar ni in ni, poraba se ne zmanjšuje, davki so vse višji, država pa se še vedno zadolžuje kot nora in še vedno tone. Vaše obljubljene rasti, ki bo menda te pufe pokrila, ni na spregled in je v takšni meri, jasno, tudi ne more biti, sploh pa ne pod bremenom čedalje višjih davkov. Zagovarjate pač pot Grčije, pa čeprav se tega sploh zavedate ne. Ko nekdo omeni preprosta zmanjšanja povsem nepotrebnih stroškov, skočite v zrak in v nedogled pretepate straw-mane. Edini rezultat, ki ga bo vaše naivno čakanje na reforme ob veselem podpiranju statusa quo prineslo, bo pač razgradnja socialne države in njenih institucij, ki jo menda tako ljubite.
Pozabljate pač na preprosto dejstvo, da sistemi, ki se niso sposobni prilagajat razmeram, propadajo...
oldguy> Zagovorniki statusa quo zgornje trosite že lep čas, reform pa še kar ni in ni
Dokler se ne boste znal zment o reformah, teh ne bo.
oldguy> poraba se ne zmanjšuje, davki so vse višji, država pa se še vedno zadolžuje kot nora in še vedno tone.
Ja. Še naprej se bo, vse dokler se ne boš zresnil (jaz sem seveda realist in sem prepričan, da se ne boš).
oldguy> Edini rezultat, ki ga bo vaše naivno čakanje na reforme ob veselem podpiranju statusa quo prineslo, bo pač razgradnja socialne države in njenih institucij, ki jo menda tako ljubite.
Ta razgradnja je neizogibna izključno zaradi ljudi tvojega kova.
oldguy ::
jype je izjavil:
Ne. (jest znam tut) Ta razgradnja je neizogibna izključno zaradi ljudi tvojega kova.
jype je izjavil:
Nope. Mnenja, ki jih deliš, kažejo zgolj na naivnega prepotentneža brez pametnih argumentov.
oldguy> Nope. Mnenja, ki jih deliš, kažejo zgolj na naivnega prepotentneža brez pametnih argumentov.
A lahko slišimo tvoj argument? Moj je bil že predstavljen, tvoj pa še ne.
oldguy ::
jype je izjavil:
Tvoj argument? A ono, kako nas lahko reši samo dodatno zadolževanje in višji davki, ki nam bodo kupili čas, da menda enkrat, ko se bomo čez pet let pa končno zmenili, kaj bi sploh radi, izvedemo reforme?
To ni argument, to so naivne lepe želje, ki nam že več let delajo samo škodo in še več nam je bodo. No, da se popravim, naivnost je lahko zgolj en razlog za takšna razmišljanja. Bodisi ta, ali pa odkrita pokvarjenost.
ZaphodBB ::
Vse kar se je za zmenit je kako bomo Lukšiče in Stepišnike naučil še višjo matematiko onkraj marksističnega samoupravljanja.
ZaphodBB> Vse kar se je za zmenit je kako bomo Lukšiče in Stepišnike naučil še višjo matematiko onkraj marksističnega samoupravljanja.
Ne. Oni že znajo. Naučit je treba še Šušteršiča, Janšo in ostale "vaše".
oldguy> Tvoj argument?
No dejmo, you first.
jype pa malo seka mimo :
Trenutno stanje rešuje ustrezna vlada v tej vladi oba ne igrata nikakršne vloge.
Verjetno pa je problem bolj Mencinger, ki svetuje tej vladi, pa se mu podira svet : Če bi bil sam direktor in bi videl, da mi grozi izgubiti vse, kar imam in za kar sem se trudil desetletje ali več, bi najbrž tudi sam poskušal oškodovati družbeno premoženje
Nč mim ne sekam - smo vidl link kako Šušteršič svari pred slabo banko in kako se Janša zadolžuje za milijarde.
Double_J ::
Dve šivanki...
Skratka, če bi malo manj klobasali, kako imamo "preveč družboslovcev" in malo več delali, bi bili na boljšem kot je Avstrija.
Se strinjam. Odprite podjetje, zaposlite brezposelne in zaslužite milijone.
Mipe ::
Odlična iniciativa! Ko bi le kdo ponudil začetni kapital...
Jaz ponujam pol milijona za pol firme z dobro idejo.
PaX_MaN ::
Mipe je izjavil:
Ja za prazen nič ne bo nben nč dal.
Mipe ::
Pod "dobro idejo" misliš profitabilno, ne?
Idej je dovolj, problematična je le izvedba.
137 / 279
