Forum » Programiranje » sql 08 management studio - backup select stavka
boss-tech ::
Je možno recimo v management studiu naredit select stavek, ali pa da vzameš kar celo tabelo in ti zgenerira insert stavke, ki jih potem enostavno poženeš na drugi bazi, seveda z isto tabelo. Gre pa se za sql 05
- spremenil: boss-tech ()
win64 ::
insert stavkov ti mssql managment studio ne bo naredil.
Imaš pa naslednje možnosti:
- generate script: ti generira create stavke
- copy data: ti shrani podatke v datoteko ali drugo bazo. Vrst datotek je več: excel,csv,access..
Če hočeš kopirat celotno bazo pa je najlažje narediti backup in na drugem strežniku restore.
win64 ::
pardon: sem zmeraj toliko iskal to možnost po programu, sem pa najdel po googlu takoj :)
http://stackoverflow.com/questions/5065...
Right-click the database in SSMS, select "Tasks", "Generate Scripts...". As you work through, you'll get to a "Scripting Options" section. Click on "Advanced", and in the list that pops up, where it says "Types of data to script", you've got the option to select Data and/or Schema.
nightrage ::
V 2008 R2 kamot dobiš insert stavke. Desni klik na bazo -> tasks -> generate scripts -> selectaš tabele -> advanced -> types of data to script (data only, data and schema, schema only).
| » | MS SQL Express 2008R2Oddelek: Programska oprema | 1881 (1232) | BivšiUser2 |
| » | PostgreSQL pomočOddelek: Programiranje | 3142 (2635) | Mato989 |
| » | SQL težavaOddelek: Programiranje | 6951 (6233) | joseti |
| » | SQL Server in datum nagajataOddelek: Programiranje | 2314 (2177) | dudi |
| » | XHTML reference?Oddelek: Izdelava spletišč | 2192 (2013) | darh |
