sql 08 management studio - backup select stavka
boss-tech ::
Je možno recimo v management studiu naredit select stavek, ali pa da vzameš kar celo tabelo in ti zgenerira insert stavke, ki jih potem enostavno poženeš na drugi bazi, seveda z isto tabelo. Gre pa se za sql 05
win64 ::
insert stavkov ti mssql managment studio ne bo naredil.
Imaš pa naslednje možnosti:
- generate script: ti generira create stavke
- copy data: ti shrani podatke v datoteko ali drugo bazo. Vrst datotek je več: excel,csv,access..
Če hočeš kopirat celotno bazo pa je najlažje narediti backup in na drugem strežniku restore.
win64 ::
pardon: sem zmeraj toliko iskal to možnost po programu, sem pa najdel po googlu takoj :)
Right-click the database in SSMS, select "Tasks", "Generate Scripts...". As you work through, you'll get to a "Scripting Options" section. Click on "Advanced", and in the list that pops up, where it says "Types of data to script", you've got the option to select Data and/or Schema.
http://stackoverflow.com/questions/5065...
nightrage ::
V 2008 R2 kamot dobiš insert stavke. Desni klik na bazo -> tasks -> generate scripts -> selectaš tabele -> advanced -> types of data to script (data only, data and schema, schema only).
boss-tech ::
Hvala. Ta types of data to script me je mučil :) Zdaj je šlo
MS SQL Express 2008R2
Oddelek: Programska oprema
181881 (1232) BivšiUser2
PostgreSQL pomoč
Oddelek: Programiranje
163142 (2635) Mato989
SQL težava
366951 (6233) joseti
SQL Server in datum nagajata
92314 (2177) dudi
XHTML reference?
Oddelek: Izdelava spletišč
162192 (2013) darh
