Forum » Pomoč in nasveti » Premalo rama?
Premalo rama?
miha121 ::
Pozdravljeni!
Zanima me,če je možno da mi(stričev)računalnik počasi dela,počasi odpira programe,počasi odpira spletne strani(ko dam nov zavihek)...
Sam sumim na ram,saj se je po 8 letih sigurno "zapacal"?
tu je spisek komponent.Naj povem,da je kišta stara 8let,vendar je bil za tisti čas ena a.
Saj mi še sedaj dela ls2013 na njemu.
Ter ko zašteka,mi enkrat zapiska(kratek piip pisk).
CPU-Z
Binaries
CPU-Z version 1.62.0
Processors
Number of processors 1
Number of threads 1
APICs
Processor 0
-- Core 0
-- Thread 0 0
Timers
ACPI timer 3.580 MHz
Perf timer 3.580 MHz
Sys timer 1.000 KHz
Processors Information
Processor 1 ID = 0
Number of cores 1 (max 1)
Number of threads 1 (max 1)
Name AMD Sempron 3200+
Codename Palermo
Specification AMD Sempron(tm) Processor 3200+
Package Socket 939
CPUID F.F.2
Extended CPUID F.2F
Brand ID 38
Core Stepping E6
Technology 90 nm
Core Speed 1809.3 MHz
Multiplier x FSB 9.0 x 201.0 MHz
HT Link speed 804.1 MHz
Stock frequency 1800 MHz
Instructions sets MMX (+), 3DNow! (+), SSE, SSE2, SSE3, x86-64
L1 Data cache 64 KBytes, 2-way set associative, 64-byte line size
L1 Instruction cache 64 KBytes, 2-way set associative, 64-byte line size
L2 cache 256 KBytes, 16-way set associative, 64-byte line size
FID/VID Control yes
Max FID 9.0x
VID range 1.100 V - 1.450 V
# of P-States 2
P-State FID 0x2 - VID 0x12 (5.00x - 1.100 V)
P-State FID 0xA - VID 0x06 (9.00x - 1.400 V)
K8 Thermal sensor yes
K8 Revision ID 4.2
Attached device PCI device at bus 0, device 24, function 0
Attached device PCI device at bus 0, device 24, function 1
Attached device PCI device at bus 0, device 24, function 2
Attached device PCI device at bus 0, device 24, function 3
Thread dumps
CPU Thread 0
APIC ID 0
Topology Processor ID 0, Core ID 0, Thread ID 0
Type 02002006h
Max CPUID level 00000001h
Max CPUID ext. level 80000018h
Cache descriptor Level 1, I, 64 KB, 1 thread(s)
Cache descriptor Level 1, D, 64 KB, 1 thread(s)
Cache descriptor Level 2, U, 256 KB, 1 thread(s)
CPUID
0x00000000 0x00000001 0x68747541 0x444D4163 0x69746E65
0x00000001 0x00020FF2 0x00000800 0x00000001 0x078BFBFF
0x80000000 0x80000018 0x68747541 0x444D4163 0x69746E65
0x80000001 0x00020FF2 0x00000988 0x00000001 0xE3D3FBFF
0x80000002 0x20444D41 0x706D6553 0x286E6F72 0x20296D74
0x80000003 0x636F7250 0x6F737365 0x32332072 0x002B3030
0x80000004 0x00000000 0x00000000 0x00000000 0x00000000
0x80000005 0xFF08FF08 0xFF20FF20 0x40020140 0x40020140
0x80000006 0x00000000 0x42004200 0x01008140 0x00000000
0x80000007 0x00000000 0x00000000 0x00000000 0x0000003F
0x80000008 0x00003028 0x00000000 0x00000000 0x00000000
0x80000009 0x00000000 0x00000000 0x00000000 0x00000000
0x8000000A 0x00000000 0x00000000 0x00000000 0x00000000
0x8000000B 0x00000000 0x00000000 0x00000000 0x00000000
0x8000000C 0x00000000 0x00000000 0x00000000 0x00000000
0x8000000D 0x00000000 0x00000000 0x00000000 0x00000000
0x8000000E 0x00000000 0x00000000 0x00000000 0x00000000
0x8000000F 0x00000000 0x00000000 0x00000000 0x00000000
0x80000010 0x00000000 0x00000000 0x00000000 0x00000000
0x80000011 0x00000000 0x00000000 0x00000000 0x00000000
0x80000012 0x00000000 0x00000000 0x00000000 0x00000000
0x80000013 0x00000000 0x00000000 0x00000000 0x00000000
0x80000014 0x00000000 0x00000000 0x00000000 0x00000000
0x80000015 0x00000000 0x00000000 0x00000000 0x00000000
0x80000016 0x00000000 0x00000000 0x00000000 0x00000000
0x80000017 0x00000000 0x00000000 0x00000000 0x00000000
0x80000018 0x00000000 0x00000000 0x00000000 0x00000000
MSR 0x0000001B 0x00000000 0xFEE00900
MSR 0xC0010114 0x00000000 0x00000000
MSR 0xC001001E 0x00000000 0x00000042
MSR 0xC0010015 0x00000000 0x0A000000
MSR 0xC0010042 0x12040606 0x040A0A0A
MSR 0xC0010041 0x00000000 0x00000000
Chipset
Northbridge NVIDIA nForce4 rev. A3
Southbridge NVIDIA nForce4 MCP rev. A3
Graphic Interface PCI-Express
PCI-E Link Width x16
PCI-E Max Link Width x16
Memory Type DDR
Memory Size 512 MBytes
Channels Dual
Memory Frequency 201.0 MHz (CPU/9)
CAS# latency (CL) 3.0
RAS# to CAS# delay (tRCD) 3
RAS# Precharge (tRP) 3
Cycle Time (tRAS) 8
Bank Cycle Time (tRC) 11
DRAM Idle Timer 16
Command Rate (CR) 2T
Memory SPD
DIMM # 1
SMBus address 0x50
Memory type DDR
Manufacturer (ID) Samsung (CE00000000000000)
Size 256 MBytes
Max bandwidth PC3200 (200 MHz)
Part number M3 68L3223FUN-CCC
Serial number F1036273
Manufacturing date Week 64/Year 05
Number of banks 1
Data width 64 bits
Correction None
Registered no
Buffered no
Nominal Voltage 2.50 Volts
EPP no
XMP no
AMP yes
JEDEC timings table CL-tRCD-tRP-tRAS-tRC @ frequency
JEDEC #1 2.5-3-3-7-n.a. @ 166 MHz
JEDEC #2 3.0-3-3-8-n.a. @ 200 MHz
AMP profile
Min Cycle time 1.#IO ns (0 MHz)
Max CL -2147483648.0
Min tRP 1.#J ns
Min tRCD 1.#J ns
Min tRAS 1.#J ns
Min tRFC 1.#J ns
AMP timings table CL-tRCD-tRP-tRAS-tRC @ frequency
AMP #1 -2147483648.0--1073741824--1073741824--1073741824--1073741824 @ 0 MHz
DIMM # 2
SMBus address 0x51
Memory type DDR
Size 256 MBytes
Serial number F1046254
Number of banks 1
Data width 64 bits
Correction None
Registered no
Buffered no
EPP no
XMP no
AMP yes
AMP profile
Min tRP 1.#J ns
Min tRCD 1.#J ns
Min tRAS 1.#J ns
Min tRFC 1.#J ns
DIMM # 1
SPD registers
00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F
00 80 08 07 0D 0A 01 40 00 04 50 65 00 82 08 00 01
10 0E 04 18 01 02 20 C0 60 70 00 00 3C 28 3C 28 40
20 60 60 40 40 00 00 00 00 00 37 46 28 28 50 00 00
30 00 00 00 00 00 00 00 00 00 00 00 00 00 00 10 7D
40 CE 00 00 00 00 00 00 00 02 4D 33 20 36 38 4C 33
50 32 32 33 46 55 4E 2D 43 43 43 20 4E 46 05 40 F1
60 03 62 73 00 53 57 43 30 4B 30 54 00 00 00 00 00
70 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
80 00 51 A2 70 04 00 33 33 F0 A0 30 42 00 18 1B 00
90 00 51 A2 70 04 00 33 33 F0 A0 30 42 01 19 1B 00
A0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
B0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
C0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
D0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
E0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
F0 01 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
DIMM # 2
SPD registers
60 04 62 54 00 53 57 43 30 4B 30 54 00 00 00 00 00
80 00 51 A2 72 29 00 33 33 F0 A0 30 42 01 17 1B 00
90 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
Monitoring
Mainboard Model A8NE-FM (0x000001CC - 0x0054B30D)
LPCIO
LPCIO Vendor SMSC
LPCIO Vendor ID 0x55
LPCIO Chip ID 0x77
Config Mode I/O address 0x2E
Config Mode LDN 0x8
Config Mode registers
00 00 00 00 00 00 00 00 08 00 00 00 00 00 00 00 00
10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
20 77 01 08 00 44 00 2E 00 00 00 00 00 00 00 00 00
30 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
40 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
50 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
60 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Hardware Monitors
Hardware monitor SMSC DME1737
Voltage 0 5.03 Volts [0xC1] (+5VTR)
Voltage 1 1.42 Volts [0x79] (CPU VCORE)
Voltage 2 3.40 Volts [0xC6] (ATX +3.3V)
Voltage 3 5.18 Volts [0xC7] (ATX +5V)
Voltage 4 12.36 Volts [0xC5] (ATX +12V)
Temperature 1 41°C (105°F) [0x29] (Internal)
Temperature 2 54°C (129°F) [0x36] (Diode 2)
Fan 0 1483 RPM [0xE39] (FANIN0)
Register space SMBus, base address = 0x04C00
SMBus request channel 0x0, address 0x2E
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
20 C1 79 C6 C7 C4 80 29 37 37 0E FF FF FF FF FF FF
30 39 FF FF 00 00 00 00 00 00 00 00 00 00 00 5C 89
40 05 90 40 00 00 FF 00 FF 00 FF 00 FF 00 FF 81 7F
50 81 7F 81 7F FF FF FF FF FF FF FF FF 42 42 62 CB
60 0B 0B 60 B0 39 FF 80 5A 46 46 64 64 64 44 40 00
70 39 FF FF 09 09 09 09 09 09 00 10 00 40 00 EC 18
80 7E A4 0E 00 00 30 8C 03 17 00 4D 4D 0B 0B 0D 00
90 04 04 04 04 0C 0C 0C 5A F1 C7 00 00 FF 00 FF 00
A0 00 00 0C 00 02 00 00 0B 0B FE FF FE FF FF FF FF
B0 FF 00 00 00 00 00 28 28 0E 0E 2B 2B 00 00 00 00
C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Hardware monitor ACPI
Temperature 0 40°C (103°F) [0xC3C] (THRM)
PCI Devices
Description Memory Controller
Location bus 0 (0x00), device 0 (0x00), function 0 (0x00)
Common header
Vendor ID 0x10DE
Model ID 0x005E
Revision ID 0xA3
PI 0x00
SubClass 0x80
BaseClass 0x05
Cache Line 0x00
Latency 0x00
Header 0x00
PCI header
Subvendor ID 0x1043
Subsystem ID 0x815A
Int. Line 0xFF
Int. Pin 0x00
PCI capability
Caps class HyperTransport
Caps offset 0x44
Caps revision 1.03
Interface type Slave/Primary
Link 0 width (in/out) 16 bits/16 bits
Link 0 frequency 800 MHz
Link 1 width (in/out) 8 bits/8 bits
Link 1 frequency 200 MHz
PCI capability
Caps offset 0xE0
Interface type MSI Mapping
PCI registers
00 DE 10 5E 00 06 00 B0 00 A3 00 80 05 00 00 00 00
20 00 00 00 00 00 00 00 00 00 00 00 00 43 10 5A 81
30 00 00 00 00 44 00 00 00 00 00 00 00 FF 00 00 00
40 43 10 5A 81 08 E0 E0 01 22 01 11 11 D0 00 00 00
50 23 05 7F 80 03 00 00 00 00 00 03 00 00 00 00 00
60 00 00 00 00 00 00 00 00 00 00 00 00 06 36 00 00
70 44 44 00 00 D0 09 00 00 00 00 00 00 88 00 00 00
80 13 FF 88 00 FA 00 00 00 03 00 00 00 61 00 00 00
90 0E 10 00 00 00 00 00 00 00 00 00 00 00 00 00 00
A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
B0 00 00 00 00 01 01 01 01 00 00 00 00 00 00 00 00
C0 00 00 00 00 00 00 00 00 00 00 00 00 03 00 00 00
E0 08 00 01 A8 00 00 E0 FE 00 00 00 00 00 00 00 00
Description PCI to ISA Bridge
Location bus 0 (0x00), device 1 (0x01), function 0 (0x00)
Common header
Vendor ID 0x10DE
Model ID 0x0050
Revision ID 0xA3
PI 0x00
SubClass 0x01
BaseClass 0x06
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x1043
Subsystem ID 0x815A
Int. Line 0x00
Int. Pin 0x00
PCI registers
00 DE 10 50 00 0F 00 A0 00 A3 00 01 06 00 00 80 00
40 43 10 5A 81 00 F0 FF FE FA 3E FF 00 FA 3E FF 00
50 FA 3E FF 00 00 5A 62 02 00 00 00 01 00 00 FF FF
60 01 40 00 00 01 44 00 00 01 48 00 00 00 00 F9 FF
70 10 00 FF FF C1 00 00 00 00 00 04 19 00 02 20 0D
80 09 80 00 D2 01 00 0D 00 C0 00 00 01 00 00 00 00
90 00 00 00 00 00 00 00 00 21 64 87 A9 DE BC 00 00
A0 00 00 30 81 00 00 00 00 00 00 00 00 00 00 00 00
B0 00 00 00 00 00 08 80 08 00 00 00 00 00 00 00 00
C0 35 82 80 00 00 00 00 00 00 00 00 00 00 00 00 00
E0 0C 10 01 00 00 00 D0 00 80 24 00 20 61 44 44 11
F0 5A FF 5F BF 00 00 00 C0 10 FF FF FF 00 00 30 07
Description SMBus Controller
Location bus 0 (0x00), device 1 (0x01), function 1 (0x01)
Common header
Vendor ID 0x10DE
Model ID 0x0052
Revision ID 0xA2
PI 0x00
SubClass 0x05
BaseClass 0x0C
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Address 0 (port) 0x0000E400
Address 4 (port) 0x00004C00
Address 5 (port) 0x00004C40
Subvendor ID 0x1043
Subsystem ID 0x815A
Int. Line 0x05
Int. Pin 0x01
PCI capability
Caps class Power Management
Caps offset 0x44
Caps version 1.1
PCI registers
00 DE 10 52 00 01 00 B0 00 A2 00 05 0C 00 00 80 00
10 01 E4 00 00 00 00 00 00 00 00 00 00 00 00 00 00
20 01 4C 00 00 41 4C 00 00 00 00 00 00 43 10 5A 81
30 00 00 00 00 44 00 00 00 00 00 00 00 05 01 03 01
40 43 10 5A 81 01 00 02 C0 00 00 00 00 00 00 00 00
50 01 4C 00 00 41 4C 00 00 00 00 00 00 00 00 00 00
80 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
90 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Description USB Controller (OHCI)
Location bus 0 (0x00), device 2 (0x02), function 0 (0x00)
Common header
Vendor ID 0x10DE
Model ID 0x005A
Revision ID 0xA2
PI 0x10
SubClass 0x03
BaseClass 0x0C
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Address 0 (memory) 0xC2204000
Subvendor ID 0x1043
Subsystem ID 0x815A
Int. Line 0x17
Int. Pin 0x01
PCI capability
Caps offset 0x44
Caps version 1.1
PCI registers
00 DE 10 5A 00 07 00 B0 00 A2 10 03 0C 00 00 80 00
10 00 40 20 C2 00 00 00 00 00 00 00 00 00 00 00 00
30 00 00 00 00 44 00 00 00 00 00 00 00 17 01 03 01
40 43 10 5A 81 01 00 02 FE 00 00 00 00 00 00 00 00
50 0A 00 00 00 1D 47 40 00 00 00 00 00 00 00 00 00
F0 00 00 00 00 00 00 00 00 00 FF FF FF 03 0E 30 07
Description USB 2.0 Controller (EHCI)
Location bus 0 (0x00), device 2 (0x02), function 1 (0x01)
Common header
Vendor ID 0x10DE
Model ID 0x005B
Revision ID 0xA3
PI 0x20
SubClass 0x03
BaseClass 0x0C
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Address 0 (memory) 0xC2205000
Subvendor ID 0x1043
Subsystem ID 0x815A
Int. Line 0x14
Int. Pin 0x02
PCI capability
Caps class Debug Port
Caps offset 0x44
PCI capability
Caps offset 0x80
Caps version 1.1
PCI registers
00 DE 10 5B 00 06 00 B0 00 A3 20 03 0C 00 00 80 00
10 00 50 20 C2 00 00 00 00 00 00 00 00 00 00 00 00
30 00 00 00 00 44 00 00 00 00 00 00 00 14 02 03 01
40 43 10 5A 81 0A 80 98 20 00 00 00 00 00 00 00 00
60 20 20 01 00 00 60 18 85 03 3C 3F 01 00 00 00 00
70 00 00 08 05 00 10 20 80 89 3D B6 22 77 25 64 00
80 01 00 02 FE 00 00 00 00 00 00 00 00 15 16 00 00
A0 01 00 00 00 00 00 00 C0 00 00 00 00 00 00 00 00
B0 33 00 11 22 44 00 00 00 FF 00 00 00 00 00 00 00
F0 00 00 00 00 00 00 00 00 10 FF FF FF 05 0E 30 07
Description Audio device
Location bus 0 (0x00), device 4 (0x04), function 0 (0x00)
Common header
Vendor ID 0x10DE
Model ID 0x0059
Revision ID 0xA2
PI 0x00
SubClass 0x01
BaseClass 0x04
Cache Line 0x00
Latency 0x00
Header 0x00
PCI header
Address 0 (port) 0x0000DC00
Address 1 (port) 0x0000E000
Address 2 (memory) 0xC2203000
Subvendor ID 0x1043
Subsystem ID 0x8166
Int. Line 0x15
Int. Pin 0x01
PCI capability
Caps offset 0x44
Caps version 1.1
PCI registers
00 DE 10 59 00 07 00 B0 00 A2 00 01 04 00 00 00 00
10 01 DC 00 00 01 E0 00 00 00 30 20 C2 00 00 00 00
20 00 00 00 00 00 00 00 00 00 00 00 00 43 10 66 81
30 00 00 00 00 44 00 00 00 00 00 00 00 15 01 02 05
40 43 10 66 81 01 00 02 06 00 00 00 00 06 01 00 21
F0 00 00 00 00 00 00 00 00 00 FF FF FF 04 0B 30 07
Description IDE Controller
Location bus 0 (0x00), device 6 (0x06), function 0 (0x00)
Common header
Vendor ID 0x10DE
Model ID 0x0053
Revision ID 0xF2
PI 0x8A
SubClass 0x01
BaseClass 0x01
Cache Line 0x00
Latency 0x00
Header 0x00
PCI header
Address 4 (port) 0x0000F000
Subvendor ID 0x1043
Subsystem ID 0x815A
Int. Line 0x00
Int. Pin 0x00
PCI capability
Caps offset 0x44
Caps version 1.1
PCI registers
00 DE 10 53 00 05 00 B0 00 F2 8A 01 01 00 00 00 00
20 01 F0 00 00 00 00 00 00 00 00 00 00 43 10 5A 81
30 00 00 00 00 44 00 00 00 00 00 00 00 00 00 03 01
40 43 10 5A 81 01 00 02 00 00 00 00 00 00 00 00 00
50 03 F0 01 00 00 00 00 00 20 20 20 20 66 00 20 20
60 00 C0 00 C6 00 00 00 00 00 00 00 00 00 00 00 00
80 00 00 00 00 00 C0 46 0A 00 00 C0 3B 20 24 AB 02
90 00 00 48 37 00 00 00 00 00 00 00 00 00 00 00 00
F0 00 00 00 00 00 00 00 00 10 FF FF FF 08 13 30 07
Location bus 0 (0x00), device 7 (0x07), function 0 (0x00)
Common header
Vendor ID 0x10DE
Model ID 0x0054
Revision ID 0xF3
PI 0x85
SubClass 0x01
BaseClass 0x01
Cache Line 0x00
Latency 0x00
Header 0x00
PCI header
Address 0 (port) 0x000009F0
Address 1 (port) 0x00000BF0
Address 2 (port) 0x00000970
Address 3 (port) 0x00000B70
Address 4 (port) 0x0000D800
Address 5 (memory) 0xC2202000
Subvendor ID 0x1043
Subsystem ID 0x815A
Int. Line 0x15
Int. Pin 0x01
PCI capability
Caps offset 0x44
Caps version 1.1
PCI registers
00 DE 10 54 00 07 00 B0 00 F3 85 01 01 00 00 00 00
10 F1 09 00 00 F1 0B 00 00 71 09 00 00 71 0B 00 00
20 01 D8 00 00 00 20 20 C2 00 00 00 00 43 10 5A 81
30 00 00 00 00 44 00 00 00 00 00 00 00 15 01 03 01
50 13 00 00 15 00 00 00 00 A8 20 A8 20 66 00 20 20
60 00 C0 00 C6 11 0C 00 00 08 0F 06 42 00 00 00 00
70 2C 78 C4 40 01 10 00 00 01 10 00 00 20 00 20 00
90 00 00 00 00 00 00 00 00 06 00 06 10 00 00 01 01
A0 50 01 00 00 00 00 00 00 00 00 00 00 33 BB AA 02
B0 05 CC 84 00 00 00 00 00 00 00 00 00 00 00 00 00
C0 00 00 00 00 00 00 00 00 0A 00 0A 00 08 00 02 A8
D0 01 00 02 0D 42 00 00 00 00 00 00 00 0F 00 00 00
E0 01 00 02 0D 42 00 00 00 00 00 00 00 00 00 00 00
F0 00 00 00 00 00 00 00 00 00 FF FF FF 00 00 30 07
Location bus 0 (0x00), device 8 (0x08), function 0 (0x00)
Common header
Vendor ID 0x10DE
Model ID 0x0055
Revision ID 0xF3
PI 0x85
SubClass 0x01
BaseClass 0x01
Cache Line 0x00
Latency 0x00
Header 0x00
PCI header
Address 0 (port) 0x000009E0
Address 1 (port) 0x00000BE0
Address 2 (port) 0x00000960
Address 3 (port) 0x00000B60
Address 4 (port) 0x0000C400
Address 5 (memory) 0xC2201000
Subvendor ID 0x1043
Subsystem ID 0x815A
Int. Line 0x16
Int. Pin 0x01
PCI capability
Caps offset 0x44
Caps version 1.1
PCI registers
00 DE 10 55 00 07 00 B0 00 F3 85 01 01 00 00 00 00
10 E1 09 00 00 E1 0B 00 00 61 09 00 00 61 0B 00 00
20 01 C4 00 00 00 10 20 C2 00 00 00 00 43 10 5A 81
30 00 00 00 00 44 00 00 00 00 00 00 00 16 01 03 01
D0 01 00 02 0D 42 00 00 00 00 00 00 00 08 02 30 00
E0 01 00 02 0D 42 00 00 00 00 00 00 00 01 00 F0 07
Description PCI to PCI Bridge
Location bus 0 (0x00), device 9 (0x09), function 0 (0x00)
Common header
Vendor ID 0x10DE
Model ID 0x005C
Revision ID 0xA2
PI 0x01
SubClass 0x04
BaseClass 0x06
Cache Line 0x00
Latency 0x00
Header 0x01
PCI header
Primary bus 0x00
Secondary bus 0x05
Int. Line 0x00
Int. Pin 0x00
PCI registers
00 DE 10 5C 00 07 01 A0 00 A2 01 04 06 00 00 01 00
10 00 00 00 00 00 00 00 00 00 05 05 80 F0 00 80 A2
20 F0 FF 00 00 F0 FF 00 00 00 00 00 00 00 00 00 00
30 00 00 00 00 00 00 00 00 00 00 00 00 00 00 02 02
40 00 00 07 00 01 00 02 00 07 00 00 00 00 00 44 01
50 00 00 FE 1F 00 00 00 00 FF 1F FF 1F 00 00 00 00
80 00 02 00 00 96 02 00 00 00 00 00 00 08 00 00 A8
90 00 00 E0 FE 00 00 00 00 00 00 00 00 00 00 00 00
Location bus 0 (0x00), device 11 (0x0B), function 0 (0x00)
Common header
Vendor ID 0x10DE
Model ID 0x005D
Revision ID 0xA3
PI 0x00
SubClass 0x04
BaseClass 0x06
Cache Line 0x08
Latency 0x00
Header 0x01
PCI header
Primary bus 0x00
Secondary bus 0x04
Int. Line 0x00
Int. Pin 0x00
PCI capability
Caps offset 0x40
Caps version 1.1
PCI capability
Caps class Message Signalled Interrupts
Caps offset 0x48
PCI capability
Caps offset 0x58
PCI capability
Caps class PCI Express
Caps offset 0x80
Device type Root Port of PCI-E Root Complex
Port 3
Version 1.0
Physical slot #1
Presence detect no
Link width 4x (max 2x)
Extended capabilities
Caps class Virtual Channel
Caps offset 0x100
PCI registers
00 DE 10 5D 00 07 01 10 00 A3 00 04 06 08 00 01 00
10 00 00 00 00 00 00 00 00 00 04 04 00 F1 01 00 00
20 F0 FF 00 00 F1 FF 01 00 00 00 00 00 00 00 00 00
30 00 00 00 00 40 00 00 00 00 00 00 00 00 00 06 00
40 01 48 02 F8 00 00 00 00 05 58 82 00 00 00 00 00
50 00 00 00 00 00 00 00 00 08 80 00 A8 00 00 E0 FE
80 10 00 41 01 C0 04 00 00 10 28 00 00 21 34 01 03
90 00 00 41 10 80 0C 40 00 C0 01 00 00 00 00 00 00
100 02 00 01 00 11 00 00 00 02 00 00 0A 02 00 00 00
110 00 00 00 00 FF 00 00 80 00 00 00 00 00 00 00 00
120 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00
130 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Location bus 0 (0x00), device 12 (0x0C), function 0 (0x00)
Common header
Vendor ID 0x10DE
Model ID 0x005D
Revision ID 0xA3
PI 0x00
SubClass 0x04
BaseClass 0x06
Cache Line 0x08
Latency 0x00
Header 0x01
PCI header
Primary bus 0x00
Secondary bus 0x03
Int. Line 0x00
Int. Pin 0x00
PCI capability
Caps offset 0x40
Caps version 1.1
PCI capability
Caps offset 0x48
PCI capability
Caps offset 0x58
PCI capability
Caps offset 0x80
Port 2
Version 1.0
Physical slot #0
Presence detect no
Link width 4x (max 1x)
Caps offset 0x100
PCI registers
10 00 00 00 00 00 00 00 00 00 03 03 00 F1 01 00 00
80 10 00 41 01 C0 04 00 00 10 28 00 00 11 34 01 02
90 00 00 41 10 00 05 20 00 C0 01 00 00 00 00 00 00
Location bus 0 (0x00), device 13 (0x0D), function 0 (0x00)
Common header
Vendor ID 0x10DE
Model ID 0x005D
Revision ID 0xA3
PI 0x00
SubClass 0x04
BaseClass 0x06
Cache Line 0x08
Latency 0x00
Header 0x01
PCI header
Primary bus 0x00
Secondary bus 0x02
Int. Line 0x00
Int. Pin 0x00
PCI capability
Caps offset 0x40
Caps version 1.1
PCI capability
Caps offset 0x48
PCI capability
Caps offset 0x58
PCI capability
Caps offset 0x80
Port 1
Version 1.0
Physical slot #0
Presence detect no
Link width 8x (max 1x)
Caps offset 0x100
PCI registers
10 00 00 00 00 00 00 00 00 00 02 02 00 F1 01 00 00
80 10 00 41 01 C0 04 00 00 10 28 00 00 11 34 01 01
90 00 00 81 10 00 05 10 00 C0 01 00 00 00 00 00 00
Location bus 0 (0x00), device 14 (0x0E), function 0 (0x00)
Common header
Vendor ID 0x10DE
Model ID 0x005D
Revision ID 0xA3
PI 0x00
SubClass 0x04
BaseClass 0x06
Cache Line 0x08
Latency 0x00
Header 0x01
PCI header
Primary bus 0x00
Secondary bus 0x01
Int. Line 0x00
Int. Pin 0x00
PCI capability
Caps offset 0x40
Caps version 1.1
PCI capability
Caps offset 0x48
PCI capability
Caps offset 0x58
PCI capability
Caps offset 0x80
Port 0
Version 1.0
Physical slot #0
Presence detect yes
Link width 16x (max 16x)
Caps offset 0x100
PCI registers
10 00 00 00 00 00 00 00 00 00 01 01 00 91 91 00 20
20 00 C0 F0 C1 01 B0 F1 BF 00 00 00 00 00 00 00 00
30 00 00 00 00 40 00 00 00 00 00 00 00 00 00 0A 00
80 10 00 41 01 C0 04 00 00 10 28 00 00 01 35 01 00
90 00 00 01 11 80 25 08 00 C0 01 40 00 00 00 00 00
Description Host Bridge
Location bus 0 (0x00), device 24 (0x18), function 0 (0x00)
Common header
Vendor ID 0x1022
Model ID 0x1100
Revision ID 0x00
PI 0x00
SubClass 0x00
BaseClass 0x06
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x0000
Subsystem ID 0x0000
Int. Line 0x00
Int. Pin 0x00
PCI capability
Caps offset 0x80
Caps revision 1.02
Interface type Host/Secondary
Device number 0
PCI registers
00 22 10 00 11 00 00 10 00 00 00 00 06 00 00 80 00
20 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
30 00 00 00 00 80 00 00 00 00 00 00 00 00 00 00 00
40 01 01 01 00 01 01 01 00 01 01 01 00 01 01 01 00
50 01 01 01 00 01 01 01 00 01 01 01 00 01 01 01 00
60 00 00 00 00 E4 00 00 00 0F CC 00 0F 0C 00 00 00
80 08 00 01 21 20 00 11 11 22 05 35 80 02 00 00 00
90 69 01 61 01 00 00 FF 00 07 00 00 00 00 00 00 00
Location bus 0 (0x00), device 24 (0x18), function 1 (0x01)
Common header
Vendor ID 0x1022
Model ID 0x1101
Revision ID 0x00
PI 0x00
SubClass 0x00
BaseClass 0x06
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x0000
Subsystem ID 0x0000
Int. Line 0x00
Int. Pin 0x00
PCI registers
00 22 10 01 11 00 00 00 00 00 00 00 06 00 00 80 00
40 03 00 00 00 00 00 1F 00 00 00 00 00 01 00 00 00
50 00 00 00 00 02 00 00 00 00 00 00 00 03 00 00 00
60 00 00 00 00 04 00 00 00 00 00 00 00 05 00 00 00
70 00 00 00 00 06 00 00 00 00 00 00 00 07 00 00 00
80 03 00 E0 00 80 FF EF 00 00 00 00 00 00 00 00 00
B0 03 0A 00 00 00 0B 00 00 03 00 20 00 00 D3 FE 00
C0 00 00 00 00 00 00 00 00 13 10 00 00 00 F0 0F 00
E0 03 00 00 FF 00 00 00 00 00 00 00 00 00 00 00 00
Location bus 0 (0x00), device 24 (0x18), function 2 (0x02)
Common header
Vendor ID 0x1022
Model ID 0x1102
Revision ID 0x00
PI 0x00
SubClass 0x00
BaseClass 0x06
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x0000
Subsystem ID 0x0000
Int. Line 0x00
Int. Pin 0x00
PCI registers
00 22 10 02 11 00 00 00 00 00 00 00 06 00 00 80 00
40 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
60 00 FE E0 01 00 00 00 00 00 00 00 00 00 00 00 00
80 04 00 00 00 00 00 00 00 42 35 82 13 41 0B 00 00
90 80 8E 05 38 07 07 7B 3E 00 00 00 00 00 00 00 00
B0 F7 9F 93 AB 2D 00 00 00 E5 FD 88 20 E1 F3 6D 1B
C0 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00
D0 05 08 82 12 03 E4 00 62 E6 AA AD 0D B4 B3 73 80
E0 7C CE 50 30 08 61 00 B0 27 A3 A7 0F 40 4D 18 81
Location bus 0 (0x00), device 24 (0x18), function 3 (0x03)
Common header
Vendor ID 0x1022
Model ID 0x1103
Revision ID 0x00
PI 0x00
SubClass 0x00
BaseClass 0x06
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x0000
Subsystem ID 0x0000
Int. Line 0x00
Int. Pin 0x00
PCI registers
00 22 10 03 11 00 00 00 00 00 00 00 06 00 00 80 00
40 FF 3B 00 00 40 00 00 00 00 00 00 00 00 00 00 00
50 10 3B 3D 7F EE 00 00 00 00 00 00 00 00 00 17 00
70 11 01 02 51 11 80 00 50 00 38 00 08 1B 22 00 00
80 00 00 07 23 13 21 13 21 00 00 00 00 00 00 00 00
90 00 00 00 00 CC 00 00 00 20 20 09 10 00 00 00 00
B0 00 00 00 00 00 00 00 00 3F 00 00 00 00 00 00 00
D0 00 00 00 00 01 A7 0D 00 00 00 00 00 00 00 00 00
E0 00 00 00 00 20 14 54 14 19 05 00 00 00 00 00 00
Description VGA Controller
Location bus 1 (0x01), device 0 (0x00), function 0 (0x00)
Common header
Vendor ID 0x1002
Model ID 0x5B62
Revision ID 0x00
PI 0x00
SubClass 0x00
BaseClass 0x03
Cache Line 0x08
Latency 0x00
Header 0x80
PCI header
Address 0 (memory) 0xB0000000
Address 1 (port) 0x00009000
Address 2 (memory) 0xC1000000
Subvendor ID 0x1458
Subsystem ID 0x2102
Int. Line 0x12
Int. Pin 0x01
PCI capability
Caps offset 0x50
Caps version 1.1
PCI capability
Caps offset 0x58
Device type PCI-E Endpoint Device
Port 0
Version 1.0
PCI capability
Caps offset 0x80
Caps class Advanced Error Reporting
Caps offset 0x100
PCI registers
00 02 10 62 5B 07 00 10 00 00 00 00 03 08 00 80 00
10 08 00 00 B0 01 90 00 00 00 00 00 C1 00 00 00 00
20 00 00 00 00 00 00 00 00 00 00 00 00 58 14 02 21
30 00 00 00 00 50 00 00 00 00 00 00 00 12 01 00 00
40 00 00 00 00 00 00 00 00 00 00 00 00 58 14 02 21
50 01 58 02 06 00 00 00 00 10 80 01 00 60 02 2C 01
60 10 09 00 00 01 1D 00 00 00 00 01 11 00 00 00 00
80 05 00 80 00 00 00 00 00 00 00 00 00 00 00 00 00
100 01 00 01 00 00 00 00 00 00 00 00 00 11 20 06 00
110 00 00 00 00 00 00 00 00 00 00 00 00 01 00 00 04
120 0F 00 70 00 3C 00 07 01 39 AD 1C 6F 00 00 00 00
Description Display Controller
Location bus 1 (0x01), device 0 (0x00), function 1 (0x01)
Common header
Vendor ID 0x1002
Model ID 0x5B72
Revision ID 0x00
PI 0x00
SubClass 0x80
BaseClass 0x03
Cache Line 0x08
Latency 0x00
Header 0x00
PCI header
Address 0 (memory) 0xC1FF0000
Subvendor ID 0x1458
Subsystem ID 0x2103
Int. Line 0xFF
Int. Pin 0x00
PCI capability
Caps offset 0x50
Caps version 1.1
PCI capability
Caps offset 0x58
Port 0
Version 1.0
PCI registers
00 02 10 72 5B 07 00 10 00 00 00 80 03 08 00 00 00
10 00 00 FF C1 00 00 00 00 00 00 00 00 00 00 00 00
20 00 00 00 00 00 00 00 00 00 00 00 00 58 14 03 21
30 00 00 00 00 50 00 00 00 00 00 00 00 FF 00 00 00
50 01 58 02 06 00 00 00 00 10 00 01 00 40 02 00 00
60 00 00 00 00 01 1D 00 00 00 00 01 11 00 00 00 00
100 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
110 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
120 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Description BaseClass 0x30, SubClass 0x44, PI 0x11
Location bus 5 (0x05), device 2 (0x02), function 0 (0x00)
Common header
Vendor ID 0x0000
Model ID 0x0000
Revision ID 0x0E
PI 0x11
SubClass 0x44
BaseClass 0x30
Cache Line 0x0F
Latency 0x00
Header 0x10
PCI registers
00 00 00 00 00 07 00 10 82 0E 11 44 30 0F 00 10 82
10 00 00 10 C2 01 A4 00 00 08 00 10 C2 09 A4 00 00
20 00 00 00 00 00 00 00 00 08 00 00 00 08 00 00 00
30 00 00 00 00 10 00 00 00 08 00 00 00 18 00 00 00
40 40 00 00 00 47 00 10 82 4E 11 44 30 4F 00 10 82
50 40 00 10 C2 41 A4 00 00 48 00 10 C2 49 A4 00 00
60 40 00 00 00 40 00 00 00 48 00 00 00 48 00 00 00
70 40 00 00 00 50 00 00 00 48 00 00 00 58 00 00 00
80 00 00 00 00 00 00 00 00 08 00 00 00 08 00 00 00
90 00 00 00 00 00 00 00 00 08 00 00 00 08 00 00 00
A0 00 00 00 00 00 00 00 00 08 00 00 00 08 00 00 00
B0 00 00 00 00 00 00 00 00 08 00 00 00 08 00 00 00
C0 40 00 00 00 40 00 00 00 48 00 00 00 48 00 00 00
D0 40 00 00 00 40 00 00 00 48 00 00 00 48 00 00 00
E0 40 00 00 00 40 00 00 00 48 00 00 00 48 00 00 00
F0 40 00 00 00 40 00 00 00 48 00 00 00 48 00 00 00
DMI
DMI BIOS
vendor Phoenix Technologies, LTD
version FUJITSU SIEMENS A8NE-FM 1009
date 09/15/2005
ROM size 512 KB
DMI System Information
manufacturer FUJITSU SIEMENS
product AxxE-FM
version 1.XX
serial 1xxxxxxxxxxxx
UUID {11111111-1111-1111-1111-111111111111}
DMI Baseboard
vendor ASUSTek Computer INC.
model A8NE-FM
revision 1.00
serial xxxxxxxxxx
DMI System Enclosure
manufacturer Chassis Manufacture
chassis type Desktop
chassis serial EVAL
DMI Processor
manufacturer AMD
model AMD Sempron(tm) Processor 3200+
clock speed 1800.0 MHz
FSB speed 200.0 MHz
multiplier 9.0x
DMI Processor
manufacturer unknown
model unknown
DMI BIOS
vendor unknown
version unknown
date unknown
ROM size 256 KB
DMI Memory Controller
correction 64-bit ECC
Max module size 1024 MBytes
DMI Memory Module
designation A0
size 256 MBytes (single bank)
DMI Memory Module
designation A1
DMI Memory Module
designation A2
DMI Memory Module
designation A3
DMI Port Connector
designation PRIMARY IDE (internal)
connector On Board IDE
DMI Port Connector
designation SECONDARY IDE (internal)
DMI Port Connector
designation FDD (internal)
port type 8251 FIFO Compatible
connector On Board Floppy
DMI Port Connector
designation COM1 (internal)
port type Serial Port 16450
connector 9 Pin Dual Inline (pin 10 cut)
connector DB-9 male
DMI Port Connector
designation LPT1 (internal)
port type Parallel Port ECP/EPP
connector DB-25 female
DMI Port Connector
designation PS/2 Keyboard (internal)
port type Keyboard Port
connector PS/2
connector PS/2
DMI Port Connector
designation PS/2 Mouse (internal)
port type Mouse Port
connector PS/2
connector PS/2
DMI Port Connector
designation USB1 (external)
port type USB
DMI Port Connector
designation USB2 (external)
port type USB
DMI Port Connector
designation USB3 (external)
port type USB
DMI Port Connector
designation USB4 (external)
port type USB
DMI Port Connector
designation USB5 (external)
port type USB
DMI Port Connector
designation USB6 (external)
port type USB
DMI Port Connector
designation USB7 (external)
port type USB
DMI Port Connector
designation USB8 (external)
port type USB
DMI Extension Slot
designation PCI1
type PCI
width 32 bits
populated no
DMI Extension Slot
designation PCI2
type PCI
width 32 bits
populated no
DMI Extension Slot
designation PCI3
type PCI
width 32 bits
populated no
DMI Extension Slot
designation PCIEX16
type A5
populated yes
DMI Physical Memory Array
location Motherboard
usage System Memory
correction None
max capacity 4096 MBytes
max# of devices 4
DMI Memory Device
designation A0
format DIMM
type unknown
total width 64 bits
data width 64 bits
size 256 MBytes
DMI Memory Device
designation A1
format DIMM
type unknown
total width 64 bits
data width 64 bits
size 256 MBytes
DMI Memory Device
designation A2
format DIMM
type unknown
total width 64 bits
data width 64 bits
DMI Memory Device
designation A3
format DIMM
type unknown
total width 64 bits
data width 64 bits
Graphics
Number of adapters 2
Graphic APIs
API ATI I/O
Display Adapters
Display adapter 0
Name RADEON X600 Series
PCI device bus 1 (0x1), device 0 (0x0), function 0 (0x0)
Vendor ID 0x1002 (0x1458)
Model ID 0x5B62 (0x2102)
Performance Level 0
Display adapter 1
Name RADEON X600 Series Secondary
PCI device bus 1 (0x1), device 0 (0x0), function 1 (0x1)
Model ID 0x5B72 (0x2103)
Performance Level 0
Software
Windows Version Microsoft Windows XP Media Center Edition Professional Service Pack 2 (Build 2600)
DirectX Version 9.0c
CPU-Z
Binaries
Processors
Number of threads 1
APICs
Processor 0
-- Core 0
-- Thread 0 0
Timers
Sys timer 1.000 KHz
Processor 1 ID = 0
Codename Palermo
Package Socket 939
CPUID F.F.2
Extended CPUID F.2F
Brand ID 38
Core Stepping E6
Technology 90 nm
FID/VID Control yes
Max FID 9.0x
# of P-States 2
K8 Revision ID 4.2
Thread dumps
CPU Thread 0
APIC ID 0
Type 02002006h
CPUID
Chipset
Memory Type DDR
Channels Dual
Cycle Time (tRAS) 8
DRAM Idle Timer 16
Memory SPD
DIMM # 1
SMBus address 0x50
Memory type DDR
Size 256 MBytes
Number of banks 1
Data width 64 bits
Correction None
Registered no
Buffered no
EPP no
XMP no
AMP yes
AMP profile
Min tRP 1.#J ns
Min tRCD 1.#J ns
Min tRAS 1.#J ns
Min tRFC 1.#J ns
DIMM # 2
SMBus address 0x51
Memory type DDR
Size 256 MBytes
Number of banks 1
Data width 64 bits
Correction None
Registered no
Buffered no
EPP no
XMP no
AMP yes
AMP profile
Min tRP 1.#J ns
Min tRCD 1.#J ns
Min tRAS 1.#J ns
Min tRFC 1.#J ns
DIMM # 1
SPD registers
DIMM # 2
SPD registers
Monitoring
LPCIO
LPCIO Vendor SMSC
LPCIO Chip ID 0x77
Config Mode LDN 0x8
Hardware Monitors
PCI Devices
Common header
Vendor ID 0x10DE
Model ID 0x005E
Revision ID 0xA3
PI 0x00
SubClass 0x80
BaseClass 0x05
Cache Line 0x00
Latency 0x00
Header 0x00
PCI header
Subvendor ID 0x1043
Subsystem ID 0x815A
Int. Line 0xFF
Int. Pin 0x00
PCI capability
Caps offset 0x44
Caps revision 1.03
PCI capability
Caps offset 0xE0
PCI registers
Common header
Vendor ID 0x10DE
Model ID 0x0050
Revision ID 0xA3
PI 0x00
SubClass 0x01
BaseClass 0x06
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x1043
Subsystem ID 0x815A
Int. Line 0x00
Int. Pin 0x00
PCI registers
Common header
Vendor ID 0x10DE
Model ID 0x0052
Revision ID 0xA2
PI 0x00
SubClass 0x05
BaseClass 0x0C
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x1043
Subsystem ID 0x815A
Int. Line 0x05
Int. Pin 0x01
PCI capability
Caps offset 0x44
Caps version 1.1
PCI registers
Common header
Vendor ID 0x10DE
Model ID 0x005A
Revision ID 0xA2
PI 0x10
SubClass 0x03
BaseClass 0x0C
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x1043
Subsystem ID 0x815A
Int. Line 0x17
Int. Pin 0x01
PCI capability
Caps offset 0x44
Caps version 1.1
PCI registers
Common header
Vendor ID 0x10DE
Model ID 0x005B
Revision ID 0xA3
PI 0x20
SubClass 0x03
BaseClass 0x0C
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x1043
Subsystem ID 0x815A
Int. Line 0x14
Int. Pin 0x02
PCI capability
Caps offset 0x44
PCI capability
Caps offset 0x80
Caps version 1.1
PCI registers
Common header
Vendor ID 0x10DE
Model ID 0x0059
Revision ID 0xA2
PI 0x00
SubClass 0x01
BaseClass 0x04
Cache Line 0x00
Latency 0x00
Header 0x00
PCI header
Subvendor ID 0x1043
Subsystem ID 0x8166
Int. Line 0x15
Int. Pin 0x01
PCI capability
Caps offset 0x44
Caps version 1.1
PCI registers
Common header
Vendor ID 0x10DE
Model ID 0x0053
Revision ID 0xF2
PI 0x8A
SubClass 0x01
BaseClass 0x01
Cache Line 0x00
Latency 0x00
Header 0x00
PCI header
Subvendor ID 0x1043
Subsystem ID 0x815A
Int. Line 0x00
Int. Pin 0x00
PCI capability
Caps offset 0x44
Caps version 1.1
PCI registers
Common header
Vendor ID 0x10DE
Model ID 0x0054
Revision ID 0xF3
PI 0x85
SubClass 0x01
BaseClass 0x01
Cache Line 0x00
Latency 0x00
Header 0x00
PCI header
Subvendor ID 0x1043
Subsystem ID 0x815A
Int. Line 0x15
Int. Pin 0x01
PCI capability
Caps offset 0x44
Caps version 1.1
PCI registers
Common header
Vendor ID 0x10DE
Model ID 0x0055
Revision ID 0xF3
PI 0x85
SubClass 0x01
BaseClass 0x01
Cache Line 0x00
Latency 0x00
Header 0x00
PCI header
Subvendor ID 0x1043
Subsystem ID 0x815A
Int. Line 0x16
Int. Pin 0x01
PCI capability
Caps offset 0x44
Caps version 1.1
PCI registers
Common header
Vendor ID 0x10DE
Model ID 0x005C
Revision ID 0xA2
PI 0x01
SubClass 0x04
BaseClass 0x06
Cache Line 0x00
Latency 0x00
Header 0x01
PCI header
Primary bus 0x00
Secondary bus 0x05
Int. Line 0x00
Int. Pin 0x00
PCI registers
Common header
Vendor ID 0x10DE
Model ID 0x005D
Revision ID 0xA3
PI 0x00
SubClass 0x04
BaseClass 0x06
Cache Line 0x08
Latency 0x00
Header 0x01
PCI header
Primary bus 0x00
Secondary bus 0x04
Int. Line 0x00
Int. Pin 0x00
PCI capability
Caps offset 0x40
Caps version 1.1
PCI capability
Caps offset 0x48
PCI capability
Caps offset 0x58
PCI capability
Caps offset 0x80
Port 3
Version 1.0
Physical slot #1
Presence detect no
Caps offset 0x100
PCI registers
Common header
Vendor ID 0x10DE
Model ID 0x005D
Revision ID 0xA3
PI 0x00
SubClass 0x04
BaseClass 0x06
Cache Line 0x08
Latency 0x00
Header 0x01
PCI header
Primary bus 0x00
Secondary bus 0x03
Int. Line 0x00
Int. Pin 0x00
PCI capability
Caps offset 0x40
Caps version 1.1
PCI capability
Caps offset 0x48
PCI capability
Caps offset 0x58
PCI capability
Caps offset 0x80
Port 2
Version 1.0
Physical slot #0
Presence detect no
Caps offset 0x100
PCI registers
Common header
Vendor ID 0x10DE
Model ID 0x005D
Revision ID 0xA3
PI 0x00
SubClass 0x04
BaseClass 0x06
Cache Line 0x08
Latency 0x00
Header 0x01
PCI header
Primary bus 0x00
Secondary bus 0x02
Int. Line 0x00
Int. Pin 0x00
PCI capability
Caps offset 0x40
Caps version 1.1
PCI capability
Caps offset 0x48
PCI capability
Caps offset 0x58
PCI capability
Caps offset 0x80
Port 1
Version 1.0
Physical slot #0
Presence detect no
Caps offset 0x100
PCI registers
Common header
Vendor ID 0x10DE
Model ID 0x005D
Revision ID 0xA3
PI 0x00
SubClass 0x04
BaseClass 0x06
Cache Line 0x08
Latency 0x00
Header 0x01
PCI header
Primary bus 0x00
Secondary bus 0x01
Int. Line 0x00
Int. Pin 0x00
PCI capability
Caps offset 0x40
Caps version 1.1
PCI capability
Caps offset 0x48
PCI capability
Caps offset 0x58
PCI capability
Caps offset 0x80
Port 0
Version 1.0
Physical slot #0
Presence detect yes
Caps offset 0x100
PCI registers
Common header
Vendor ID 0x1022
Model ID 0x1100
Revision ID 0x00
PI 0x00
SubClass 0x00
BaseClass 0x06
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x0000
Subsystem ID 0x0000
Int. Line 0x00
Int. Pin 0x00
PCI capability
Caps offset 0x80
Caps revision 1.02
Device number 0
PCI registers
Common header
Vendor ID 0x1022
Model ID 0x1101
Revision ID 0x00
PI 0x00
SubClass 0x00
BaseClass 0x06
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x0000
Subsystem ID 0x0000
Int. Line 0x00
Int. Pin 0x00
PCI registers
Common header
Vendor ID 0x1022
Model ID 0x1102
Revision ID 0x00
PI 0x00
SubClass 0x00
BaseClass 0x06
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x0000
Subsystem ID 0x0000
Int. Line 0x00
Int. Pin 0x00
PCI registers
Common header
Vendor ID 0x1022
Model ID 0x1103
Revision ID 0x00
PI 0x00
SubClass 0x00
BaseClass 0x06
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x0000
Subsystem ID 0x0000
Int. Line 0x00
Int. Pin 0x00
PCI registers
Common header
Vendor ID 0x1002
Model ID 0x5B62
Revision ID 0x00
PI 0x00
SubClass 0x00
BaseClass 0x03
Cache Line 0x08
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x1458
Subsystem ID 0x2102
Int. Line 0x12
Int. Pin 0x01
PCI capability
Caps offset 0x50
Caps version 1.1
PCI capability
Caps offset 0x58
Port 0
Version 1.0
PCI capability
Caps offset 0x80
Caps offset 0x100
PCI registers
Common header
Vendor ID 0x1002
Model ID 0x5B72
Revision ID 0x00
PI 0x00
SubClass 0x80
BaseClass 0x03
Cache Line 0x08
Latency 0x00
Header 0x00
PCI header
Subvendor ID 0x1458
Subsystem ID 0x2103
Int. Line 0xFF
Int. Pin 0x00
PCI capability
Caps offset 0x50
Caps version 1.1
PCI capability
Caps offset 0x58
Port 0
Version 1.0
PCI registers
Common header
Vendor ID 0x0000
Model ID 0x0000
Revision ID 0x0E
PI 0x11
SubClass 0x44
BaseClass 0x30
Cache Line 0x0F
Latency 0x00
Header 0x10
PCI registers
DMI
DMI BIOS
date 09/15/2005
ROM size 512 KB
product AxxE-FM
version 1.XX
DMI Baseboard
model A8NE-FM
revision 1.00
serial xxxxxxxxxx
chassis serial EVAL
DMI Processor
manufacturer AMD
FSB speed 200.0 MHz
multiplier 9.0x
DMI Processor
model unknown
DMI BIOS
vendor unknown
version unknown
date unknown
ROM size 256 KB
DMI Memory Module
designation A0
DMI Memory Module
designation A1
DMI Memory Module
designation A2
DMI Memory Module
designation A3
DMI Port Connector
DMI Port Connector
DMI Port Connector
DMI Port Connector
connector DB-9 male
DMI Port Connector
DMI Port Connector
connector PS/2
connector PS/2
DMI Port Connector
connector PS/2
connector PS/2
DMI Port Connector
port type USB
DMI Port Connector
port type USB
DMI Port Connector
port type USB
DMI Port Connector
port type USB
DMI Port Connector
port type USB
DMI Port Connector
port type USB
DMI Port Connector
port type USB
DMI Port Connector
port type USB
DMI Extension Slot
designation PCI1
type PCI
width 32 bits
populated no
DMI Extension Slot
designation PCI2
type PCI
width 32 bits
populated no
DMI Extension Slot
designation PCI3
type PCI
width 32 bits
populated no
DMI Extension Slot
designation PCIEX16
type A5
populated yes
usage System Memory
correction None
max# of devices 4
DMI Memory Device
designation A0
format DIMM
type unknown
total width 64 bits
data width 64 bits
size 256 MBytes
DMI Memory Device
designation A1
format DIMM
type unknown
total width 64 bits
data width 64 bits
size 256 MBytes
DMI Memory Device
designation A2
format DIMM
type unknown
total width 64 bits
data width 64 bits
DMI Memory Device
designation A3
format DIMM
type unknown
total width 64 bits
data width 64 bits
Graphics
Graphic APIs
API ATI I/O
Display Adapters
Display adapter 0
Performance Level 0
Display adapter 1
Performance Level 0
Software
karkoli nadgrajevat na tem sistemu nima smisla.. Največ kar lahko nardiš je da formatiraš zadevo in namestiš kak chrome ali firefox optimiziran za ta proc.. (SSE3)
| » | dolžina ethernet paketaOddelek: Omrežja in internet | 6611 (6142) | AndrejO |
| » | BSOD me spravlja v obupOddelek: Strojna oprema | 2345 (1817) | rsroki |
| » | BSOD problemOddelek: Pomoč in nasveti | 2248 (1906) | Oktan |
| » | navijanje dellaOddelek: Navijanje | 1579 (1471) | MecH |
| » | ebtables+linux+brctl+siol-tvOddelek: Omrežja in internet | 2793 (2645) | korenje_ver2 |
