Forum » Programiranje » Getcontent iz write-only streama
nuclear ::
Nekaj se igram doma, in uporabljam to metodo za pridobivanje vsebine iz streama(urla):
Vendar sem ugotovil, da je stream dejansko write-only, kar mi navrže napako pri debugu:
Pozna kdo morda kakšen workaround kako pridobiti vsebino streama, če je write-only.. ?
thx
private string getContent(string url)
string buffer;
try
string target = string.Empty;
HttpWebRequest httpWebRequest = (HttpWebRequest)WebRequest.Create(url);
HttpWebResponse response = (HttpWebResponse)httpWebRequest.GetResponse();
try
StreamReader streamReader = new StreamReader(response.GetResponseStream(), true);
try
buffer = streamReader.ReadToEnd();
finally
streamReader.Close();
finally
response.Close();
catch (Exception exp)
buffer = "Error: " + exp.Message.ToString();
return (buffer);
}Vendar sem ugotovil, da je stream dejansko write-only, kar mi navrže napako pri debugu:
Length = 'stream.Length' threw an exception of type 'System.NotSupportedException'
Position= 'stream.Position' threw an exception of type 'System.NotSupportedException'
thx
Spura ::
Aja zdele vidm da sm mal blentav ze od delanja server sidea kjer v response pises....ti imas klienta, ki bere response od requesta k si ga naredu. Najverjetneje ni problem da je stream write only ampak to, da response stream ne podpira Position in Length in ti klices ReadFully, kar najbrz hoce vedet kok velik buffer mora alocirat.
| » | [C# asp.NET web forma] Kam zgine cookie oz. zkj se izbriše?Oddelek: Programiranje | 1477 (1291) | Morenov |
| » | ASP.NET + C# vprašanjeOddelek: Programiranje | 3321 (2335) | Morenov |
| » | Avtomatično prepoznati POST spremenljivkeOddelek: Programiranje | 1925 (1718) | AnonimkeOP |
| » | kaj zna c#Oddelek: Programiranje | 2090 (1902) | snow |
| » | Kako z VS.NET priti do izvorne kode neke html strani?Oddelek: Programiranje | 1696 (1491) | Microsoft |
