Deep freeze vprašanje
dynr la ::
oj,
a se da z Deep Freeze zamrznit samo določene mape al lahko samo diske?? Jst bi recimo zamrznu cel C: z izjemo mape od antivirusnika, zato, da bi se lahko normalno posodabljal brez da bi moral skos unfreezat da se posodobi.
Hvala
  • spremenilo: dynr la ()
Cold1 ::
Stvaritelji Globokega Zamrzovanja, so si zamislili tudi tale dodatek:
Data Igloo Standard
http://www.faronics.com/en-uk/document-...
Faronics Data Igloo allows Deep Freeze users to exempt specified data folders, entire user profiles, or even registry keys from being Frozen by redirecting them to a Thawed partition (or ThawSpace), while keeping the operating system partition completely protected.
Data Igloo allows users to retain vital data across restarts on a Frozen workstation. Since this data is stored in a Thawed partition, the operating system is still on a Frozen partition and remains fully protected. Retained data can include, user created files, documents, settings, favorites, AV Updates or even entire user profiles. You also have the option to migrate security permissions for profiles or folders, if desired.
dynr la ::
Tnx. Sam še to mi povej, a moram potem najprej Deep Freeze naložćit in potem Igloo al kako je s tem?
MIHAc27 ::
Igloo ne poznam, vem pa da deep freezu v osnovi lahko določiš, da zamrzne samo določene črke pogonov. Zamrzneš C, na D pa poinštaliraš Antivirus
Deep freeze-a ne morem odmrzniti
51395 (1092) MIHAc27
deep freeze - pomoč
Oddelek: Programska oprema
101482 (1169) Voluharr
kako zakleniti računalnik pred nalaganjem
154623 (4262) bajsibajsi
Deepfreez in radix
Oddelek: Šola
142591 (2459) paliskic
Kako v Win2k premakniti mapo Documents and Settings?
Oddelek: Operacijski sistemi
62506 (2472) Mercier
