Forum » Navijanje » Blender Render Benchmark v0.2
fr4nc ::
XeonAdvanced ::
Posodobitev lestvice:
1. Shark-357 | 3. 63 s | Intel Core i7 3960x @ 4400 MHz | ddr3@ 1600 Mhz|
2. Moonman | 4. 22 s | Intel Core i7 3770K @ 4800 MHz | ddr3@ 2133 Mhz|
3. minimus | 4. 76 s | Intel Core i7 2700K @ ? MHz | ddr3 @ ? Mhz |
4. fr4nc | 5.40 s | 8T | AMD FX-8120 @ 4830MHz / Gigabyte 990FXA-UD3 / G.Skill 1866MHz
5. freesty | 5. 78 s | Intel Core i5 2500K @ 4500 MHz | ddr3 1600 |
6. fr4nc | 7.30 s | 8T | AMD FX-8120 (stock) / Gigabyte 990FXA-UD3 / G.Skill 1866MHz
7. Pro_moted | 8. 01 s | AMD FX 8120 @ ? MHz | ddr3@ ?|
8. stock | 8. 9 s | Intel Core i7 920 @ 2800 MHz | ddr3 @ ? |
9. Assass1n | 9. 72 s | Intel Core i5 750 @ 3800 MHz | ddr3@ 1600 Mhz|
10. dragana | 10. 32 s | Athlon II 64 @ 3000 MHz | ddr3@ Mhz|
11. TechBeats | 10. 72 s | Intel Core2Quad 9450 @ 3520 MHz | ddr2 @ 1056 Mhz |
12. rb750 | 10. 76 s | Intel Q9550 @ ? MHz | ddr2@ ?|
13. XeonAdvanced | 12.43 s | 2× Intel Xeon E5320 (stock) | 4×1GB ECC Registered FB-DIMM @667MHz (stock)
14. MacGyver141 | 13. 77 s | AMD Phenom II X4 955 @ 3146 MHz | ddr2@ 788 Mhz|
15. matonson | 15. 97 s | Intel Core i7 620 @ 2800 MHz | ddr3 @ ? |
16. SplitCookie | 20. 47 s | Intel Core i3 2350M @ stock MHz | ddr3@ ?|
17. XeonAdvanced | 24. 60 s | Intel Xeon 5120 @ ? MHz | ddr3@ ?|
18. fr4nc | 29.27 s | 1T | AMD FX-8120 @ 4830MHz / Gigabyte 990FXA-UD3 / G.Skill 1866MHz
19. fr4nc | 36.03s | 1T | AMD FX-8120 (stock) / Gigabyte 990FXA-UD3 / G.Skill 1866MHz
20. rb750 | 44. 17 s | Intel Core2Duo M @ ? MHz | ddr2@ ?|
21. XeonAdvanced | 44. 70 s | Intel Core2Duo T5500 @ 4800 MHz | ddr2@ 667 Mhz|
22. XeonAdvanced | 1:14. 33 s | Intel Pentium 4 @ 3660 MHz | ddr @ ? Mhz |
23. Xserces | 1: 40. 64 s | Intel Pentium 4 @ 3000 MHz | ddr @ ? |
24. XeonAdvanced | 2: 46. 42 s | Intel Pentium 4 @ 1700 MHz | ddr @ ? Mhz |
25. Xserces | 35: 30. 85 s | Intel Celeron @ 416 MHz | sdr @ ? |
Evo, fr4nc posodobljeno.
HP XW6400|2× Xeon E5320 @1.86GHz 16MB L2 Cache|Sapphire HD6850
4GB FB-DIMM|HP 575W
4GB FB-DIMM|HP 575W
- spremenil: XeonAdvanced ()
GenZNPC ::
Mene zanima, če je to možno da je tako malo? ali je to kak bug?
m0LN4r | 9.27 s | AMD A10-6800K @ 4725 MHz | ddr3 @ 2200MHz |
skibidi
Pro_moted ::
FX 8120 na 4,8 Gkz ima 5s, tako da je teh 9s na 4,7Ghz čisto normalno.
AMD FX8120;GB 990FXA-UD3
fr4nc ::
Xserces ::
Ke so haswelli? :D
wate ::
galu ::
Friško.
Prosim, da v prihodnje uporabljate formulo za objavo rezultata, da ne bom pri nekaterih iskal podatkov iz slik.
Tako to gre.
einstein :P ::
Mogoče kdo ve, zakaj setfsb popolnoma nič ne učinkuje pri tem testu? BSEL mod se pozna, vse kar pa s setfsbjem naredim, se pa ne pozna ČISTO NIČ!?
Hvala za odg.
Hvala za odg.
STAY OUT OF MY TERRITORY!
einstein :P ::
einstein :P | 10.72s | 2× Xeon E5320 @ 2333MHz (bsel mod - stock 1886MHz) | ddr2, fb-dimm, ecc hynix, 4GB @ 667MHz
- spremenil: einstein :P ()
fr4nc ::
@einstein :P: Torej ti je uspelo
einstein :P ::
@fr4nc
BSEL mod? Ja!
Vse, kar sem prvič pozabil narediti, je bilo resetiranje cmos-a, zato pa takrat ni delalo
Zanimivo, če pogledaš tvoj in moj čas, je približno za pol razlike (malo več, tebi v prid) jaz imam na 2333MHz, ti pa na 4715MHz, pa če bi imel jaz na še enkrat toliko, kot imam (4666MHz) bi imel glih za približno pol večji rezultat, potem pa do 4715 ostane še 49MHz, glih za tisti delček sekunde, pa bi bila mogoče celo izenačena, če bi jaz lahko toliko navil?
BSEL mod? Ja!
Janac ::
Ti govoriš v smislu, če bi 3570k lahk na 6ghz naziv mogoče ujel 3930k se prav za 24/7 nemogoče.
einstein :P ::
In, kaj te muči, če podam neko primerjavo?
- predlagal izbris: Janac ()
fr4nc ::
einstein :P je izjavil:
@fr4nc
BSEL mod? Ja!
Zanimivo, če pogledaš tvoj in moj čas, je približno za pol razlike (malo več, tebi v prid) jaz imam na 2333MHz, ti pa na 4715MHz, pa če bi imel jaz na še enkrat toliko, kot imam (4666MHz) bi imel glih za približno pol večji rezultat, potem pa do 4715 ostane še 49MHz, glih za tisti delček sekunde, pa bi bila mogoče celo izenačena, če bi jaz lahko toliko navil?![]()
Hehe
Zanimivo in v bistvu resnično... z drugimi besedami povedano, je moje 1 "jedro" enako hitro kot tvoje jedro od Xeona
einstein :P ::
Ej, fr4nc
a imaš mogoče možnost odvit na 2333MHz in testirat?
fr4nc ::
Ej, fr4nc
a imaš mogoče možnost odvit na 2333MHz in testirat?![]()
Hmm... dobra ideja
Imam možnost kolikor vem
A pol praviš, da bi probal za foro
Koliko max niti lahko uporablja ta program?
Ne bi vedel... vendar 8 jih zagotovo koristi...
- spremenil: fr4nc ()
TechBeats ::
Ja točno do 64 gre.
Moj 24/7 OC
TechBeats | 3. 82 s | Intel i7 4770K @ 4700 MHz | 4x4GB DDR3 Crucial Balistix Elite CL9 @ 2200 Mhz |
Skoraj prehitel Sharka z 12 threadi :D
Single Core @ 4.7Ghz 16.32s
edit: še cpuz
Ja točno do 64 gre.
Moj 24/7 OC
edit: še cpuz
AciD TriP
- spremenilo: TechBeats ()
TechBeats ::
Prepozen, da bi spremenil..
Malo sem še potweakal ram in dobil
TechBeats | 3. 79 s | Intel i7 4770K @ 4700 MHz | 4x4GB DDR3 Crucial Balistix Elite CL9 @ 2200 Mhz |
Single 16.28s
Single 16.28s
AciD TriP
einstein :P ::
Ej, fr4nc
Hmm... dobra ideja
Imam možnost kolikor vem.
A pol praviš, da bi probal za foro??
Seveda!
einstein :P ::
einstein :P | 10.26s | 2× Xeon E5320 @ 2510MHz (bsel mod + setfsb - stock 1886MHz) | ddr2, fb-dimm, ecc hynix, 4GB @ 667MHz
za nekaj stotink se pozna navitje s fsb-jem ampak škoda, da ne več in nimam pojma, zakaj ne...
fr4nc ::
@einstein :P
Fr4nc | 10.54 s | 8T | AMD FX-8320 @ 2342MHz / ASUS M5A97 / DDR3 @ 1600MHz (11-11-11-28)
11.5x203 = 2333,4MHz (načeloma
Drugače pa so vklopljene vse power saving funkcije ipd. (samo turbo je izklopljen in znižan množilnik ter povišan FSB)
Tako da ja... "jedro" je nekje enako hitro...
fr4nc ::
Zanimivo, potem imava le nekaj podobnega![]()
Hehe... na nek način res
Vendar moj gre tudi čez 4.5GHz recimo
einstein :P ::
To pa, ja. Jah, če bi lahko še jaz prosto navijal, pa mora HP pač vse zaščitit, da ne gre
fr4nc ::
Mhm...no sej koliko je sedaj videt gre dejansko procesorko gledano zelo v tej smeri - manjši OC potencial, saj so stock hitrosti vedno višje...
Spock83 ::
Spock83 | 7.63 s | 16T | AMD Opteron 6212 2x @ 2600MHz / Supermicro H8DGU / DDR3 @ 1600MHz (11-11-11-28)
No dostikrat imam dostop do novih Supermicro strežnikov tako da bom s časoma kar nekaj testov nabral ;)
- spremenil: Spock83 ()
Spock83 ::
Spock83 ::
Zanimivost. 8core Atomcek :)
Spock83 | 12.28 s | 8T | Intel Atom Avoton C2750 @ 2.4GHz | 2x 8GB DDR3 ECC SODIMM 1600Mhz
Seljak ::
Kaj se ti rezultati še sploh posodabljajo ali je avtor pozabil
Proc: AMD Ryzen 7 9800X3D
GIGABYTE GeForce RTX 5080
Ram: 32GB
Ram: 32GB
technolog ::
technolog 27.76s
RAM: DDR3 @ 800 Mhz
Proc: Intel(R) Core™2 Duo CPU T6570 @ 2.10GHz
Dva threada / obe jedri. A ni rezultat kar malce predober?
RAM: DDR3 @ 800 Mhz
matic492 ::
maticbla | 6.29 s | 8T | AMD FX-8320 @ 4000MHz / Gigabyte GA990FXA-UD3 / DDR3 1600
http://shrani.najdi.si/?16/13K/aPL33uB/...
maticbla | 29.24 s | 1T | AMD FX-8320 @ 4500MHz / Gigabyte GA990FXA-UD3 / DDR3 1600
http://shrani.najdi.si/?q/Wu/4S2xcFtg/b...
maticbla | 5.93 s | 8T | AMD FX-8320 @ 4500MHz / Gigabyte GA990FXA-UD3 / DDR3 1600
5GHz malo za hec, hladilnik mi zdrži samo 1 thread, drugače ga downclocka.
http://shrani.najdi.si/?a/uG/4Q4zc0hR/b...
maticbla | 26.28 s | 1T | AMD FX-8320 @ 5000MHz / Gigabyte GA990FXA-UD3 / DDR3 1600
- spremenilo: matic492 ()
GenZNPC ::
m0LN4r | 2. 90s | Intel Core i7 4930K @ 4500 MHz | DDR3@ 1600 Mhz| (1.4V - previsoke temp)
m0LN4r | 3. 15s | Intel Core i7 4930K @ 4343 MHz | DDR3@ 1885 Mhz| (1.31V - 24/7)
skibidi
- spremenil: GenZNPC ()
Seljak ::
Pozabil sem dopisati,da proc ni navit
Ram: 32GB
Ram: 32GB
lonewolf_ ::
lonewolf_ | 17.37s | Intel Pentium G3258 @ 4500MHz | DDR3 @1400 MHz | (1.32V 24/7)
R7 5700G + NH-U12P SE2 | Ballistix 2x8Gb 3000MHz
Mortar Titanium | P1 500GB | Exos 3TB | SSD MX500 1TB
beQuiet 700W Gold | Fractal Design Define S
Spock83 ::
Spock83 |Single Core|1.01min|Opteron 6376|DDR3 @ 1600Mhz
|Multi core (4x 16core)|14.65s|
Ni skoraj razlike ali je en proc z 16-jedri ali vsi štirje proci.
matic492 ::
modelno1 ::
modelno1 | 6,28 s | Intel Core i7 2600 | DDR3 @ 1333 MHz
Respect the bacteria! They are the only culture some people have.
Spock83 ::
| » | Slo-Tech 3D Team: 3DMark (2016) Time Spy (strani: 1 2 3 )Oddelek: Navijanje | 112836 (68780) | opticom1 |
| ! | Slo-tech superpi team: intel core 2, i5, i7 & amd am2, am3 lestvica (strani: 1 2 3 4 5 6 )Oddelek: Navijanje | 308406 (68999) | krneki0001 |
