[Android]Javljanje napak
messi ::
Dober večer, Ob sesutju mi javlja takolo napako ampak jaz rez ne vem kaj je sicer narobe z metodo onDraw ali pa z ostalima napakama če ima kdo kako idejo naj pove kaj je narobe oz kako idejo ..
09-07 07:56:42.896: E/AndroidRuntime(1114): Uncaught handler: thread Thread-9 exiting due to uncaught exception
09-07 07:56:42.906: E/AndroidRuntime(1114): java.lang.NullPointerException
09-07 07:56:42.906: E/AndroidRuntime(1114): at aa.bb.cc.Panel.onDraw(Panel.java:372)
09-07 07:56:42.906: E/AndroidRuntime(1114): at aa.bb.cc.TutorialThread.run(Panel.java:502)
09-07 07:56:42.916: I/dalvikvm(1114): threadid=7: reacting to signal 3
09-07 07:56:42.916: E/dalvikvm(1114): Unable to open stack trace file '/data/anr/traces.txt': Permission denied
09-07 07:56:44.806: I/Process(1114): Sending signal. PID: 1114 SIG: 9
package aa.bb.cc;
public   class Panel extends SurfaceView implements  Callback {
private Shape currentGraphicObject;
DrawPain a;
	public TutorialThread _thread;
    public Panel(Context context,  AttributeSet attributeSet) {
        super(context, attributeSet);
        getHolder().addCallback(this);
        _thread = new TutorialThread(getHolder(), this);
        setFocusable(true);
       setDrawingCacheEnabled(true);
    public Panel(Context context) {
        super(context);
        setFocusable(true);
    public ArrayList<Shape> getGraphicObjects(){
    	return a.graphicobjects;
    /*private void setGraphicObject(Shape s){
    	GraphicObject = s;
    private Shape getGraphicObject(){
    	return GraphicObject;
    /*public Canvas getWallPaperCanvas(){
    	return canvas;
    @Override
    public boolean onTouchEvent(MotionEvent event) {
    	//if(shapemenuclicked == true && erasemenuclicked == false){
        	synchronized (_thread.getSurfaceHolder()) {
        		if(event.getAction() == MotionEvent.ACTION_DOWN){
        			if(a.shapemenuclicked == true && a.erasemenuclicked == false){
	        			//if(GraphicObject instanceof Line){
	        			if(a.ShapeObject_to_be_created == a.ShapeLine){
	        				currentGraphicObject = new Line();
	        				((Line) currentGraphicObject).getBegin().setX(event.getX());
	        				//((Line)(GraphicObject).getBegin().setX(event.getX()));//.setX(event.getX());
	            			//begin.setY(event.getY());
	        				((Line) currentGraphicObject).getBegin().setY(event.getY());
	        			//if(GraphicObject instanceof FreeHand){
	        			if(a.ShapeObject_to_be_created == a.ShapeFreehand){
	        				currentGraphicObject = new FreeHand();
	        				((FreeHand)currentGraphicObject).getPath().moveTo(event.getX(), event.getY());
	        				((FreeHand)currentGraphicObject).getPath().lineTo(event.getX(), event.getY());
	        			//if(GraphicObject instanceof Rectangle){
	        			if(a.ShapeObject_to_be_created == a.ShapeRect){
	        				//(Rectangle)GraphicObject.set
	        				//It will be later decided whether this end is upper-left/lower-left/upper-right
	        				//lower-right
	        				currentGraphicObject = new Rectangle();
	        				Point temp = new Point(event.getX(), event.getY());
	        				((Rectangle) currentGraphicObject).settemppointOfOneEndRectangle(temp);
	        			//if(GraphicObject instanceof Circle){
	        			if(a.ShapeObject_to_be_created == a.ShapeCircle){
	        				currentGraphicObject = new Circle();
	        				((Circle)currentGraphicObject).getOneEndOfTheCircle().setX(event.getX());
	        				((Circle)currentGraphicObject).getOneEndOfTheCircle().setY(event.getY());
	        			//if(GraphicObject instanceof Oval){
	        			if(a.ShapeObject_to_be_created == a.ShapeOval){
	        				currentGraphicObject = new Oval();
	        				((Oval)currentGraphicObject).getoneEndOfTheOval().setX(event.getX());
	        				((Oval)currentGraphicObject).getoneEndOfTheOval().setY(event.getY());
        			if(a.shapemenuclicked == false && a.erasemenuclicked == true){
                		//if(GraphicObject instanceof Erase){
        				if(a.ShapeObject_to_be_created == a.ShapeErase){
            				currentGraphicObject = new Erase();
            				((Erase)currentGraphicObject).getPath().moveTo(event.getX(), event.getY());
            				((Erase)currentGraphicObject).getPath().lineTo(event.getX(), event.getY());
        		else if(event.getAction() == MotionEvent.ACTION_MOVE){
	        			/*if(GraphicObject instanceof Rectangle){
	        			/*if(GraphicObject instanceof Circle){
        		else if(event.getAction() == MotionEvent.ACTION_UP){
	        				//create a new Line... Add it to the  ArrayList
	        				//currentGraphicObject = new Line();
	        				((Line) currentGraphicObject).getEnd().setX(event.getX());
	        				((Line) currentGraphicObject).getEnd().setY(event.getY());
	        				Point temp_begin = ((Line)currentGraphicObject).getBegin();
	        				Point temp_end = ((Line)currentGraphicObject).getEnd();
	            			((Line) currentGraphicObject).setBegin(temp_begin);
	            			((Line)currentGraphicObject).getPath().moveTo(temp_begin.getX(), temp_begin.getY());
	            			((Line)currentGraphicObject).getPath().lineTo(temp_end.getX(), temp_end.getY());
	            			//currentGraphicObject.setrgb((int)color[0],(int)color[1],(int)color[2]);
	        				//_graphics.add(((FreeHand)GraphicObject).getPath());
	        				((FreeHand)currentGraphicObject).getGraphicsPath().add(((FreeHand)currentGraphicObject).getPath());
	        				float tempX = ((Rectangle) currentGraphicObject).gettemppointOfOneEndRectangle().getX();
	        				//the X co-ordinate of the first up
	        				float tempY = ((Rectangle) currentGraphicObject).gettemppointOfOneEndRectangle().getY();
	        				float tempX1 = event.getX();
	        				float tempY1 = event.getY();
	        				if(tempX<tempX1 && tempY>tempY1){
	        					((Rectangle)currentGraphicObject).getPath().addRect(tempX, tempY1, tempX1, tempY, Path.Direction.CW);
	        				if(tempX<tempX1 && tempY<tempY1){
	        					((Rectangle)currentGraphicObject).getPath().addRect(tempX, tempY, tempX1, tempY1, Path.Direction.CW);
	        				if(tempX>tempX1  && tempY>tempY1){
	        					((Rectangle)currentGraphicObject).getPath().addRect(tempX1, tempY1, tempX, tempY, Path.Direction.CW);
	        				if(tempX>tempX1 && tempY<tempY1){
	        					((Rectangle)currentGraphicObject).getPath().addRect(tempX1, tempY, tempX, tempY1, Path.Direction.CW);
	        				float tempX1 = ((Circle)currentGraphicObject).getOneEndOfTheCircle().getX();
	        				float tempY1 = ((Circle)currentGraphicObject).getOneEndOfTheCircle().getY();
	        				float tempX2 = event.getX();
	        				float tempY2 = event.getY();
	        				double temp = Math.pow((tempX1-tempX2),2) + Math.pow((tempY1-tempY2),2);
	        				float radius = (float)Math.sqrt(temp)/2;
	        				((Circle)currentGraphicObject).getPath().addCircle((tempX1 + tempX2)/2,(tempY1 + tempY2)/2, radius, Path.Direction.CW);
	        				float tempX = ((Oval)currentGraphicObject).getoneEndOfTheOval().getX();
	        				float tempY = ((Oval)currentGraphicObject).getoneEndOfTheOval().getY();
	        				if(tempX<=tempX1 && tempY>=tempY1){
	           					((Oval)currentGraphicObject).getRectangle().set(tempX,tempY1,tempX1,tempY);
	        				if(tempX<=tempX1 && tempY<=tempY1){
	        					((Oval)currentGraphicObject).getRectangle().set(tempX,tempY,tempX1,tempY1);
	        				if(tempX>=tempX1  && tempY>=tempY1){
	        					((Oval)currentGraphicObject).getRectangle().set(tempX1,tempY1,tempX,tempY);
	        				if(tempX>=tempX1 && tempY<=tempY1){
	        					((Oval)currentGraphicObject).getRectangle().set(tempX1,tempY,tempX,tempY1);
	        				//RectF r = ((Oval)GraphicObject).getRectangle();
	        				((Oval)currentGraphicObject).getPath().addOval(((Oval)currentGraphicObject).getRectangle(), Path.Direction.CW);
	        				//((Oval)GraphicObject).getPath().addOval(r, Path.Direction.CW);
	        				((Erase)currentGraphicObject).getGraphicsPath().add(((Erase)currentGraphicObject).getPath());
        			if(a.colormenuclicked == false && a.shapemenuclicked == true){
	        			currentGraphicObject.setrgb(100,100,100);
	        		if(a.colormenuclicked == true && a.shapemenuclicked == true){
	        			currentGraphicObject.setrgb((int)a.color[0],(int)a.color[1],(int)a.color[2]);
	        		if(a.erasemenuclicked == true && a.colormenuclicked == false){
	        			currentGraphicObject.setrgb(0,0,0);
	        			//mPaint.setStrokeWidth(6);
	        		if(a.brushwidthmenuclicked == true){//  || erasemenuclicked == true){
	        			currentGraphicObject.setStrokeWidth(a.BrushWidth);
	        		a.graphicobjects.add(currentGraphicObject);
	        		a.number_of_graphicObjects++;
        		if(colormenuclicked == false && shapemenuclicked == true){
        		if(colormenuclicked == true && shapemenuclicked == true){
        		if(erasemenuclicked == true && colormenuclicked == false){
        		if(brushwidthmenuclicked == true){//  || erasemenuclicked == true){
        			currentGraphicObject.setStrokeWidth(BrushWidth);
        		number_of_graphicObjects++;*/
      return true;
    @Override
    public void onDraw(Canvas canvas) {
    		for(int i = 0; i<a.number_of_graphicObjects; i++){
        		Shape currentGraphicObject = a.graphicobjects.get(i);
        			a.mPaint.setColor(Color.rgb(currentGraphicObject.getrgb()[0], currentGraphicObject.getrgb()[1], currentGraphicObject.getrgb()[2]));
        			a.mPaint.setStrokeWidth(currentGraphicObject.getStrokeWidth());
        		if(currentGraphicObject instanceof FreeHand){
        			for (Path path : ((FreeHand)currentGraphicObject).getGraphicsPath()) {
                	    canvas.drawPath(path,a.mPaint);
                	    a.bitmapCanvas.drawPath(path,a.mPaint);
        		else if(currentGraphicObject instanceof Erase){
        			for (Path path : ((Erase)currentGraphicObject).getGraphicsPath()) {
                	    canvas.drawPath(path, a.mPaint);
                	    a.bitmapCanvas.drawPath(path, a.mPaint);
        		else{
        			canvas.drawPath(currentGraphicObject.getPath(),a.mPaint);
        			a.bitmapCanvas.drawPath(currentGraphicObject.getPath(),a.mPaint);
    public void surfaceCreated(SurfaceHolder holder) {
        _thread.setRunning(true);
        _thread.start();
    public void surfaceDestroyed(SurfaceHolder holder) {
        boolean retry = true;
        _thread.setRunning(false);
        while (retry) {
            try {
                _thread.join();
                retry = false;
            } catch (InterruptedException e) {
                // we will try it again and again...
class TutorialThread extends Thread {
    private SurfaceHolder _surfaceHolder;
    private Panel _panel;
    private boolean _run = false;
    public TutorialThread(SurfaceHolder surfaceHolder, Panel panel) {
        _surfaceHolder = surfaceHolder;
        _panel = panel;
    public void setRunning(boolean run) {
        _run = run;
    public SurfaceHolder getSurfaceHolder() {
        return _surfaceHolder;
    @Override
    public void run() {
        Canvas c;
        while (_run) {
            c = null;
            try {
                c = _surfaceHolder.lockCanvas(null);
                synchronized (_surfaceHolder) {
                    _panel.onDraw(c);
                    //_panel.saveScreenshot();
            } finally {
                if (c != null) {
                    _surfaceHolder.unlockCanvasAndPost(c);
[Android] pomoč pri postavitvi layouta
Oddelek: Programiranje
123034 (2792) icurk
Programiranje problem android
51596 (1361) g333kk
Android zamenjava pogledov
61574 (1395) c00L3r
android črta
412970 (2241) g333kk
vkljucevanje txt datoteke v ...
132005 (1781) webblod
