Forum » Programiranje » [Android]Javljanje napak
messi ::
Dober večer, Ob sesutju mi javlja takolo napako ampak jaz rez ne vem kaj je sicer narobe z metodo onDraw ali pa z ostalima napakama če ima kdo kako idejo naj pove kaj je narobe oz kako idejo ..
09-07 07:56:42.896: E/AndroidRuntime(1114): Uncaught handler: thread Thread-9 exiting due to uncaught exception
09-07 07:56:42.906: E/AndroidRuntime(1114): java.lang.NullPointerException
09-07 07:56:42.906: E/AndroidRuntime(1114): at aa.bb.cc.Panel.onDraw(Panel.java:372)
09-07 07:56:42.906: E/AndroidRuntime(1114): at aa.bb.cc.TutorialThread.run(Panel.java:502)
09-07 07:56:42.916: I/dalvikvm(1114): threadid=7: reacting to signal 3
09-07 07:56:42.916: E/dalvikvm(1114): Unable to open stack trace file '/data/anr/traces.txt': Permission denied
09-07 07:56:44.806: I/Process(1114): Sending signal. PID: 1114 SIG: 9
package aa.bb.cc;
public class Panel extends SurfaceView implements Callback {
private Shape currentGraphicObject;
DrawPain a;
public TutorialThread _thread;
public Panel(Context context, AttributeSet attributeSet) {
super(context, attributeSet);
getHolder().addCallback(this);
_thread = new TutorialThread(getHolder(), this);
setFocusable(true);
setDrawingCacheEnabled(true);
public Panel(Context context) {
super(context);
setFocusable(true);
public ArrayList<Shape> getGraphicObjects(){
return a.graphicobjects;
/*private void setGraphicObject(Shape s){
GraphicObject = s;
private Shape getGraphicObject(){
return GraphicObject;
/*public Canvas getWallPaperCanvas(){
return canvas;
@Override
public boolean onTouchEvent(MotionEvent event) {
//if(shapemenuclicked == true && erasemenuclicked == false){
synchronized (_thread.getSurfaceHolder()) {
if(event.getAction() == MotionEvent.ACTION_DOWN){
if(a.shapemenuclicked == true && a.erasemenuclicked == false){
//if(GraphicObject instanceof Line){
if(a.ShapeObject_to_be_created == a.ShapeLine){
currentGraphicObject = new Line();
((Line) currentGraphicObject).getBegin().setX(event.getX());
//((Line)(GraphicObject).getBegin().setX(event.getX()));//.setX(event.getX());
//begin.setY(event.getY());
((Line) currentGraphicObject).getBegin().setY(event.getY());
//if(GraphicObject instanceof FreeHand){
if(a.ShapeObject_to_be_created == a.ShapeFreehand){
currentGraphicObject = new FreeHand();
((FreeHand)currentGraphicObject).getPath().moveTo(event.getX(), event.getY());
((FreeHand)currentGraphicObject).getPath().lineTo(event.getX(), event.getY());
//if(GraphicObject instanceof Rectangle){
if(a.ShapeObject_to_be_created == a.ShapeRect){
//(Rectangle)GraphicObject.set
//It will be later decided whether this end is upper-left/lower-left/upper-right
//lower-right
currentGraphicObject = new Rectangle();
Point temp = new Point(event.getX(), event.getY());
((Rectangle) currentGraphicObject).settemppointOfOneEndRectangle(temp);
//if(GraphicObject instanceof Circle){
if(a.ShapeObject_to_be_created == a.ShapeCircle){
currentGraphicObject = new Circle();
((Circle)currentGraphicObject).getOneEndOfTheCircle().setX(event.getX());
((Circle)currentGraphicObject).getOneEndOfTheCircle().setY(event.getY());
//if(GraphicObject instanceof Oval){
if(a.ShapeObject_to_be_created == a.ShapeOval){
currentGraphicObject = new Oval();
((Oval)currentGraphicObject).getoneEndOfTheOval().setX(event.getX());
((Oval)currentGraphicObject).getoneEndOfTheOval().setY(event.getY());
if(a.shapemenuclicked == false && a.erasemenuclicked == true){
//if(GraphicObject instanceof Erase){
if(a.ShapeObject_to_be_created == a.ShapeErase){
currentGraphicObject = new Erase();
((Erase)currentGraphicObject).getPath().moveTo(event.getX(), event.getY());
((Erase)currentGraphicObject).getPath().lineTo(event.getX(), event.getY());
else if(event.getAction() == MotionEvent.ACTION_MOVE){
/*if(GraphicObject instanceof Rectangle){
/*if(GraphicObject instanceof Circle){
else if(event.getAction() == MotionEvent.ACTION_UP){
//create a new Line... Add it to the ArrayList
//currentGraphicObject = new Line();
((Line) currentGraphicObject).getEnd().setX(event.getX());
((Line) currentGraphicObject).getEnd().setY(event.getY());
Point temp_begin = ((Line)currentGraphicObject).getBegin();
Point temp_end = ((Line)currentGraphicObject).getEnd();
((Line) currentGraphicObject).setBegin(temp_begin);
((Line)currentGraphicObject).getPath().moveTo(temp_begin.getX(), temp_begin.getY());
((Line)currentGraphicObject).getPath().lineTo(temp_end.getX(), temp_end.getY());
//currentGraphicObject.setrgb((int)color[0],(int)color[1],(int)color[2]);
//_graphics.add(((FreeHand)GraphicObject).getPath());
((FreeHand)currentGraphicObject).getGraphicsPath().add(((FreeHand)currentGraphicObject).getPath());
float tempX = ((Rectangle) currentGraphicObject).gettemppointOfOneEndRectangle().getX();
//the X co-ordinate of the first up
float tempY = ((Rectangle) currentGraphicObject).gettemppointOfOneEndRectangle().getY();
float tempX1 = event.getX();
float tempY1 = event.getY();
if(tempX<tempX1 && tempY>tempY1){
((Rectangle)currentGraphicObject).getPath().addRect(tempX, tempY1, tempX1, tempY, Path.Direction.CW);
if(tempX<tempX1 && tempY<tempY1){
((Rectangle)currentGraphicObject).getPath().addRect(tempX, tempY, tempX1, tempY1, Path.Direction.CW);
if(tempX>tempX1 && tempY>tempY1){
((Rectangle)currentGraphicObject).getPath().addRect(tempX1, tempY1, tempX, tempY, Path.Direction.CW);
if(tempX>tempX1 && tempY<tempY1){
((Rectangle)currentGraphicObject).getPath().addRect(tempX1, tempY, tempX, tempY1, Path.Direction.CW);
float tempX1 = ((Circle)currentGraphicObject).getOneEndOfTheCircle().getX();
float tempY1 = ((Circle)currentGraphicObject).getOneEndOfTheCircle().getY();
float tempX2 = event.getX();
float tempY2 = event.getY();
double temp = Math.pow((tempX1-tempX2),2) + Math.pow((tempY1-tempY2),2);
float radius = (float)Math.sqrt(temp)/2;
((Circle)currentGraphicObject).getPath().addCircle((tempX1 + tempX2)/2,(tempY1 + tempY2)/2, radius, Path.Direction.CW);
float tempX = ((Oval)currentGraphicObject).getoneEndOfTheOval().getX();
float tempY = ((Oval)currentGraphicObject).getoneEndOfTheOval().getY();
if(tempX<=tempX1 && tempY>=tempY1){
((Oval)currentGraphicObject).getRectangle().set(tempX,tempY1,tempX1,tempY);
if(tempX<=tempX1 && tempY<=tempY1){
((Oval)currentGraphicObject).getRectangle().set(tempX,tempY,tempX1,tempY1);
if(tempX>=tempX1 && tempY>=tempY1){
((Oval)currentGraphicObject).getRectangle().set(tempX1,tempY1,tempX,tempY);
if(tempX>=tempX1 && tempY<=tempY1){
((Oval)currentGraphicObject).getRectangle().set(tempX1,tempY,tempX,tempY1);
//RectF r = ((Oval)GraphicObject).getRectangle();
((Oval)currentGraphicObject).getPath().addOval(((Oval)currentGraphicObject).getRectangle(), Path.Direction.CW);
//((Oval)GraphicObject).getPath().addOval(r, Path.Direction.CW);
((Erase)currentGraphicObject).getGraphicsPath().add(((Erase)currentGraphicObject).getPath());
if(a.colormenuclicked == false && a.shapemenuclicked == true){
currentGraphicObject.setrgb(100,100,100);
if(a.colormenuclicked == true && a.shapemenuclicked == true){
currentGraphicObject.setrgb((int)a.color[0],(int)a.color[1],(int)a.color[2]);
if(a.erasemenuclicked == true && a.colormenuclicked == false){
currentGraphicObject.setrgb(0,0,0);
//mPaint.setStrokeWidth(6);
if(a.brushwidthmenuclicked == true){// || erasemenuclicked == true){
currentGraphicObject.setStrokeWidth(a.BrushWidth);
a.graphicobjects.add(currentGraphicObject);
a.number_of_graphicObjects++;
if(colormenuclicked == false && shapemenuclicked == true){
if(colormenuclicked == true && shapemenuclicked == true){
if(erasemenuclicked == true && colormenuclicked == false){
if(brushwidthmenuclicked == true){// || erasemenuclicked == true){
currentGraphicObject.setStrokeWidth(BrushWidth);
number_of_graphicObjects++;*/
return true;
@Override
public void onDraw(Canvas canvas) {
for(int i = 0; i<a.number_of_graphicObjects; i++){
Shape currentGraphicObject = a.graphicobjects.get(i);
a.mPaint.setColor(Color.rgb(currentGraphicObject.getrgb()[0], currentGraphicObject.getrgb()[1], currentGraphicObject.getrgb()[2]));
a.mPaint.setStrokeWidth(currentGraphicObject.getStrokeWidth());
if(currentGraphicObject instanceof FreeHand){
for (Path path : ((FreeHand)currentGraphicObject).getGraphicsPath()) {
canvas.drawPath(path,a.mPaint);
a.bitmapCanvas.drawPath(path,a.mPaint);
else if(currentGraphicObject instanceof Erase){
for (Path path : ((Erase)currentGraphicObject).getGraphicsPath()) {
canvas.drawPath(path, a.mPaint);
a.bitmapCanvas.drawPath(path, a.mPaint);
else{
canvas.drawPath(currentGraphicObject.getPath(),a.mPaint);
a.bitmapCanvas.drawPath(currentGraphicObject.getPath(),a.mPaint);
public void surfaceCreated(SurfaceHolder holder) {
_thread.setRunning(true);
_thread.start();
public void surfaceDestroyed(SurfaceHolder holder) {
boolean retry = true;
_thread.setRunning(false);
while (retry) {
try {
_thread.join();
retry = false;
} catch (InterruptedException e) {
// we will try it again and again...
class TutorialThread extends Thread {
private SurfaceHolder _surfaceHolder;
private Panel _panel;
private boolean _run = false;
public TutorialThread(SurfaceHolder surfaceHolder, Panel panel) {
_surfaceHolder = surfaceHolder;
_panel = panel;
public void setRunning(boolean run) {
_run = run;
public SurfaceHolder getSurfaceHolder() {
return _surfaceHolder;
@Override
public void run() {
Canvas c;
while (_run) {
c = null;
try {
c = _surfaceHolder.lockCanvas(null);
synchronized (_surfaceHolder) {
_panel.onDraw(c);
//_panel.saveScreenshot();
} finally {
if (c != null) {
_surfaceHolder.unlockCanvasAndPost(c);
} Vredno ogleda ...
| » | [Android] pomoč pri postavitvi layoutaOddelek: Programiranje | 2981 (2739) | icurk |
| » | Programiranje problem androidOddelek: Programiranje | 1570 (1335) | g333kk |
| » | Android zamenjava pogledovOddelek: Programiranje | 1546 (1367) | c00L3r |
| » | android črtaOddelek: Programiranje | 2948 (2219) | g333kk |
| » | vkljucevanje txt datoteke v ...Oddelek: Programiranje | 1990 (1766) | webblod |
