Asus K75V (procesor in grafična)
nendzi ::
Pozdravljeni,
zanima me če kdo ve koliko lahko največ navijem sledečo grafično od prenosnega računalnika Geforce GT 630M 2gb (default: core clock 475Mhz, Memory clock 900Mhz). Zanima me tudi kako se vklopi turbo boost za procesor, ker ima to opcijo ( procesor je intel core i7 3610QM ) ali se pač vklopi avtomatsko, ko se kakšna igra zažene? (The Intel Core i7 for laptops is based on the LG1156 Core i5/i7 CPU for desktops. The base clock speed of the CPUs is relatively low, but because of a huge Turbo mode, the cores can dynamically overclock to up to 3.2 GHz (920XM). Therefore, the CPU can be as fast as high clocked dual-core CPUs (using single threaded applications) but still offer the advantage of 4 cores. Because of the large TDP of 45 W / 55 W, the CPU is only intended for large laptops)
Hvala.
DOOM_er ::
tudi jaz imam ta prenosnik sedaj in me zanima kako vem in kako spreminjam katera grafična kartica mi deluje. Imam notri nvidio gt635m in pa integrirano intel. Windows score v windows 8 imam 6.5 za multimedio in gaming medtem ko je za aero in desktop 6.1 . Je to v redu?
hvala
Kaby Lake (strani: 1 2 3 4 5 6 7 )
30277432 (59351) Han
Navijanje (strani: 1 2 )
Oddelek: Navijanje
5613777 (12489) wate
prenosnik za igre do 1200E
339503 (8875) iloveboobz
