PowerColor Devil 13 HD 7990
Janac ::
TUL Corporation, a leading manufacturer of AMD graphic cards, today reveals the 1st and only dual TAHITI XT GPU solution: the PowerColor Devil 13 HD7990. Designed to tackle the demanding HD titles, the Devil 13 HD7990 has default settings at 925 MHz engine clocks and 1375 MHz memory clocks. Furthermore, it's equipped with dual BIOS switch button, boosting up the engine frequencies to 1 GHz, breaking out the limitation of extremely gaming performance.
Solidly-Built Design
The Devil 13 HD7990 is built with high efficiency thermal solution and solid components onboard. With trio fans and 10pcs U-shape heat pipes, maximizing the heat dissipated ability to cool down the Devil 13 board. Also, it includes 12+2+2 phases, digital PWM, super cap, UHB and PowerIRstage—all these platinum power kit enhances stability and reliability voltage for GPU with minimum conduction losses and lower temperatures at load, delivering the steadiest and most secure power to boost for performance.
Devil13 Deluxe Pack
The Devil 13 HD7990 includes industry leading brand, Wiha Tool Kit; with Wiha multiple reversible blades set, gamers can easily utilize different blades to fix every machine. Also, it packs with PowerColor PowerJack, the professional graphics card supporter which provides the powerful force to support the weight of the card from the back, avoiding card bending in the case.
Xserces ::
stara novica... to se že dolg ve za "devila"
devil 13 aka 7970x2 al je to kej novga?... official 7990 pa od nikjer...
  • spremenil: Xserces ()
sennheiser ::
Če ne bodo preskočil stvar... glede na to da nismo daleč od 8 serije
Janac ::
Pro_moted ::
Janac je izjavil:
prvi review http://www.hardwareheaven.com/reviews/1...
To pomeni, da za multi monitor setup , je boljše izbrat 7990. Za en monitor pa se tak grafa itak ne kupi. Če je še cena taprava, potem je to WIN za PowerColor.
AMD FX8120;GB 990FXA-UD3
Predator ^^ ::
Pa ni hd 7990 ampak je hd 7970x2!
Gnmstle
  • polepsal: bluefish ()
Janac ::
od kej ti pa to?
ja saj 690 je tudi 680x2
Predator ^^ ::
Ne ni.
GTX 680 SLi > GTX 690
Gnmstle
Janac ::
vidimd a nimas pojma. Ce je proizvalaec grafo oznacil za 7990 je pac to to. Drugace s eje pa amd odlocil d anebo iydal svoje 79990
freesty ::
Predator ^^ je izjavil:
Ne ni.
Ubistvu pri istih frekvencah je 680 sli = gtx 690
http://www.youtube.com/watch?v=5hfYJsQAhl0
Xserces ::
kaj se zgodi z GTX690 pri DIRT in pa Sleeping Dogs? watafak? Ne verjamem da GTX690 počepne pri 1920x1080 v sleeping dogs...
isto pri dirt showdown na 1920x1080 ma AVG 35FPS ? WTF
Predator ^^ ::
Gnmstle
Xserces ::
na techpowerup se pa lepo vidi da niso driverji poštimani pri Batmanu in pa BF3 ... Kot da nebi blo 2 jedra ... UL
Janac ::
torej je najhitrejsa graficna kartica na svetu GTX 690? Govorim povprecno.
Jakob_X ::
Xserces je izjavil:
Direct compute. AMD je hitrejsi v tek taskih in v novejsih igrah, ki bodo to izkoriscale se bo ta razlika pac poznala.
Xserces je izjavil:
to je pac 7990. Nic pa ne kaze da bodo izdali referencno 7990 ampak to ne pomeni da 7990 ne obstaja. Je pac AMD dovolil da pac svojo naredijo.
Who cares...tako ali tako se bolj splaca kupit dve kartico kot pa eno z dvema cipoma. Je ceneje pa se manj se pregreva in je posledicno tisja, da ne omenjam da so ponavadi tudi malce hitrejse.
  • spremenil: Jakob_X ()
Jakob_X ::
Janac je izjavil:
Glede ne ta review je za multimonitor setup (edini "logicen" razlog da to nabavis) vecinoma AMD rahlo hitrejsi. Obe kartici sta za tiste, ki imajo vec denarja kot pameti.
Xserces ::
Moje mnenje glede teh testov ... brezveze dokler ne dajo poštimanih driverjev vn... morte racunat da je GTX690 že kr neki cajta uzun pa ima "poštimane" driverje... Pri BF3 in pri nekaterih igrah je "7990"=7970 KAR JE PORAZNO...
Test grafičnih kartic pri ločljivosti 4K (strani: 1 2 )
5730253 (26589) MrStein
AMD-jeva najzmogljivejša kartica po novem Radeon HD 7990
3913088 (11118) mtosev
AMD je na GDC-ju pokazal Radeona HD 7990
3920831 (18522) D3m
GeForce GTX Titan - najhitrejši grafični čip na svetu (strani: 1 2 3 )
10132890 (28817) mihco
