Forum » Loža » Ročna ura
Ročna ura
iKst_ ::
Rekel sem konkretne primere.
Saj sem ti napisal, pa očitno površno bereš. Citizen Attesa in Seiko Astron. Podoben koncept, v veliko primerih bistveno boljša izvedba.
Seiko Astron je dražji. Kar pa se ostali dveh tiče (da ne bi na pamet):
If you're comparing the Citizen Attesa and Casio Oceanus lines (not specific models), they're among the best Japanese solar quartz watches. Both offer titanium cases, sapphire crystals, radio/GPS timekeeping on many models, and exceptional reliability. The differences come down to finishing, technology, and value.
Category Citizen Attesa Casio Oceanus Winner
Build quality Excellent Outstanding ? Oceanus
Case finishing Very good Zaratsu/Sallaz polished with sharper finishing ? Oceanus
Titanium Super Titanium (Duratect coating) Titanium with titanium-carbide coating Tie
Scratch resistance Excellent (Super Titanium is very hard) Excellent ? Attesa (slight edge)
Bracelet quality Very good Better tolerances, less rattle ? Oceanus
Dial design Clean and modern More refined and luxurious ? Oceanus
Crystal Sapphire Sapphire with excellent anti-reflective coating ? Oceanus
Accuracy Eco-Drive + Radio/GPS Tough Solar + Radio + Bluetooth (many models) ? Oceanus
Battery/Solar Eco-Drive is industry-leading Tough Solar is also excellent Tie
GPS models Larger selection Fewer GPS models ? Attesa
Bluetooth Limited More common ? Oceanus
Value for money Excellent Excellent, slightly higher perceived quality ? Oceanus
Availability Easier to find globally Mostly Japanese Domestic Market ? Attesa
Overall score
Category Winner
Luxury feel ? Oceanus
Toughness ? Attesa
Technology ? Oceanus
Finishing ? Oceanus
Comfort Tie
Everyday watch ? Oceanus
Best travel watch Tie (depends on GPS vs Bluetooth preference)
Which is better?
Choose Casio Oceanus if you want:
Better case and bracelet finishing.
A more premium-looking dial.
Excellent anti-reflective sapphire crystal.
Bluetooth plus Multiband 6 synchronization on many models.
A watch that feels close to entry-level luxury at a mid-range price.
Choose Citizen Attesa if you want:
Citizen's renowned Eco-Drive movement.
Super Titanium with exceptional scratch resistance.
More GPS satellite-controlled options.
Better worldwide availability and service.
Final verdict
Overall Ranking Score (/10)
? Casio Oceanus 9.7
? Citizen Attesa 9.3
For most enthusiasts, Casio Oceanus is considered the more refined watch because of its superior finishing, bracelet quality, and dial execution. Citizen Attesa excels in material technology (Super Titanium) and offers stronger GPS-based options, making it especially attractive for frequent international travelers.
Ni se mi dalo formatirati, informacijo se da komot razbrati.
Tako, da nima za burek tale tvoj model.
Zdaj, da smo mi tisti, ki smo prepoznali:
Overall score
Category Winner
Toughness ? Attesa
Finishing ? Oceanus
Comfort Tie
Which is better?
Final verdict
? Casio Oceanus 9.7
bullshit :)
- spremenilo: FireSnake ()
iKst_ ::
Ja, res je, se opravičujem. Če ChatGPT tako pravi, bo pa že res :) Sploh glede na to, da primerjava ni pavšalna in povsem subjektivna, ampak natančno primerja dva točno določena modela, a ne? :)
Ne se smešit s takimi objavami. Dajmo držat en nivo debate prosim.
Saj te razumemo, si fan Oceanusa, tudi drugi smo in jih z veseljem nosimo (ne samo enega). Ampak slepo nabijanje o superiornosti na vseh nivojih pa nobenem ne koristi.
Še tvoj lame LLM odgovor je ocenil, da ni neke dramatične razlike med Oceanusom in Atteso (čeprav ni jasno katere modele je primerjal).
Tale Oceanus stane skoraj 5 jurjev. Jurja in pol več od trenutno najdražjega Astrona na Seiko.com
https://www.casio.com/us/watches/oceanu...
Gogo ::
Iščem manj znano švicarsko znamko ure. Ne diver varianto, enostavno, le datum. Za priporočila bom hvaležen.
Gigabyte Aorus B550 Elite|Ryzen 3 3100|Gainward RTX 2060 Ghost, 6 GB GDDR|
TG Delta RGB 16GB CL 16|ADATA XPG SX8200 PRO 512GB NVMe SSD M.2|
Chieftec Photon Series 650W RGB ATX| Antec PerformanceOne P7 Silent Black|
iKst_ ::
Gogo, kakšen je budget?
Meni so všeč Nivada Grenchen. En od OG švicarskih brandov, ki so ga oživili leta 2018.
Npr. Super Antarctic:
Pa Ball lahko pohvalim. Imam Engineer III že nekaj časa, je kar redno v rotaciji. Je pa res, da imajo v katalogu tudi nekaj precej groznih modelov.
iKst_ ::
Aja, pa Victorinox lahko še pogledaš. Znamka sama po sebi je sicer precej znana, ampak predvsem po nožih. Delajo pa tudi odlične ure.
iKst_ ::
Where Are Victorinox Watches Manufactured ?
Victorinox watches are manufactured at the Watch Competence Center in Délémont, Switzerland, where they are also developed, assembled and inspected.
https://www.victorinox.com/en-PL/What-M...
Razen, če ciljaš na to, da določene dele dobijo iz Kitajske in ure samo sestavijo v Švici. Ampak to delajo praktično vse švicarske znamke, tudi take, ki prodajajo ure za 10k EUR in več.
Zvezdica27 ::
ok,
bom še napisal prva opažanja tega oceanusa 200: BT dela super, se poveže s telefonom, nastavi uro... no hassle. Ne vem ali potem še uporablja radio ali ne, ampak point je, da ni težav. Nastaviš time zone, nasveidenje.
Solar dela. ura je praktično non-stop na 100%. Sploh ne bom preverjal. Vesel sem, da nisem vzel mehanske (v igri je bil Seiko 5, saj sem napisal, da nad neko mejo mi je moralno sporno dati keš za jebeno uro).
na vajino debato: niso vsi Oceanusi titan. In pa, ko sem gledal v trgovini, je bil pri enem Oceanusu številčnica za 0,2 mm zamaknjena (na blizu se je videlo, moteče). Sam da se ve, da JDM ure niso vedno popolne ;)
Še zadnja stvar: če bo kdo od vas šel na J, zdaj ko razmišljam, za razliko cene ure imate krit polet. Če že kupujete uro za nekaj tisoč. Hoteli so cenejši, hrana je okoli pol cene tu... tak da priporočam, vendar pa velike trgovine z urami sem jaz videl v Nagoyi in Osaki. Tokio in Kyoto sta bolj turistična, je pa res, da nisem aktivno iskal. No, kar sem jaz gledal sem itak kupoval v velikih trgovskih centrih (Bic store in še ena veriga), ne pa v namenskih trgovinah (Rolex, Tissot, TAG itd.).
Zdaj ko sem tu, je cena tudi 10% nižja, ker ni davka in na meji te itak noben ne gleda (uro daš na roko). Bom javil, če slučajno pride od FURS kaj kasneje (ker se vsak nakup skenira na qr od vize).
Tako,
zdj sem se tudi odločil, da si iz vsakega potovanaj prinesel kako lokalno uro... pa bo neka zbirka čez par let...
zz
Tako,
zz
Gogo ::
Budget je okoli 500€.
iKst_ ::
En (pri nas) malo znan švicarski proizvajalec ur je West End Watch Co.
https://www.westendwatchco.ch/
Ena od redkih manjših znamk, ki ni bila obujene od mrtvih, ampak je dejavna že dobrih 130 let. Je ena od tistih znamk, katerih glavno tržišče je izven Evrope in ZDA - pretežno Azija, Bližnji Vzhod...
So pa večinoma nad 500 evrov, nekje med 750 in 1000.
Druga podobna znamka je Ogival. Njeno glavno tržišče je Tajvan, Vietnam, Kambodža...
https://ogival.ch/
Med od mrtvih obujenih znamk je pa treba nujno omeniti Darwil, ki je bil nekoč najbolj priljubljena znamka švicarskih ur v ex-Jugoslaviji.
https://www.darwil.ch/
So pa za obujeno znamko kar (pre)drage, od 1500-2000 frankov.
https://ogival.ch/
Gogo ::
Thx za omenjene. Sicer ne iščem diver stil
Sem pa poiskal Glycine GL0508
Glycine AIRPILOT Automatic. Všečna ura.
Gledam pa tudi Mathey-Tissot (serija Rolly Vintage ali Classic)
Gogo ::
Eh Mathey-Tissot (serija Rolly Vintage ali Classic) ni zame.
iKst_ ::
Če boš kupoval Glycin poglej na https://www.jomashop.com/
Če hočeš videti končno ceno moraš sicer na košarico in vpisati svoj naslov. Ti zaračunajo poštnino in carino/davek kar ob nakupu. Amapk imajo ponavadi dobre cene, tako, da se splača preveriti.
Gogo ::
Hvala.
Zvezdica27 ::
ej, zakaj ima diver ura vrtljivo krono - saj lahko googlam, sam če mi nekdo laično pojasni... razumem, da kul zgleda, a zakaj imajo diverji to (in ali današnje športne ure tega ne delajo bolje?)
zz
zz
iKst_ ::
Verjetno misliš luneto (bezel)? Krona je vrtljiv gumb s katerim nastavljaš čas/datum.
Drugače je pa to štoparica. Npr. nastaviš tako, da je nula poravnana z minutami in potem lažje vidiš, koliko minut je preteklo. Si ni treba zapomniti točnega začetnega časa.
Današnje športne ure so drugače v vsem boljše od analognih, še posebej mehanskih. Dejanska uporabna vrednost mehanskih ur je danes blizu nič. Če hočeš funkcionalnost, si kupiš Garmin ali Apple Watch, mehanske so pa za zganjanje nostalgije.
Pri potapljaških urah s tem meriš, koliko časa si pod vodo. Pred potopom puščico (0) na luneti poravnaš z minutnim kazalcem, da potem sproti vidiš, koliko časa si pod vodo (pogledaš, kaj minutni kazalec kaže na luneti). Zato se pri certificiranih potapljaških urah (ISO 6425) luneta sme vrteti samo v eni smeri - da če se med potopom pomotoma premakne, se lahko čas, ki ga ura kaže, da si pod vodo, samo podaljša, ne moreš pomotoma misliti, da si pod vodo manj časa, kot si zares.
Certificirane potapljaške ure morajo obvezno imeti še nekaj drugih stvari, recimo sekundni kazalec, katerega namen je izključno to, da vidiš, ali ura še deluje.
Kot zanimivost, nekoč so bili pri potapljaških urah precej priljubljeni preprosti kapilarni globinomeri. Tanka cevka, odprta na enem koncu, je bila nameščena po obodu ure. Pod vodo je voda prišla v cevko in pritisk vode je nato čedalje bolj stiskal zrak v njej. Ob cevki je bila natisnjena skala, na kateri si odčital globino.
Zvezdica27 ::
aha. OK.
Torej, to kar imajo zdaj potaplaške računalnike, je bilo včasih to. Najbrž se to ne uprablja več? Je kdo potapljač?
zz
zz
Arey ::
Zvezdica27 je izjavil:
aha. OK.
zz
Se ne. Ni sicer razloga da ne bi, se vedno deluje, sam potapljaski “racunalnik” pocne marsikaj vec kot to. Recimo opozori pri prehitrem dvigovanju na povrsje.
Pride pa taka luneta prav ce moras kaj na priblizno "stopat". Sicer mamo telefone in vse ostalo, ampak met to na uri tudi ne skodi, uporabi, vcasih.
- spremenil: Arey ()
Map ::
Luneta se težko vrti. Uro sem pustil nekaj časa v vodi ter vrtel luneto pod vodo, pa še ni okej. Ali to še parkrat ponovim ali je kak drug postopek?
Ales ::
Dodaj kapljico strojnega olja pod luneto, ter jo potem počasi obračaj, da se olje prenese povsod, kamor se lahko. Se pravi, strojno olje in res, res malo olja.
Je pa zelo verjetno, da bo treba luneto vzeti dol, vse skupaj očistiti in podmazati tesnilo. V tem primeru seveda ne s strojnim oljem ampak s silikonsko mastjo.
- spremenil: Ales ()
Map ::
To sem razmišljal, ampak me je skrbelo, da bi olje potem še bolj zlepilo ta prah.
Koliko sile je potrebno za odstranitev lunete? Ker nisem bil ravno nežen, pa ni dalo nič nikamor.
Zigerion ::
Iščem vsakodnevno uro - ne preveč športno, ampak bolj casual. Cena tam do 1 kEUR.
V oči mi je padla tale: Tissot Gentleman Powermatic 80 Silicium
Ima kdo izkušnje oz. kakšno mnenje o tej uri, ali pa kak alternativni predlog? Tnx!
Yossarian ::
Imam škatlo za ure (6 ur), gornji del je prozoren oz. po mojem neke vrsti pleksi. Vse v redu, problem pa je, ko sem dal v njo uro Citizen EcoDrive, torej na sončno svetlobo. Čez nekaj mesecev sem pa ugotovil, da se ura ne polni in se je tako izpraznila, da sem moral zamenjat akumulatorček. Mi lahko kedo predlaga ustrezno škatlo za recimo 6 ur?
Ales ::
Namontiraj not majhno grow ledico, da bo rastlinica zadovoljna
Ne, resno, se tega še nihče ni spomnil za solarne ure & display boxe? Rabil bi seveda vir energije, ampak ideja niti ni slaba...
Yossarian ::
V sobi ni praktično nikoli dovolj svetlobe, da bi se ura polnila.
Ker jo imam izven škatle, je svetlobe dovolj. Morda je problem v pleksi steklu...
Samael ::
Od daleč se vidi, da je Lineage cenejši. Pač ohišje, številčnica in zapestnica so na nižjem nivoju obdelave.
Ima pa prednost, da ima tudi LCD, štoparico, alarm, lučko...
Tako da s stališča univerzalne uporabnosti je Lineage boljša izbira. In nekaj najboljsega, če hočeš nekaj elegantnejšega od digitalnega casia, s kazalci in vsemi dodatki digitalne ure ter cenovno ugodnega.
Prepričal si me (kot da, sem res rabil... zijam je že kakšno leto, vmes sem kupil kakšnih pet drugih), v dilemi sem bil le ali titanium ali črno, cena je bila enaka, ampak sem itak vedel, da če kupim titanium bom črno želel še vedno :)
In ja, zelo zelo mi je lepa. Zame, po mojem okusu skoraj popolna. Skoraj ker ji do popolnosti manjka kakšne 2mm in pa osvetlitev ne zajame negativnega display, samo številčnico. Kar pa ni dealbreaker - bi jo komot vzel še enkrat :)
Po mojem bom imel zdaj nekaj časa mir. Mogoče še kakšen super sexy "square" z MIP zaslonom, ali pa še to ne, glede na to, kako zelo rad nosim klasične square g-shocke in ne vidim, da bi en spet rahlo drugačen spremenil karkoli.
Samael != Samuel
iKst_ ::
Malo za hec, malo za res, da se razvije debata.
Kupujem diverja. Ni treba, da je dejansko profi certificiran diver, bo pa nošen dnevno, na nato strapu s fitbitom na spodnji strani. Torej, športne aktivnosti, morje, bazen in vse ostalo. Ure ne pazim, tako, da mora biti trpežna.
Lahko je automatic, lahko je quartz, če je kaj bolj zanimivega od navadnega Seiko 4R pa tudi ne škodi.
Budget okrog jurja, mogoče bi se stegnil do 1500. Če je 500 pa tudi ne bom jezen.
Zaenkrat favoriti:
Seiko SPB511
Certina DS Action Diver 40.5mm Powermatic 80
Tissot Seastar 1000
Bulova Oceanographer (devil diver)
San Martin SN0012-GB
Mico Ocean Star 200C (powermatic 80)
Citizen NY0120 (Rumena ali oranžna številčnica)
Na koncu sem vzel Certino Super PH2000M.
Ura ima premer 43mm in debelino 16mm, ampak v živo se nosi lepo, tudi zaradi relativno majhne teže (115g na gumjastem pasčku). Ohišje je iz titana. Je pa seveda kar opazna na roki, kot se spodobi za hardcore potapljaško uro.
Powermatic 80 mehanizem zaenkrat teče lepo, 80 ur rezerve bo prišlo prav, ko bo v rotaciji z drugimi urami. Zraven je gumjast pasček in kovinska zapestnica. Obe zapestnici imata možnost mikro nastavitev na roki, tako, da lahko udobno nosiš cel dan.
Vodotesna do 2000m, lahko se z njo tudi tuširaš ali mogoče celo na hitro zaplavaš :)
Arey ::
16mm, holy :D Meni ze moje 13.5mm ure najedajo in za novo gledam max okoli 12.
Glavno da si zadovoljen, oce ima eno certino iz titana in je dobro narejena.
razor1911 ::
V razmislek:
A ti radio sinhronizacija dobro dela, v stanovanju? Sicer gledam drugo uro ampak neke pripombe so bile čez casiov mehanizem, da ima težave pri
sinhronizaciji, čeprav imho v Sloveniji ne bi smel biti problem saj smo na polovici operativnega dosega oddajnika v Mainflingenu.
iKst_ ::
V razmislek:
Kaj je bistvo videa? Slišal sem AI generiran govor in scenarij in kliknil stran.
Meni na Oceanusih sync pogosto ne gre skozi, če jih imam v sobi v škatli. Ampak imam povezane s telefonom na Bluetooth, tako, da za nastavitev uporabi očitno BT pred radio syncom.
Drugače pa lahko narediš force sync. Držiš gumb 2 sekundi, pa se poveže.
- spremenilo: iKst_ ()
cebelar123 ::
Zdaj sem probal na mojem gulfmasterju in kaze zunaj sprejem L2 do L3. L3 je najboljsi sprejem. Potem pa ko bi se ura morala nastaviti pa gre v error.
Mogoce nimam v nastavitvah ure kaj prav nastavljeno. Ala homecity ali kaj podobnega. Moram preveriti.
- spremenilo: cebelar123 ()
