Forum » Loža » Vodoodporna MyASS
Vodoodporna MyASS
BlueBerry ::
Razlaga 1
Water Resistant: Will resist moisture from accidental splashing, rain, sweat, etc.
Water Resistant 30M: Will resist moisture and can be submerged, no swimming
Water Resistant 50M: Will resist moisture and can also be worn while swimming in shallow water.
Water Resistant 100M: Watch may be worn during snorkeling, skin-diving, and swimming.
Water Resistant 200M: (plus): Watch may be worn during standard scuba diving.
Water Resistant 1000M: Watch may be worn for deep sea diving.
Razlaga 2
Watch manufacturers use other terms to measure water resistance:
A.T.M. (atmosphere), where 1 A.T.M. equals 10 metres.
Bar, where 1 bar equals 10 metres.
Razlaga 3
atm is the abbreviation for the word "atmospheres." An atmosphere is a measure of pressure. 1 atmosphere of pressure is equal to the amount of pressure the air around you exerts on you at sea level.
As you go farther down in a dive, the pressure of the water around you increases.
Your pressure increases by 1 atm for approximately every 33 feet you dive. So, your watch, labeled as only working up to 3atm of pressure, will stop working if you dive more than 66 feet.
Razlaga 4
Water resistant up to 3 ATM (Not suitable for swimming, deep diving, shower etc.).
Prvo kot prvo se mi zdi res lepa marketinška poteza da na uro napišejo vodooporna kar vsakemu laiku da misliti ok lahko plavam, v resnici pa jo lahko nosi le v dežju in pri suhih športih kjer nanjo teče samo znoj...
Zdej me pa zanima kako je s temi zadevami na netu je polno teoretičnih razlag nekaj sem jih podal zgoraj. Zakaj sploh pišem to temo, ker sem nosil že nekaj ur in nikoli ni še bilo tako kot piše in sicer potapljal sem že vse ure, rezultati so bili naslednji:
- Waterresist: Navadna LED ura za 3 € (DX) je doživela majhen šok po potopu potem pa normalno delovala naprej
- Waterresist 30M: Ura brez problema deluje
Zanima me kako je z gumbi, če jih pod vodo pritiskaš menda vse crkne tako se je vsaj zgodilo kolegu sam raje nisem probaval, če bi ura bila dovolj kvalitetna bi moralo vzdržat tudi to?
Razlaga 2
Razlaga 3
Razlaga 4
- premaknil iz Pomoč in nasveti: bluefish ()
NeMeTko ::
Na moji piše, da drži do 100m, pa vseeno ne bom šel preverjati, če to res drži.
Zame je bolj pomembno, da lahko uro po kakšnem svinjskem delu brez skrbi pustim na roki, ko si jih umivam pod tekočo vodo, tako da se opere tudi pašček, kamor se sicer zažre umazanija.
Razlage v smislu Razlaga 4 - Water resistant up to 3 ATM (Not suitable for swimming, deep diving, shower etc.), pa najbrž bolj veljajo za poceni kitajsko robo, ki jo prodajajo na spletu. Če kupiš original uro solidnega proizvajalca, potem imaš vso pravico pričakovati, da bo tudi držala, kar proizvajalec obljublja.
RejZoR ::
To je pa to ko folk NIKOLI ne prebere navodil. Ampak res NIKOLI. Pa ne samo pri urah, pri nobeni stvari. Takoj ko neki ne vejo prec nazaj v štacuno pa udri po prodajalcu. Pol pa jim poveš da vse to lepo piše v navodilih pol pa aja a res. Ja no shit. Seveda, če slovenskih navodil ni zraven pa folk zganja celega hudiča. Pol jih pa itaq ne preberejo. Skratka RTFM.
- spremenil: RejZoR ()
bluefish ::
Prvo kot prvo se mi zdi res lepa marketinška poteza da na uro napišejo vodooporna kar vsakemu laiku da misliti ok lahko plavam, v resnici pa jo lahko nosi le v dežju in pri suhih športih kjer nanjo teče samo znoj...Ne, pri vsaki uri je ob stopnji tesnosti prav dobro napisano, kaj lahko vzdrži. Jasno ko beli dan.
In eno čudno ribo, ki ni nikoli več zamudila? :)
GoPro Hero kamerca zdrži 15m globine. Piše, da zdrži 60, ampak na dah ne morem tako globoko.
kixs ::
Stric je to probal pred leti - sredi jadrana so uro navezali na 100m štrika z nekaj svinca in zadevo vrgli v vodo - nazaj so dobili samo štrik in svinec.
Lepo pise kaj pomeni 100M:
RejZoR ::
O tem sem že govoril v ene dveh drugih temah, to je 100M vertikalnega potopa do statične končne globine 100M. S tem da se mora potapljat relativno počasi.
NeMeTko ::
Prej bi rekel, da se jih dosti ne zaveda, da se prodaja na netu ogromno škart kopij 'made in China', na katerih je oznaka o metrih vodotesnosti zgolj okras, ki so ga prekopirali z originala, nima pa popolnoma nobene veze s tem, koliko ura dejansko zdrži.
BlueBerry ::
@NeMeTko
Tale 3ATM oznaka je kot kaže Wiki pravilna edino, če so jo pisali Kitajci?
Water Resistant mark @ Wikipedia
Water Resistant 3 ATM or 30 m Suitable for everyday use. Splash/rain resistant. NOT suitable for showering, bathing, swimming, snorkelling, water related work and fishing. NOT suitable for diving.
šernk ::
Meni je smešen folk, ki ima vodoodporne telefone in jih stalno perejo pod vodo (seveda v smislu, da je to carsko)
samo čakam kdaj nekaj crkne in da se bom lepo nasmejal zraven
z uro vodoodporno 50m pa nisem imel nikoli težav pri plavanju.
Venum ::
LOL, tej vodoodpornosti telefonom js nebi glih zaupu. Imo je to bol zato, če ti recimo pade v vodo enkrat v svoji življenski dobi ne pa da ga pereš pod vodo.
Malajlo ::
Swatchke so do 30m, pa še nobene nisem menjal zaradi vode, čeprav sem z njimi plaval, se potapljal, skakal (praviloma z rokami naprej na glavo, totej bi pri knofih morala spustiti). Pa tudi knofe sem v vodi pritiskal.
Mi je pa jasmo, da je pritisk vode na dihtunge pri skoku z višine desetih metrov precejšen in da če bi nastal tak majhen ročni akvarij, z garancijo ne morem težiti.
s1m0n ::
IceIceBaby ::
Sej je praktično vse Made in China fyi...
Niti ne. Spodobne ure še vedno delajo švicarji, japonci, nemci... :) Še celo Swatchke so večinoma narejene v Švici.
Na moji piše "Water resistance 600 m (2000 feet)". V navodilih potem vidiš, koliko je ura dejansko odporna, oz. za kakšno uporabo je. (http://www.omegawatches.com/fileadmin/c...
Spodaj piše tudi, da je dejanska odpornost odvisna od vzdrževanja in starosti tesnil. Vsake toliko se splača menjati tesnila (in narediti servis na mehanizmu, če je ura mehanska).
RejZoR ::
Ja, jih delajo če zanje odšteješ po 500 EUR in več (raje več). Tistih za 100-200 EUR načeloma ne delajo v državi kjer se nahaja matična firma. Tud sicer je skor vseeno za modele, ki so strojno sestavljeni. Recimo moj Seiko 5 je sicer japonska firma ampak sestavljajo pa jih se mi zdi v singapurju al pa na kitajskem če se prav spomnim. Je pa celotni mehanizem avtomatika razvit, proizveden in sestavljen iz strani Seiko-ta, tko da je skor vseeno kje jih sestavljajo, ko potegneš črto. Sploh za tak denar.
Ure, ki pa se sestavljajo ročno in imajo ceno v 4 in 5 mestnih everskih številkah, tiste pa načeloma sestavljajo kot sem rekel, ročno in v matični tovarni.
Moja sploh nima ratinga kar se pri Seiko urah smatra kot odporna na kapljice vode, torej pri umivanju rok in kakšen rahel dež...
Malajlo ::
Swatch uporablja celo iste (ok, nekatere) mehanizme kot Tag Heuer. Samo cena je druga. Pa ohišje. Pa ime. Pa design.
IceIceBaby ::
Kje si pa to pobral? Da ne bo kdo res mislil, da ima njegova Swatchka za 100 eur kaj skupnega s TAG Heuer.
Swatch ure so, kolikor vem, vse kvarčne. Če so vmes mogoče naredili kakšnega automatica ima skoraj sigurno ETA mehanizem. TAG Heuer dela večinoma mehanske ure s svojimi mehanizmi. Imajo par kvarčnih modelov, ampak tam mehanizem tako ali tako nima nobene vrednosti.
SmeskoSnezak ::
Torej lahko HD Hero kamera se nosi le v plitvi vodi po zgornji razlagi? Ne morš se niti potapljat na dah z njo? Ali je razlika med waterproof and water resistant?
http://www.mimovrste.com/artikel/136000...
@ Pusti soncu v srce... @
RejZoR ::
Water Resist brez navedene globine/tlaka pomeni, da je naprava odporna na manjše količine vode (npr ko si umivaš roke in malo vode odleti po napravi). Water Proof oz Water Resist z navedeno globino oz tklakom pa pove koliko več vode prenese (oz do kakšne statične globine).
Šimpanz ::
Pa še neki. Meni je trgovec povedal da je treba za vodotesnost nujno zamenjati tesnilo na uri vsako leto in po vsaki zamenjavi baterije. Brez dobrega tesnila je vsaka oznaka na uri brez pomena.
RejZoR ::
Vsako leto je mal pretiravano, mislim da je menjalni interval pri navadnih non diver urah na 3 oz 5 let. Vsako leto se menja samo pri diver urah, kjer je v igri tud sol in se tesnilo hitreje zjebe. Pa tud globine so večje kot pri običajni rabi.
SmeskoSnezak ::
Lahko to s primerom obrazlozis?
RejZoR ::
Moja Seiko Automatic ura ima v navodilih obrazloženo, da samo Water Resist pomeni, da si lahko umivaš roke in te ne skrbi nekaj kaplic vode. Al pa če recimo v rahlem dežju pogledaš na uro in nanjo pade nekaj kapljic. Vse več je navedeno s tlakom in globino, ki je navedena kot statični potop, torej vertikalni potop brez sunkovitih gibov pod samo vodo. To je to. Se pa globina prenaša tud na samo silo, torej lahko uro uporabljaš samo za plavanje, ampak mora imet raing npr 50m oz 5 bar rating, ker pri plavanju, ko z roko "zarežeš" v gladino vode, je ura pod dost velikim stresom udarca ob samo vodo in ta sila lahko potisne vodo skozi tesnila in vijake za nastavljanje same ure.
TAG Heuer dela večinoma mehanske ure s svojimi mehanizmi.Malo morgen.
Do pred nekaj leti ni imel niti enega svojega mehanizma, sedaj pa so jih sicer nekaj začeli delati, za najprestižnejše modele, večinoma imajo pa še vedno dobre stare ETE, pa še Zenith, Ronda in Sellita.
http://www.calibre11.com/tag-heuer-move...
O.
- spremenil: Okapi ()
SmeskoSnezak ::
Rejzor, kak si naj pol razlagam waterproof pri tistem ohišju od kamere?
DimmniBurek ::
SmeskoSnezak je izjavil:
Piše ti v opisu na mimovrste.
There Is No Stronger Drug Than Reality
SmeskoSnezak ::
No, hvala. Torej je le razlika med waterproof in water resistance.
| » | Pametni trak Microsoft BandOddelek: Novice / Windows Mobile | 12438 (10496) | Motion |
| » | "Večna" ročna ura do 1000€ (strani: 1 2 3 )Oddelek: Kaj kupiti | 41747 (32305) | zvery1 |
| ⊘ | Problem z Zapestno UroOddelek: Loža | 5306 (5091) | Gandalfar |
| » | Swatch ureOddelek: Loža | 1694 (1522) | RejZoR |
| » | Športna ura + vodotesna, z merilnim pasom ali zapestje, itd ?Oddelek: Loža | 1459 (1409) | RejZoR |
