Forum » Izdelava spletišč » Web hosting pri somee.com problem z SQL bazo
T_F_7 ::
Hola!
Naredil sem si free paket, prilepil .mdf bazo. Vse štima, tudi queryji. Problem se pojavi pri login aplikaciji na moji spletni strani. Ko se skušam logirat mi vrže ven sledeči problem:
Vprašal sem jih za asistenco in so mi poslali link v katerem je sledeče:
Skratka se z zadevo prvič srečujem in nimam pojma kaj moram naredit. Ima kdo izkušnje s somee.com ali nasploh s bazami in web hosti?
Server Error in '/' Application. A network-related or instance-specific error occurred while establishing a connection to SQL Server. The server was not found or was not accessible. Verify that the instance name is correct and that SQL Server is configured to allow remote connections. (provider: SQL Network Interfaces, error: 26 - Error Locating Server/Instance Specified) Description: An unhandled exception occurred during the execution of the current web request. Please review the stack trace for more information about the error and where it originated in the code. SQLExpress database file auto-creation error: The connection string specifies a local Sql Server Express instance using a database location within the applications App_Data directory. The provider attempted to automatically create the application services database because the provider determined that the database does not exist. The following configuration requirements are necessary to successfully check for existence of the application services database and automatically create the application services database: If the applications App_Data directory does not already exist, the web server account must have read and write access to the applications directory. This is necessary because the web server account will automatically create the App_Data directory if it does not already exist. If the applications App_Data directory already exists, the web server account only requires read and write access to the applications App_Data directory. This is necessary because the web server account will attempt to verify that the Sql Server Express database already exists within the applications App_Data directory. Revoking read access on the App_Data directory from the web server account will prevent the provider from correctly determining if the Sql Server Express database already exists. This will cause an error when the provider attempts to create a duplicate of an already existing database. Write access is required because the web server accounts credentials are used when creating the new database. Sql Server Express must be installed on the machine. The process identity for the web server account must have a local user profile. See the readme document for details on how to create a local user profile for both machine and domain accounts. Source Error: An unhandled exception was generated during the execution of the current web request. Information regarding the origin and location of the exception can be identified using the exception stack trace below. Stack Trace: [SqlException (0x80131904): A network-related or instance-specific error occurred while establishing a connection to SQL Server. The server was not found or was not accessible. Verify that the instance name is correct and that SQL Server is configured to allow remote connections. (provider: SQL Network Interfaces, error: 26 - Error Locating Server/Instance Specified)] System.Data.SqlClient.SqlInternalConnection.OnError(SqlException exception, Boolean breakConnection) +4856727 System.Data.SqlClient.TdsParser.ThrowExceptionAndWarning(TdsParserStateObject stateObj) +194 System.Data.SqlClient.TdsParser.Connect(ServerInfo serverInfo, SqlInternalConnectionTds connHandler, Boolean ignoreSniOpenTimeout, Int64 timerExpire, Boolean encrypt, Boolean trustServerCert, Boolean integratedSecurity, SqlConnection owningObject) +4867325 System.Data.SqlClient.SqlInternalConnectionTds.AttemptOneLogin(ServerInfo serverInfo, String newPassword, Boolean ignoreSniOpenTimeout, Int64 timerExpire, SqlConnection owningObject) +90 System.Data.SqlClient.SqlInternalConnectionTds.LoginNoFailover(String host, String newPassword, Boolean redirectedUserInstance, SqlConnection owningObject, SqlConnectionString connectionOptions, Int64 timerStart) +374 System.Data.SqlClient.SqlInternalConnectionTds.OpenLoginEnlist(SqlConnection owningObject, SqlConnectionString connectionOptions, String newPassword, Boolean redirectedUserInstance) +225 System.Data.SqlClient.SqlInternalConnectionTds..ctor(DbConnectionPoolIdentity identity, SqlConnectionString connectionOptions, Object providerInfo, String newPassword, SqlConnection owningObject, Boolean redirectedUserInstance) +189 System.Data.SqlClient.SqlConnectionFactory.CreateConnection(DbConnectionOptions options, Object poolGroupProviderInfo, DbConnectionPool pool, DbConnection owningConnection) +4868451 System.Data.ProviderBase.DbConnectionFactory.CreateNonPooledConnection(DbConnection owningConnection, DbConnectionPoolGroup poolGroup) +29 System.Data.ProviderBase.DbConnectionFactory.GetConnection(DbConnection owningConnection) +4870764 System.Data.ProviderBase.DbConnectionClosed.OpenConnection(DbConnection outerConnection, DbConnectionFactory connectionFactory) +117 System.Data.SqlClient.SqlConnection.Open() +122 System.Web.Management.SqlServices.GetSqlConnection(String server, String user, String password, Boolean trusted, String connectionString) +82 [HttpException (0x80004005): Unable to connect to SQL Server database.] System.Web.Management.SqlServices.GetSqlConnection(String server, String user, String password, Boolean trusted, String connectionString) +137 System.Web.Management.SqlServices.SetupApplicationServices(String server, String user, String password, Boolean trusted, String connectionString, String database, String dbFileName, SqlFeatures features, Boolean install) +94 System.Web.Management.SqlServices.Install(String database, String dbFileName, String connectionString) +25 System.Web.DataAccess.SqlConnectionHelper.CreateMdfFile(String fullFileName, String dataDir, String connectionString) +395 Version Information: Microsoft .NET Framework Version:2.0.50727.5456; ASP.NET Version:2.0.50727.5456
Instantiated MS SQL databases are not supported! But they still can be used if properly attached.
Before you'll be able to deploy your database to our servers you'll need to create an empty database with Doka panel. See description
After empty MS SQL database is created with Doka panel, you have several deployment options:
If you have a SQL deployment script you can run it
You can restore your database from a backup made from your development MS SQL server
Or you can attach MS SQL database files (*.mdf, *.ldf)
After database is deployed you'll need to update connection settings in your software.
T_F_7 ::
Še 1x sm kopiral datoteki .mdf in ldf v App_Data in potem sem attachau obe kot to zahteva stran. Ob loginu mi vrže novo napako:
Server Error in '/' Application. A network-related or instance-specific error occurred while establishing a connection to SQL Server. The server was not found or was not accessible. Verify that the instance name is correct and that SQL Server is configured to allow remote connections. (provider: SQL Network Interfaces, error: 26 - Error Locating Server/Instance Specified) Description: An unhandled exception occurred during the execution of the current web request. Please review the stack trace for more information about the error and where it originated in the code. Exception Details: System.Data.SqlClient.SqlException: A network-related or instance-specific error occurred while establishing a connection to SQL Server. The server was not found or was not accessible. Verify that the instance name is correct and that SQL Server is configured to allow remote connections. (provider: SQL Network Interfaces, error: 26 - Error Locating Server/Instance Specified) Source Error: An unhandled exception was generated during the execution of the current web request. Information regarding the origin and location of the exception can be identified using the exception stack trace below. Stack Trace: [SqlException (0x80131904): A network-related or instance-specific error occurred while establishing a connection to SQL Server. The server was not found or was not accessible. Verify that the instance name is correct and that SQL Server is configured to allow remote connections. (provider: SQL Network Interfaces, error: 26 - Error Locating Server/Instance Specified)] System.Data.ProviderBase.DbConnectionPool.GetConnection(DbConnection owningObject) +428 System.Data.ProviderBase.DbConnectionFactory.GetConnection(DbConnection owningConnection) +65 System.Data.ProviderBase.DbConnectionClosed.OpenConnection(DbConnection outerConnection, DbConnectionFactory connectionFactory) +117 System.Data.SqlClient.SqlConnection.Open() +122 System.Web.DataAccess.SqlConnectionHolder.Open(HttpContext context, Boolean revertImpersonate) +87 System.Web.DataAccess.SqlConnectionHelper.GetConnection(String connectionString, Boolean revertImpersonation) +221 System.Web.Security.SqlMembershipProvider.GetPasswordWithFormat(String username, Boolean updateLastLoginActivityDate, Int32& status, String& password, Int32& passwordFormat, String& passwordSalt, Int32& failedPasswordAttemptCount, Int32& failedPasswordAnswerAttemptCount, Boolean& isApproved, DateTime& lastLoginDate, DateTime& lastActivityDate) +815 System.Web.Security.SqlMembershipProvider.CheckPassword(String username, String password, Boolean updateLastLoginActivityDate, Boolean failIfNotApproved, String& salt, Int32& passwordFormat) +105 System.Web.Security.SqlMembershipProvider.CheckPassword(String username, String password, Boolean updateLastLoginActivityDate, Boolean failIfNotApproved) +42 System.Web.Security.SqlMembershipProvider.ValidateUser(String username, String password) +78 System.Web.UI.WebControls.Login.AuthenticateUsingMembershipProvider(AuthenticateEventArgs e) +60 System.Web.UI.WebControls.Login.OnAuthenticate(AuthenticateEventArgs e) +119 System.Web.UI.WebControls.Login.AttemptLogin() +115 System.Web.UI.WebControls.Login.OnBubbleEvent(Object source, EventArgs e) +101 System.Web.UI.Control.RaiseBubbleEvent(Object source, EventArgs args) +37 System.Web.UI.WebControls.Button.OnCommand(CommandEventArgs e) +118 System.Web.UI.WebControls.Button.RaisePostBackEvent(String eventArgument) +166 System.Web.UI.WebControls.Button.System.Web.UI.IPostBackEventHandler.RaisePostBackEvent(String eventArgument) +10 System.Web.UI.Page.RaisePostBackEvent(IPostBackEventHandler sourceControl, String eventArgument) +13 System.Web.UI.Page.RaisePostBackEvent(NameValueCollection postData) +36 System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +1565 Version Information: Microsoft .NET Framework Version:2.0.50727.5456; ASP.NET Version:2.0.50727.5456
| » | C# težavaOddelek: Programiranje | 4953 (3799) | mladec |
| » | Internetna stran in domač serverOddelek: Omrežja in internet | 4654 (4490) | Seljak |
| » | [C#] Query in codeOddelek: Programiranje | 2184 (1928) | iggy1 |
| » | [ASP.NET] problemOddelek: Izdelava spletišč | 2655 (2305) | Microsoft |
| » | OleDb in visual studio .netOddelek: Programiranje | 2682 (2461) | Kovalchuk |
