Forum » Operacijski sistemi » BSOD
BSOD
meandmouse ::
Pozdravljeni,
V zadnjem dnevu mi je trikrat vrglo 'plavi ekran'
Sistem: P7P55D-E PRO, i5-750
1.Dump File : 062512-13369-01.dmp
Crash Time : 25.6.2012 21:10:47
Bug Check String : SYSTEM_SERVICE_EXCEPTION
Bug Check Code : 0x0000003b
Parameter 1 : 00000000`c0000005
Parameter 2 : fffff880`0107da45
Parameter 3 : fffff880`0ac39930
Parameter 4 : 00000000`00000000
Caused By Driver : fltmgr.sys
Caused By Address : fltmgr.sys+4a45
File Description :
Product Name :
Company :
File Version :
Processor : x64
Crash Address : ntoskrnl.exe+7f1c0
Stack Address 1 :
Stack Address 2 :
Stack Address 3 :
Computer Name :
Full Path : C:\Windows\Minidump\062512-13369-01.dmp
Processors Count : 4
Major Version : 15
Minor Version : 7601
Dump File Size : 292.208
2.Dump File : 062612-12355-01.dmp
Crash Time : 26.6.2012 11:06:21
Bug Check String : IRQL_NOT_LESS_OR_EQUAL
Bug Check Code : 0x0000000a
Parameter 1 : 00000000`00000080
Parameter 2 : 00000000`00000002
Parameter 3 : 00000000`00000001
Parameter 4 : fffff800`030e94ff
Caused By Driver : ntoskrnl.exe
Caused By Address : ntoskrnl.exe+7f1c0
File Description : NT Kernel & System
Product Name : Microsoft® Windows® Operating System
Company : Microsoft Corporation
File Version : 6.1.7601.17835 (win7sp1_gdr.120503-2030)
Processor : x64
Stack Address 1 :
Stack Address 2 :
Stack Address 3 :
Computer Name :
Full Path : C:\Windows\Minidump\062612-12355-01.dmp
Major Version : 15
Dump File Size : 292.176
3.Dump File : 062612-26832-01.dmp
Crash Time : 26.6.2012 14:43:21
Bug Check String : MEMORY_MANAGEMENT
Bug Check Code : 0x0000001a
Parameter 1 : 00000000`00041287
Parameter 2 : 00000000`21fb8000
Parameter 3 : 00000000`00000000
Processor : x64
Stack Address 1 :
Stack Address 2 :
Stack Address 3 :
Computer Name :
Full Path : C:\Windows\Minidump\062612-26832-01.dmp
Major Version : 15
Ima kdo idejo kaj bi lahko povzročalo te probleme?
Hvala v naprej . . .
File Description :
Product Name :
Company :
File Version :
Processor : x64
Stack Address 1 :
Stack Address 2 :
Stack Address 3 :
Computer Name :
Major Version : 15
Processor : x64
Stack Address 1 :
Stack Address 2 :
Stack Address 3 :
Computer Name :
Major Version : 15
Processor : x64
Stack Address 1 :
Stack Address 2 :
Stack Address 3 :
Computer Name :
Major Version : 15
- spremenil: meandmouse ()
AlienRR ::
1.
STOP 0x0000003B: SYSTEM_SERVICE_EXCEPTION
Usual causes: System service, Device driver, graphics driver, memory.
2.
STOP 0x0000000A: IRQL_NOT_LESS_OR_EQUAL
Usual causes: Kernel mode driver, System Service, BIOS, Windows, Virus scanner, Backup tool, compatibility.
3.
The MEMORY_MANAGEMENT bug check has a value of 0x0000001A.
This indicates that a severe memory management error occurred.
Pri vseh treh se najde ntoskrnl.exe, preveri kaj dela ta proces in k čemu spada. Preglej tudi RAM, ter nadgradi gonilnike za grafično.
Bi še kaj napisal, vendar sem v gužvi.
2.
3.
You can override the laws of thermodynamics with sufficient sudo access.
meandmouse ::
Gonilniki so vsi nadgrajeni, bom še malo bolj podrobno pogledal kaj dela ta proces ntoskrnl.exe
Cold1 ::
Product Name : Microsoft(R) Windows(R) Operating System
Gre se, seveda, za jedro sistema Windows.
Glede na napake pa bi sam posumil na okvaro pomnilnika ali matične plošče ali pa napajalca; seveda pa je možna tudi prisotnost kake škodljive programske opreme (si nameščal kak nov program, morda kako orodje za optimizacijo Oken ali kaj podobnega), povzročitelj pa je lahko tudi kaka okužba.
meandmouse ::
Sem preizkusil rame z memtest in ni našlo nič napak. Nameščal nisem nič novega, verjetno bom moral na novo instalirati windowse . . .
| » | Blue Screen (ntoskrnl.exe)Oddelek: Pomoč in nasveti | 3076 (1927) | fulgur |
| » | Problem z Radeonom 4870 512mbOddelek: Pomoč in nasveti | 3558 (3406) | Specijalec |
| » | Težava z računalnikom - prosim za pomočOddelek: Pomoč in nasveti | 5945 (5674) | iloveboobz |
| » | Modri zaslon na win 7Oddelek: Pomoč in nasveti | 2182 (1883) | rsroki |
| » | prosim za pomoč- kako odpraviti tole napako...Oddelek: Pomoč in nasveti | 5020 (4529) | Mavrik |
