Rabim pomoč za nakup releja
peter1234 ::
Zadeva je taka.
imam dataloger dt80 in bi rad z njim krmilil el.m ventil. ventil je 12VDC napajan, porabo ob delovanju ima 0,6W.
lLogger pa daje na izhodu 1D napetost navodila so pa taka:
This can sink up to 100mA @ 30Vdc so it
can drive a low voltage actuator or relay or LED directly. A 47k pull-up resistor (to approx. +4V) is also included,
allowing logic devices to be driven.
Zanima me kaki rele rabim, da ga bo loger vklopil in da bo ventil delal.
Hvala za pomoč.
lp Peter
Vodovod
82146 (1073) Likalnik
Rele 12V vprašanje
72605 (2412) mirator
Vezava rele-ja
75854 (4207) tezej
Po novem na udaru hekerjev tudi avtomobili (strani: 1 2 )
Oddelek: Novice / Varnost
5625269 (22054) Pyr0Beast
