Forum » Mobilne tehnologije » Telefonski imenik
Telefonski imenik
STASI ::
Živjo.
Izgubil sem svoj Samsungov telefon. Na srečo sem že imel backup konatktov. Kontakti so v formatu .spb .
Nov telefon je nokia. Sedaj kako bi lahko uvozil kontakte iz backupa v novo nokio? V Kies ne morem shraniti v drugo format kot .spb, hočem pa shraniti v .csv ali drug pametni format, ki ga bere Nokia Suite.
Any ideas?
Any ideas?
"WAR IS PEACE, FREEDOM IS SLAVERY, IGNORANCE IS STRENGTH"
abcčdefghijklmnoprsštuvzž
V-i-p ::
To ne pomaga?
Open Kies
Open your saved spb file
Select all the contacts
Click SAVE
Select a location on your PC, create a directory called Contacts.
Browse to this directory and save the file using VCF as your file extension
Yes it doesn't give VCF as a file type option so just manually type it.
Check the directory and it should be full of vcf files.
Copy the directory to your Phone SD Card and import using contacts import.
Open Kies
Click SAVE
STASI ::
Ne dela
| » | Prenos imenika iz Nokia na Galay S7Oddelek: Mobilne tehnologije | 1748 (1636) | harvey |
| » | Razbit telefon, kako do kontaktov na google serverjuOddelek: Mobilne tehnologije | 2879 (2226) | Zmajc |
| » | Kloniranje tabliceOddelek: Mobilne tehnologije | 2524 (2018) | Cervantes |
| » | Apache - localhost JA, IP naslov NEOddelek: Omrežja in internet | 7286 (7145) | ManDriver |
| » | vkljucevanje txt datoteke v ...Oddelek: Programiranje | 2019 (1795) | webblod |
