Arduino programiranje koračnega motorja
PriesteR ::
Zdravo,
že nekaj časa brskam po internetu, kako naj sprogramiram, da bom lahko krmilil koračni motorček z arduinotom.
nekaj primerov sem našel in delujejo čist na preprost način
primer
 stepper.setSpeed(spd);
  stepper.step(rand);
  delay(1000);
nekaj je pa drugih primerov in so čisto zakopmlicirani
primer
int motorPins[] = {8, 9, 10, 11};
int count = 0;
int count2 = 0;
int delayTime = 500;
int val = 0;
void setup() {
  for (count = 0; count < 4; count++) {
    pinMode(motorPins[count], OUTPUT);
void moveForward() {
  if ((count2 == 0) || (count2 == 1)) {
    count2 = 16;
  count2>>=1;
  for (count = 3; count >= 0; count--) {
    digitalWrite(motorPins[count], count2>>count&0x01);
  delay(delayTime);
void moveBackward() {
    count2 = 16;
  count2>>=1;
    digitalWrite(motorPins[3 - count], count2>>count&0x01);
  delay(delayTime);
void loop() {
  val = analogRead(0);
  if (val > 540) {
    // move faster the higher the value from the potentiometer
    delayTime = 2048 - 1024 * val / 512 + 1;
    moveForward();
  } else if (val < 480) {
    // move faster the lower the value from the potentiometer
    delayTime = 1024 * val / 512 + 1;
    moveBackward();
  } else {
    delayTime = 1024;
imam tale koračni motorček http://www.eminebea.com/en/product/rota...
kakšna pomoč kako naj to sprogramiram?
java regex group count
Oddelek: Programiranje
6948 (885) smacker
Python
203527 (2213) d_DJ
Pomoč C++
71788 (1507) samo111
Arduino in luči (strani: 1 2 )
9814780 (12406) FX6300B
php array in path določenega keya:
Oddelek: Izdelava spletišč
151770 (1598) HardFu
