Ivy Bridge Extreme
Ivy Bridge Extreme
Janac ::
kaj se ze ve:
Ivy Bridge-E will be compatible with today's Intel X79 platform, and LGA2011 socket.
Ivy Bridge-E is slated for Q4 2012
viri: http://www.techpowerup.com/155307/Ivy-B...
Isotropic ::
nič novega torej
najboljse si pa kar pozabil
Suddenly, Sandy Bridge-E makes for a sweeter deal because its platform longevity (for upgrades) is at least two years. Ivy Bridge-E, like Ivy Bridge LGA1155, will be built on the 22 nanometer silicon fabrication process. We don't expect Ivy Bridge-E to be much more than an optical shrink of today's Sandy Bridge-E silicon, but the shrink could leave scope for enabling some of its components otherwise locked out for the Core processor family. Sandy Bridge-E silicon physically holds 8 cores and 20 MB of L3 cache, but the fastest Core processor based on it has just 6 of those cores, and 15 MB of L3 enabled. The source at XFastest says that while Ivy Bridge-E is slated for Q4 2012, the LGA1155 Ivy Bridge will launch across Q1 and Q2 of 2012 (March~April).
:O
ne_ti_si ::
imam vprašanja!!! in sicer, ali se zdaj splača kupit SB-E, ali se splača počakati na IB-E... kateri bo boljši?? ali bodo imeli IB-E kakšne težave z 22nm tehnologijo, pregrevanjem oz karkoli?? je že kaj znano o tem(sam ne najdem skorajda nič konkretnega na netu)...in koliko jeder bo imel IB-E, ter če mogoče kdo ve, kako se bodo "približno" gibale cene??? ja in še to, se že kje kaj najde kateri bo imel večji OC potencial????
v glavnem, ali bo IB-E na LGA 2011 podnožju zmogljivejša in boljša izbira od SB-E, se splača počakati????
za odg. se že v naprej zahvaljujem...
ASUS Rampage III Extreme / i7 950 4.5Ghz / Nvidia 2x GTX570 SLI 950/1150/1800
G-Skill 3x2GB / X-fi Fatal1ty Platinum / WD1002FAEX SATA 6Gb / SSD Corsair 64GB
EKWB CPU + GPU / SAITEK R.A.T.7 / Logitech G15, G35, THX Z5500 / Corsair HX1000W
koliko ::
IB-E je že prestavljen za konec l. 2013. Kar pomeni zate, zame realno nakup v začetku l. 2014. Dve leti čakanja za nekje 20-30 procentov kolikor bodo performance zrasle...mislim, da se ne splača več čakat.
Sedajšnje matične plošče 2011 naj bi podpirale IB-E vendar je jasno kaj bodo imele kmalu naslednje:
1.nativni USB 3 support (ne preko 3rd party controllerja kot sedaj),
2.PCI-E 3.0 support (pri sedajšnjih ga naj ne bi bilo - mogoče pride z novejšimi biosi)
3.Sedajšnji chipset omogoče samo 2 SATA 6gbs vhoda, ostali so preko 3rd party controlerjev in so cca 20-30% počasnejši (glej guru3d test za plato asus rog extreme) itd.
4.najbolj pomembna funkcija, ki je bila opuščena pri sedajšnjem X79 čipovju: "PCI Express 3.0 storage uplink to the CPU" (beri strica googla).
Z 90% gotovostjo trdim, da za IB-E 2011 pride nov ali vsaj izboljšan X79 chipset ven ;)
  • spremenil: koliko ()
koliko ::
Evo tole sem mislil:
http://xtreview.com/addcomment-id-22094...
se pravi, če kupuješ zdej - počakaj še nekaj tednov na c1 X79 plate.
Isotropic ::
koliko je izjavil:
daj link
gendale ::
če ne rabiš 6 jeder pol ne vidim fore
http://pastebin.com/QiWny5dV
Isotropic ::
prevec kesa
alpa mem throughput. pri nekaterih aplikacijah se fajn pozna. me pa zanima, kaj bo mel haswell-e novega s tistim interposerjem in kaksnim cachom na njem. tisto bi znalo biti hudo, sploh z avx2, ki ga sedaj (avx1) bremza malo cache (premalo, po domace povedano)
ne_ti_si ::
IB-E čakat do konec l. 2013? kako to? pa slučajno pride kdaj v BLIŽNJI PRIHODNOSTI kakšen IB, ki bo šel na lga 2011 plato???? ker ta i7 IB, ki je že zunaj ni neki stroj, oz bi naj imel nekaj težav....
kot sem že vprašal kdaj pride kakšen nov IB za lga 2011 podnožje, pa pomožnosti z šestimi jedri???
platformo imam namen menjati do konec leta in me zdaj zanima, če pride do takrat kaj pametnega ven, ali kupim c1 x79 plato + SB-E????
Isotropic ::
kaj bos pa delal z racunalnikom?
ne_ti_si ::
se mi je zdelo da bo nekdo postavil to vprašanje... v glavnem rad bi IB, z šestimi jedri na x79 čipu...... do kdaj bo treba čakat???
Janac ::
najmanj kaksno leto
ne_ti_si ::
ampak koliko sem jaz čekiral po netu, sem videl da IB-E pride do konec leta 2012
Isotropic ::
ne_ti_si je izjavil:
kupi zaenkrat sb-e, saj ne bo velike razlike, razen nekaj v porabi. par 10w pa tut ni celo vesolje.
ne_ti_si ::
že, ampak šele IB bi naj podpiral pci-e 3.0, itd.. in želim si, da ko kupim novo stvar, da nebo zastarela v roku pol leta!!! glede porabe me sploh ne skrbi...važno mi je, da bo cpu hladen, ter da bo imel VELIK OC potencial, saj bom hladil z vodo in pa seveda, a bo cpu ZELO zmogljiv!!!....
Alo, a ste kle eni sploh pismeni??
SB-E ima 40 PCIe 3.0 linij. A to ni uredu?
Poleg tega, je 3820 pocasnejsi ze od 2600k, kaj sele 3770k, torej se splaca na lga2011 ce kupis cpu za 500€.
In ne, noben lga2011 cpu, razen mogoce kaksen low power Xeon, ne bo hladen, pa tudi ogromnega OC potenciala ne bo imel, vsaj na zraku ali vodi ne.
Janac ::
3820 ni pocasnejsi od 2600k ? HALO?
Isotropic ::
zakaj ze, ce je 3820 200mhz hitrejsi in ima 2mb vec cache (od 2600)? razlika je, samo ne v ms office...
pa tut navijat se da, cist fajn, sam ajd, rabis boljse hlajenje, to je res.
Ok, v najboljsem primeru je enako hiter. Se splaca pogledat kaksen test, mimogrede. Pa ne mi zdej kazat kaksnega, kjer je za misji k... hitrejsi.
Janac ::
sem veliko testov pregledal in 3820 je malo pocasnejsi od 2700k
ne_ti_si ::
ok...torej prvo kot prvo itak mislim kupit GPU, ker trenutna platforma še je dovolj dobra za moje potrebe(glej podpis)... zdaj mene samo zanima, na kaj oz če se sploh splača čakat na nov IB cpu, ali kupim R4E + SB-E 3930K...?
Isotropic ::
kupi sb-e, ce jo rabis ze sedaj.
alpa taprvo nov gpu (tle lahko magar pocakas na gk110 naslednje leto, bo teh shit) in zraven se cpu.
ne_ti_si ::
kot sem že povedal, ne rabim še zdaj takoj nujno platforme...prvo GPU, kasneje CPU in zato sprašujem, če počakam na nove IB ali kar kupim SB-E, z razlogom, ker se ne splača čakati....? dugače pa ali bo čez čas šel IB na lga2011 ali ne?? pa še nekaj, kako to da se npr. 2600k navije tam do 5ghz bp, ti novi SB-E pa ne????
kaj pa pravite na i7 3770K.....???
Isotropic ::
ne vem, kuk se navija 3930k, manj kot 2600k obviously, ker ima vec jeder in imas verjetno probleme s tdp. alpa moznostjo za rahlo slabse jedro alpa kej.
3770k se slabse navija kot 2600k.
ce res hoces ib-e, pocakaj na naslednje leto in ga kupi skupaj z naslednjo nv kartico, gk110. ta bo orenk hitrejsa od sedanjih... naslednja generacija v bistvu.
ce ze ne ves, kupi graficno in pocakaj se eno leto za haswella. tko bi jaz naredil :)
koliko ::
Intel posodablja extreme serijo na 2-3 leta. Če kdo misli da bo pri IB-e kej drugače, se pošten moti.
Link:
http://www.techspot.com/news/47849-ivy-...
Odvisno od potrebe. Ce sluzis z racunalnikom velke dnarje, ni problema dat mnogo dnarja za cpu in plato, za kaksne igre in podobne stvari je pa brez veze.
Sicer odlocitev posameznika, koneckoncev se vsak sam odloci, kam bo dal svoj denar.
Isotropic ::
koliko je izjavil:
Link:
na zacetku je bilo receno, da bo prisla toliko za IB, kot je bil sb-e za sb. ne vem vec kuk, 1/2 al 3/4 leta.
TechBeats ::
Zgleda, da bomo le videli IB-E, ampak ne tako kmalu >> Q3 2013.
8core IB-e here i come lol :D
Intel's next high-end desktop (HEDT) platform, codenamed "Ivy Bridge-E," is slated for Q3-2013, according to the latest platform road-map slide sourced by VR-Zone. According to the leaked slide, launch of Ivy Bridge-E Core i7 processors follows that of Core "Haswell" socket LGA1150 processors (Q2-2013). What's more, the upcoming Ivy Bridge-E chips will be compatible with existing socket LGA2011 motherboards, based on Intel X79 Express chipset.
Intel's next-generation Ivy Bridge-E chips are up-scaled versions of today's Core "Ivy Bridge" chips, built on the same 22 nm process, with more processing cores, memory channels, cache, and PCI-Express 3.0 certified system interfaces. It remains to be seen if Intel launches a new chipset to go with the new processor, or retains the X79 chipset with a few minor updates in the form of steppings. The company retained its X58 Express chipset over the first two HEDT processor generations (45 nm Core i7 "Bloomfield" and 32 nm Core i7 "Westmere").
http://www.techpowerup.com/forums/showt...
Intel bo pred tem izdal še en 6core 3970x SB-e enkrat okoli novembra 2012..
AciD TriP
fr4nc ::
Očitno bo kamlu potreba po 8 jedrih če se Itelu nekako "mudi"...
bluefish ::
Potreba je že sedaj.
fr4nc ::
Ja no... pri zelo malo programih, ki znajo to lepo izkoristiti...
Sej nevem kaj pol cakate. SB se ze dobi nekaj casa v 8 jedrni razlicici.
http://geizhals.at/eu/?cat=cpuppro&xf=2...
Ce pa mislite, da bo potem kaj cenej.... Ha, ha. :))
gendale ::
kaj je fora, da so pri extreme procesorjih eno generacijo zadaj?
saj pri sb/ib je dost vseeno, ker ni velike razlike med njima, ampak haswell naj bi prinesel več novosti
TechBeats ::
Ane, to ti je pa intel..
Samo, če bi pa že sedaj izdali Haswell Enthusiast, potem pa AMD res ne bi imel za burek :))
AciD TriP
TechBeats ::
Edit:
Baje je AMD vzel nazaj Jim Kellerja iz Appla, lahko da bo AMD vrnil močan udarec. :D
AMD has managed to rehire Jim Keller from Apple. Keller was the lead architect of the K8 architecture and of the x86-64 specification, he will leave his post as a director in the platform architecture group at Apple to take up a position as AMD Corporate Vice President and Chief Architect for CPU cores.
AMD announced today that Jim Keller, 53, has joined the company as corporate vice president and chief architect of AMD's microprocessor cores, reporting to chief technology officer and senior vice president of technology and engineering Mark Papermaster. In this role, Keller will lead AMD's microprocessor core design efforts aligned with AMD's ambidextrous strategy with a focus on developing both high-performance and low-power processor cores that will be the foundation of AMD's future products...
http://www.guru3d.com/news/amd-brings-b...
AciD TriP
Zeratul ^^ ::
#yolo
Isotropic ::
TechBeats je izjavil:
Edit:
vprasanje kdaj
piledriver je ze tik pred izidom, steamroller imajo verjetno arhitekturo ze zakljuceno in je v kaksnem testingu/ verifikaciji le-te (pred proizvodnjo)
excavator maybe?
Janac ::
Nic novega razen tega da pride poletje -jesen 2013, torej Q3 2013. Vse kaže da takrat tut Haswell izsel.
http://www.tomshardware.com/news/Ivy_Br...
Janac ::
TechBeats ::
hja xD
Sicer pa tale link od Janac vidim, da sem se pravilno odločil, sploh pri 4.7Ghz nima konkurence, ok razen v generičnem testu kot je recimo Cinebench
Sem pa polaufal Cienebench 10 in premagam 3970X 12 core, da ne omenjam single perf. :D
http://www.anandtech.com/show/7255/inte...
AciD TriP
klinker ::
Ni vse v benchih in stevilkah. Tak sistem kupi nekdo ki dejansko rabi tolko jeder in vec kot 4 slote za ram, pa ce to se navijes kot si ga ti, ostanes krepko zadaj ;)
TechBeats ::
Že že, samo cpu za 300€ vs 1000€ je pa tud nekaj ;)
AciD TriP
klinker ::
Ja ok, ti si pa tudi kot x45...mas ne X verzijo za 500€ ki je prakticno isti smorn, ne :)
Mnenje o Matični Plošči in Procesorju (strani: 1 2 )
6814703 (14011) touchspeed
konfig do 650EUR (strani: 1 2 3 )
12120958 (19865) Predator ^^
Intel LGA 2011 CPU, Socket R
103084 (2916) TechBeats
Izšli trije novi procesorji Sandy Bridge E
Oddelek: Novice / Procesorji
319033 (6308) Dr_M
Sandy Bridge-E bo sledil trenutnemu poimenovanju
218262 (7400) Dr_M
