Samsung Galaxy S - Ice Cream Sandwich
maja666 ::
Sem nova lastnica Galaxy S1, sedaj želim naložiti nanj Ice Cream Sandwich, mi lahko kdo to pomaga?
T(he) Boss ::
Kawl6 ::
maja666 ::
Kawl6 je izjavil:
http://slo-android.si/index.php
kje pa tukaj lahko najdem vodič ali kaj podobnega?
Mr Hilter ::
Sam bom še malo počakal s prehodom na ICS, 2.3.6 je trenutno zelo v redu.
http://forum.xda-developers.com/showthr...
Kopirana navodila:
- First time flashing ICS to your Galaxy S (or coming from another ROM)?
Root your device and install ClockworkMod Recovery.
Reboot into Recovery using 3-button-combo
Do a Nandroid backup!
WIPE (wipe data/factory reset + wipe cache partition)
Install the ROM from internal sdcard using ClockworkMod Recovery
Optionally install the Google Addon
WIPE again or Calendar Sync will not work.
- Upgrading from CM7?
Do a Nandroid Backup!
- Coming from onecosmic's ICS build?
Reboot into recovery and WIPE (wipe data/factory reset + wipe cache partition)
If radio doesn't work, go back to Samsung ROM and flash from there.
- Upgrading from another build of ICS by teamhacksung?
Note: The upgrade process from CM7 to ICS is automatic, but downgrading from ICS to CM7 (or restoring Nandroid) requires flashing twice. Once from ICS and again from CM7's recovery.
Kawl6 ::
maja666 je izjavil:
Kawl6 je izjavil:
Moraš se prijavit in imaš detaljna navodila za kar želiš;).Pobrskaj po forumu.Čeprav ti IceCream odsvetujem, vsaj meni je popolnoma zabrejkal SII,raje ti priporočam DarkyROM.:)
bobby ::
maja666, vse to ti fantje pišejo za custom ROM-e, uradno S1 ne bo dobil ICS-a. drgač pa so te v pravo smer obrnil, zej je treba samo še brat :)
zupicaa ::
Malo offtopic, kdaj uradno pride 4.0 za Galaxy S2?
Letos.
bobby ::
Enkrat :)
ko ga bodo zafilal s tistim svojim crapewarom pa k se jim bo zazdel, da bo za silo še kao user expirience na "high",,..
probal 3 mašince , htc, samsung in še en sgs1, zdej imam nexus S prejšnje generacije pa zadeva dela, nobenga sranja, ics je že uradno zunaj za njega,... nikol več na ala sgs pa htc, če lahko google expiriance samo z google phonom dobiš.
maja666 ::
kje pa dobim DarkyROM
Na internetih.
Kawl6 ::
maja666 je izjavil:
http://www.darkyrom.com/community/index...
Sam se nisem matral s tem (preeeveč zakomplicirano), moj mlajši bratec pa obvlada zadevo v nulo in ve kaj dela:).On je bil tudi krivec za inštalacijo IceCreama;((
Lahko ti pošljem njegov mail pa se sama zmenita kako in kaj.
maja666 ::
Kawl6 je izjavil:
maja666 je izjavil:
ja prosim :)
krop ::
Darky je zgodovina.
Prijavi se na slo-android stran in preberi zadnjih 10 strani v temi Samsung galaxy S. Sem tam spisal navodila ;)
cyanogen boot za S Note 1
Oddelek: Operacijski sistemi
61201 (1060) ezikielrage
Custom ROM za Nexus S pomoč
Oddelek: Mobilne tehnologije
61266 (1100) klinker
Huawei IDEOS X5 U8800
234481 (3821) errhec
nazaj na gingerbread
272007 (1278) simone
[SGS] Bo Jelly Bean deloval?
51042 (956) Xserces
