Forum » Mobilne tehnologije » Samsung Galaxy S - Ice Cream Sandwich
maja666 ::
Sem nova lastnica Galaxy S1, sedaj želim naložiti nanj Ice Cream Sandwich, mi lahko kdo to pomaga?
maja666 ::
Mr Hilter ::
Sam bom še malo počakal s prehodom na ICS, 2.3.6 je trenutno zelo v redu.
http://forum.xda-developers.com/showthr...
Kopirana navodila:
- First time flashing ICS to your Galaxy S (or coming from another ROM)?
Root your device and install ClockworkMod Recovery.
Reboot into Recovery using 3-button-combo
Do a Nandroid backup!
WIPE (wipe data/factory reset + wipe cache partition)
Install the ROM from internal sdcard using ClockworkMod Recovery
Optionally install the Google Addon
WIPE again or Calendar Sync will not work.
- Upgrading from CM7?
Do a Nandroid Backup!
- Coming from onecosmic's ICS build?
Reboot into recovery and WIPE (wipe data/factory reset + wipe cache partition)
If radio doesn't work, go back to Samsung ROM and flash from there.
- Upgrading from another build of ICS by teamhacksung?
Note: The upgrade process from CM7 to ICS is automatic, but downgrading from ICS to CM7 (or restoring Nandroid) requires flashing twice. Once from ICS and again from CM7's recovery.
Kopirana navodila:
Kawl6 ::
http://slo-android.si/index.php
kje pa tukaj lahko najdem vodič ali kaj podobnega?
Moraš se prijavit in imaš detaljna navodila za kar želiš
bobby ::
maja666, vse to ti fantje pišejo za custom ROM-e, uradno S1 ne bo dobil ICS-a. drgač pa so te v pravo smer obrnil, zej je treba samo še brat :)
bobby ::
Enkrat :)
ko ga bodo zafilal s tistim svojim crapewarom pa k se jim bo zazdel, da bo za silo še kao user expirience na "high",,..
probal 3 mašince , htc, samsung in še en sgs1, zdej imam nexus S prejšnje generacije pa zadeva dela, nobenga sranja, ics je že uradno zunaj za njega,... nikol več na ala sgs pa htc, če lahko google expiriance samo z google phonom dobiš.
Kawl6 ::
kje pa dobim DarkyROM
http://www.darkyrom.com/community/index...
Sam se nisem matral s tem (preeeveč zakomplicirano), moj mlajši bratec pa obvlada zadevo v nulo in ve kaj dela
Lahko ti pošljem njegov mail pa se sama zmenita kako in kaj.
maja666 ::
Sam se nisem matral s tem (preeeveč zakomplicirano), moj mlajši bratec pa obvlada zadevo v nulo in ve kaj dela.On je bil tudi krivec za inštalacijo IceCreama
ja prosim :)
krop ::
Darky je zgodovina.
Prijavi se na slo-android stran in preberi zadnjih 10 strani v temi Samsung galaxy S. Sem tam spisal navodila ;)
| » | cyanogen boot za S Note 1Oddelek: Operacijski sistemi | 1200 (1059) | ezikielrage |
| » | Custom ROM za Nexus S pomočOddelek: Mobilne tehnologije | 1266 (1100) | klinker |
| » | Huawei IDEOS X5 U8800Oddelek: Mobilne tehnologije | 4478 (3818) | errhec |
| » | nazaj na gingerbreadOddelek: Mobilne tehnologije | 2004 (1275) | simone |
| » | [SGS] Bo Jelly Bean deloval?Oddelek: Mobilne tehnologije | 1040 (954) | Xserces |
