(Actionscript oz. Flex 4) združitev dveh kod
r0ks0n ::
Pozdravljeni!
Sam nisem programer ampak sem po enem tutorialu izdelal preprost RSS bralnik za Android/iOS. Žal tutorial ne vključuje kako v Item dodati sliko iz RSS feeda, zato se obračam na vas. Tole je moja koda, v katero bi rad dodal kodo iz spodnjega tutoriala, ki govori o tem, kako dobiti iz RSS description sliko:
<?xml version="1.0" encoding="utf-8"?>
<s:View xmlns:fx="http://ns.adobe.com/mxml/2009"
		xmlns:s="library://ns.adobe.com/flex/spark"
		xmlns:rssreader="services.rssreader.*"
		title="" viewActivate="getDetails()">
	<fx:Script>
		<![CDATA[
			import valueObjects.Item;
			[Bindable] private var rtitle:String;
			[Bindable] private var rdate:String;
			[Bindable] private var rcreator:String;
			[Bindable] private var rlink:String;
			[Bindable] private var rdesc:String;
			private function getDetails():void
				var p:RegExp = /(&quot;)/ig;
				var thisItem:Item = data as Item;
				rtitle = thisItem.title;
				rdate = thisItem.pubDate;
				rcreator = thisItem.author;
				rlink = thisItem.link;
				rdesc = thisItem.description;
				rtitle = rtitle.replace(p, "");
	</fx:Script>
	<fx:Declarations>
		<s:CallResponder id="getDataResult"/>
		<rssreader:Rssreader id="rssreader"/>
	</fx:Declarations>
	<s:navigationContent>
		<s:Button label="Nazaj" click="navigator.popView()" />
	</s:navigationContent>
	<s:BorderContainer top="0" bottom="0" left="0" right="0"
					   backgroundColor="#FFFFFF">
		<s:Label left="20" right="20" top="42" height="61"
				 backgroundColor="#FFFFFF" color="#000000" fontSize="24"
				 paddingBottom="20" paddingLeft="5" paddingRight="5"
				 paddingTop="5" text="{rtitle}"/>
		<s:Label left="20" right="90" top="14" height="23" backgroundColor="#FEFDFD" color="#666666"
				 fontSize="18" fontStyle="italic" paddingBottom="5" paddingLeft="5" paddingRight="5"
				 paddingTop="5" text="{rdate}"/>
  		<s:BitmapImage y="91" left="20" right="20" height="135" source="image"/>
		<s:Label left="20" right="20" top="335" bottom="69" color="#666666"
				 backgroundColor="#FFFFFF" fontSize="18" paddingBottom="5"
				 paddingLeft="5" paddingRight="5" paddingTop="5"
				 text="{rdesc}" maxDisplayedLines="50"  />
		<s:Button left="50" right="50" bottom="22" label="Preberi celoten članek"
				  click="navigator.pushView(ClanekHTML, data.link)"/>
	</s:BorderContainer>
</s:View>
Pa še tutorial: http://www.telexer.nl/code-snippets/ret...
Če bi mi kdo znal pomagati pri temle problemu bom zelo zelo hvaležen, zagotovo pa se bom s tem naučil tudi nekaj novega, kar mi bo morda v prihodnje koristilo :)
r0ks0n ::
Res noben ne pozna tega ActionScripta oziroma Flash Builderja? :(
Pomoč pri izdelavi Python skripte (strani: 1 2 )
Oddelek: Programiranje
617304 (5950) BigWhale
Zmanjšanje slik v RSS feedih
Oddelek: Izdelava spletišč
6903 (824) marS
RIM predstavil BlackBerry Torch 9800
Oddelek: Novice / RIM BlackBerry
75845 (5390) MKrmec
VB vs. C#
344274 (3413) BlueRunner
index.php?name=RSS&id=nekaj
51301 (1189) Iskraman
