Problem pri php upload skripti
mason6 ::
Zdravo. Potrebujem php skripto, ki omogoča nalaganje datotek na nek direktorij. To seveda ni problem, ampak iščem še nekaj takega, da bi mi po prenosu datoteke na strežnik, spodaj izpisalo seznam datotek, ki so bile naložene, po možnosti z brisanjem.
Eno takšno skripto sem sicer našel, ki naj bi omogočala vse kar hočem, vendar ne deluje prikaz datotek na strani, posledično pa tudi ne deluje brisanje. Podatke sicer skripta beleži v log file, ampak rad bi, da jih prikaže na strani.
Prosim za pomoč.
Koda:
<?php
//vvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvv
//   You may change maxsize, and allowable upload file types.
//Mmaximum file size. You may increase or decrease.
$MAX_SIZE = 10000000;
//Allowable file ext. names. you may add more extension names.
$FILE_EXTS  = array('.zip','.jpg','.png','.gif','.doc','.xls','.pdf','.psd','.png','.txt');
//Allow file delete? no, if only allow upload only
$DELETABLE  = true;
//   Do not touch the below if you are not confident.
*     Setup variables
$site_name = $_SERVER['HTTP_HOST'];
$url_dir = "http://".$_SERVER['HTTP_HOST'].dirname($_SERVER['PHP_SELF']);
$url_this =  "http://".$_SERVER['HTTP_HOST'].$_SERVER['PHP_SELF'];
$upload_dir = "files/";
$upload_url = $url_dir."/files/";
$message ="";
*     Create Upload Directory
if (!is_dir("files")) {
  if (!mkdir($upload_dir))
      die ("upload_files directory doesn't exist and creation failed");
  if (!chmod($upload_dir,0755))
      die ("change permission to 755 failed.");
*     Process User's Request
if ($_REQUEST[del] && $DELETABLE)  {
  $resource = fopen("log.txt","a");
  fwrite($resource,date("Ymd h:i:s")."DELETE - $_SERVER[REMOTE_ADDR]"."$_REQUEST[del]n");
  fclose($resource);
  if (strpos($_REQUEST[del],"/.")>0);                  //possible hacking
  else if (strpos($_REQUEST[del],$upload_dir) === false); //possible hacking
  else if (substr($_REQUEST[del],0,6)==$upload_dir) {
    unlink($_REQUEST[del]);
    print "<script>window.location.href='$url_this?message=deleted successfully'</script>";
else if ($_FILES['userfile']) {
  fwrite($resource,date("Ymd h:i:s")."UPLOAD - $_SERVER[REMOTE_ADDR]"
            .$_FILES['userfile']['name']." "
            .$_FILES['userfile']['type']."n");
  fclose($resource);
  $file_type = $_FILES['userfile']['type'];
  $file_name = $_FILES['userfile']['name'];
  $file_ext = strtolower(substr($file_name,strrpos($file_name,".")));
  //File Size Check
  if ( $_FILES['userfile']['size'] > $MAX_SIZE)
     $message = "The file size is over 10MB.";
  //File Extension Check
  else if (!in_array($file_ext, $FILE_EXTS))
     $message = "Sorry, $file_name($file_type) is not allowed to be uploaded.";
  else
     $message = do_upload($upload_dir, $upload_url);
  print "<script>window.location.href='$url_this?message=$message'</script>";
else if (!$_FILES['userfile']);
else
    $message = "Invalid File Specified.";
*     List Files
$handle=opendir($upload_dir);
$filelist = "";
while ($file = readdir($handle)) {
   if(!is_dir($file) && !is_link($file)) {
      $filelist .= "<a href='$upload_dir$file'>".$file."</a> - URL: <b>$upload_url$file</b>";
      if ($DELETABLE)
      $filelist .= " Added at  ".date("d-m H:i", filemtime($upload_dir.$file))
$filelist .= " <a style='text-decoration:none; font-weight:bold'  href='?del=$upload_dir".urlencode($file)."' title='delete'>x</a>";
      $filelist .="<br>";
function do_upload($upload_dir, $upload_url) {
    $temp_name = $_FILES['userfile']['tmp_name'];
  $file_name = str_replace("","",$file_name);
  $file_name = str_replace("'","",$file_name);
    $file_path = $upload_dir.$file_name;
    //File Name Check
  if ( $file_name =="") {
      $message = "Invalid File Name Specified";
      return $message;
  $result  =  move_uploaded_file($temp_name, $file_path);
  if (!chmod($file_path,0777))
       $message = "change permission to 777 failed.";
  else
    $message = ($result)?"$file_name was uploaded successfully." :
               "Something is wrong with uploading the file.";
  return $message;
<html>
<head>
<title>Simple uploader</title>
<link rel=stylesheet href=style.css>
</head>
<body>
<br><br>
<center>
   <font color=red><?=$_REQUEST[message]?></font>
   <br>
   <form name="upload" id="upload" ENCTYPE="multipart/form-data" method="post">
     Objavi datoteko <input type="file" id="userfile" name="userfile">
     <input type="submit" name="upload" value="Objavi">
   </form>
   <br><b><u>Objavljene datoteke:</b></u><br><br>
   <?=$filelist?><br>
   <a style="text-decoration:none" </a>
   </sup></small>
</center>
Tody ::
Tole kar piše v 279 vrstici niti v sanjah ne more biti prav :) Probaj kak echo če ne drugega
paco ::
Zakaj ne?
Ti mogoče javi kakšno napako?
Poskusi v php.ini nastaviti vrednost short_open_tag na On.
It iz aj.
MrBrdo ::
Tody še nisi videl
taga? :) Ne pisat "niti v sanjah" če nisi prepričan hehe.
Drgač pa @OP, se bo treba naučit programirat, ane ;)
MrBrdo
  • spremenilo: MrBrdo ()
Tody ::
ja sem se spomnu na to opcijo ko sem pritisnu send... jeba pač ne sledim trendom :)
se posipam s pepelom če komu to pomaga :D
2 ftp serverja
Oddelek: Omrežja in internet
112403 (1998) knesz
Ftp batch jobs - preglednost
Oddelek: Programska oprema
6965 (898) psychoshorty
Odkrita nova Flash ranljivost, ki ugrabi odložišče (strani: 1 2 )
Oddelek: Novice / Varnost
5310843 (6648) r0b3rt
[PHP] Zend engine?
Oddelek: Programiranje
81974 (1819) Gandalfar
forum...
Oddelek: Izdelava spletišč
101549 (1323) nemesis
