Nestabilen ping
Nestabilen ping
pero44 ::
Zadnje čase se ping iz mojega računalnika (medtem ko ne downloadam NIČ in tudi če je računalnik priklopljen direktno na modem) obnaša takole:
Pinging google.com [209.85.148.103] with 32 bytes of data:
Reply from 209.85.148.103: bytes=32 time=69ms TTL=55
Reply from 209.85.148.103: bytes=32 time=135ms TTL=55
Reply from 209.85.148.103: bytes=32 time=77ms TTL=55
Reply from 209.85.148.103: bytes=32 time=123ms TTL=55
Reply from 209.85.148.103: bytes=32 time=76ms TTL=55
Reply from 209.85.148.103: bytes=32 time=70ms TTL=55
Reply from 209.85.148.103: bytes=32 time=68ms TTL=55
Reply from 209.85.148.103: bytes=32 time=102ms TTL=55
Reply from 209.85.148.103: bytes=32 time=56ms TTL=55
(ping je še en teden nazaj bil konstanten okoli 30ms)
Ponudnik pravi da s povezavo ni nič narobe. Kako naj mu dokažem da je poln DREKA?
Tracert izgleda takole:
Tracing route to google.com [209.85.148.99]
over a maximum of 30 hops:
1 1 ms 1 ms 2 ms 192.168.1.1
2 * * * Request timed out.
3 33 ms 32 ms 48 ms 213.253.98.97
4 37 ms 20 ms 25 ms 212.13.239.149
5 25 ms 34 ms 40 ms sn-vrh-01-slo.ntwk.softnet.si [213.253.100.233]
6 30 ms 19 ms 41 ms molt.softnet.si [212.103.129.10]
7 64 ms 41 ms 31 ms sn-fr-pos1-1-ger.ntwk.softnet.si [212.103.130.2]
8 61 ms 49 ms 43 ms de-cix20.net.google.com [80.81.193.108]
9 49 ms 90 ms 40 ms 72.14.238.230
10 99 ms 216 ms 89 ms 209.85.254.41
11 88 ms 83 ms 72 ms fra07s07-in-f99.1e100.net [209.85.148.99]
pero44 ::
aha pa seveda
sem poskusil "resetirat modem"
Tilen ::
Ne vem no. Na telemachu imam konstantnio 100ms+ do 209.85.148.103 ali 209.85.148.99.
Ping statistics for 209.85.148.99:
Packets: Sent = 100, Received = 100, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 109ms, Maximum = 154ms, Average = 131ms
RejZoR ::
Pingaj neko lokacijo v sloveniji. Npr siol.net Kakšen ping imaš do googla nima veze ker tud ni mišljeno, da imaš 0,0002ms zamika do iskalnika...
pero44 ::
Pinging siol.net [89.143.249.33] with 32 bytes of data:
Reply from 89.143.249.33: bytes=32 time=37ms TTL=120
Reply from 89.143.249.33: bytes=32 time=22ms TTL=120
Reply from 89.143.249.33: bytes=32 time=106ms TTL=120
Reply from 89.143.249.33: bytes=32 time=74ms TTL=120
RejZoR ::
napiši:
ping -t siol.net
Pa prekini test po 10 sekundah, da dobiš mal večji vzorec kot samo 4 pakete...
pero44 ::
vem kako delujejo komande v cmd-ju za ping, ni me treba izobraževat.
dejstvo je da ping skače do 200ms, kar se do sedaj ni dogajalo.
zanima me zakaj
logout ::
Če ne poveš, kako imaš zvezano omrežje pri sebi in kdo je ISP, je brez veze ugibati, zakaj sprememba.
L.p., Kloko
RejZoR ::
pero44 je izjavil:
zanima me zakaj
Predvsem zaradi kač. Pizda a misliš da sem jasnoviden, da ti vse veš okoli ping komande? Matr ste eni nehvaležni.
Klič ISP-ja.
Duhec ::
Pingaj v varnem zagonu z omrežno podporo, če so pingi kaj boljši.
WIMAX
Oddelek: Omrežja in internet
364120 (2273) Andrejpan
Elektro turnšek in kabelski internet - novo omrežje, a počasno odpiranje web strani
248343 (7143) iloveboobz
ADSL za "nesrečneže"
426757 (3116) KoMar-
Slab ping - What to do?
232979 (2580) KoReNJe
Najboljši slovenski webhosting
111958 (1587) Ales
