Gamer pc
Gamer pc
Demurall ::
mene zanima če se splača tale pc kupit? :
Case: CoolerMaster HAF 912 Mid-Tower Gaming Case w/ Adjustable HDD Cage (Black Color)
Laser Engraving: NONE
Laser Engraving Message:
Internal USB Extension Module: None
Neon Light Upgrade: None
Extra Case Fan Upgrade: Default case fans
Noise Reduction Technology: Sound Absorbing Foam on Side, Top And Bottom panels [+29]
CPU: AMD FX-8150 3.60 GHz Eight-Core AM3+ CPU 8MB L2 Cache & Turbo Core Technology
Freebies: FREE! Battlefield 3 Game (AMD)
FREE! DiRT 3 Game
Venom Boost Fast And Efficient Factory Overclocking: No Overclocking
Cooling Fan: Asetek 510LC Liquid Cooling System 120MM Radiator & Fan (Enhanced Cooling Performance + Extreme Silent at 20dBA) (Single Standard 120MM Fan)
Coolant for Cyberpower Xtreme Hydro Water Cooling Kits: Standard Coolant
Motherboard: * [CrossFireX] GigaByte GA-970A-D3 AMD 970 Socket AM3+ ATX Mainboard w/ On/Off Charge, 7.1 Audio, GbLAN, USB3.0, SATA-III RAID, 2 Gen2 PCIe X16, 3 PCIe X1 & 2 PCI
Memory: 16GB (4GBx4) DDR3/1600MHz Dual Channel Memory (Corsair or Major Brand)
Video Card: NVIDIA GeForce GTX 560 Ti 1.2GB 16X PCIe Video Card [+127] (EVGA GeForce 448 Cores Classified Powered by NVIDIA)
Freebies: None
Video Card 2: None
Video Card 3: None
Free Game: None
Power Supply Upgrade: 800 Watts - XtremeGear Gaming Power Supply - Quad SLI Ready [+27]
Hard Drive: 2TB (2TBx1) SATA-III 6.0Gb/s 64MB Cache 7200RPM HDD (Single Drive)
Data Hard Drive: None
Hard Drive Cooling Fan: None
External Hard Drive (USB3.0/2.0/eSATA): None
USB Flash Drive: None
Optical Drive: 24X Double Layer Dual Format DVD+-R/+-RW + CD-R/RW Drive (BLACK COLOR)
Optical Drive 2: None
Sound: HIGH DEFINITION ON-BOARD 7.1 AUDIO
3D Vision Glasses: None
LCD Monitor: None
2nd Monitor: None
3rd Monitor: None
Speakers: None
Network: Onboard Gigabit LAN Network
Network Switch: None
Keyboard: Xtreme Gear (Black Color) Multimedia/Internet USB Keyboard
Mouse: XtremeGear Optical USB 3 Buttons Gaming Mouse
Mouse Pad: None
Gaming Gear: None
Extra Thermal Display: None
Wireless 802.11B/G Network Card: None
External Wireless Network Card: None
Wireless 802.11 B/G/N Access Point: None
Bluetooth: None
Flash Media Reader/Writer: None
Video Camera: None
Headset: None
Printer: None
Cable: None
Power Protection: None
IEEE1394 Card: None
Internal USB Port: Internal USB 3.0 4-Port Hub [+29]
USB Port: None
Operating System: MicrosoftŸ Windows 7 Home Premium (64-bit Edition)
Media Center Remote Control & TV Tuner: None
Office Suite: None
Ultra Care Option: None
Service: STANDARD WARRANTY: 3-YEAR LIMITED WARRANTY PLUS LIFE-TIME TECHNICAL SUPPORT
Rush Service: NO; READY TO SHIP IN 10~15 BUSINESS DAYS
BALAST ::
Tole je ene 750€ vredno če sam sestaviš po komponentah. Čeprav vodno hlajenje je brezveze s takim proračunom.
"You may fool all the people some of the time;
you can even fool some of the people all the time;
but you can't fool all of the people all the time."
Demurall ::
torej a bi to zagnalo bf3 na ultra?
BALAST ::
Bi, ampak bi gledal diapozitive. Za Ultra FullHD BF3 rabiš gtx590 ali pa HD6990, ki pa sta grafični za 500€ in več.
Demurall ::
meniš da bi štekalo?
BALAST ::
Jap, glej video PC z GTX560ti
Demurall ::
meni zgleda ok...
BALAST ::
Če pade pod 35fps je zame že zatikanje. Kakšen pa imaš proračun za PC? Pa monitor?
Demurall ::
kaj pa če bi kupil tale pc:
http://www.mimovrste.com/artikel/274000...
drugače pa za pc nebi dal več kakor 1300 € ekran pa je kar ok 3 leta star samsung
  • spremenilo: Demurall ()
BALAST ::
  • spremenil: BALAST ()
Demurall ::
hvala samo kdo bi mi pa to sploh sestavil? se to da odnest v trgovino? ali kak
BALAST ::
Sestavi ti trgovina, samo prosiš jih na MAIL da naj sestavijo v celoto, in da boš kabelčke za DISK in DVD priklopil sam.
(nov slovenski zakon ne dovoli brez licence sestave celotnega računalnika, tako boš moral sam priklopit kabelčke, da se izogneš temu zakonu)
Pa seveda prosiš kakega kolega, ki ima Win7 da ti namesti , razen če že imaš Win XP cd.
j3rn3jk ::
Pri funtechu je tako, da ti vse sestavijo, razen ramov, katere sam vtakneš v matično.
Demurall ::
kaj pa pri agt? a tam tudi sestavijo?
BALAST ::
Prosim, res te prosim poišči malce komentarje na AGT na slo-tech, AGT zavlačuje celotna naročila za več mesecev.
Demurall ::
hvala
TOP ::
Lahko povprašaš tudi pri Dinokompu.
Demurall ::
samo eno pitanje kaj je narobe z amd bulldozer 8150fx procesorjem, zakaj vsi svetujejo intel i5 in i7?
BALAST ::
Ker za svojo ceno ne ponuja izboljšanja v igrah od starejših AMD Phenom2 procesorjev, kar preberi si kak test.
jazbec ::
ker je i5-2500k za manj denarja boljši
da o i7-2600k ne govorimo
Demurall ::
jazbec v bistvu 2500k pa fx isto staneta 2600 pa več samo za info...
jazbec ::
če je to zate isto
http://www.dinokomp.si/product_info.php...
i5-2500k okol 200 evrov
i7-2600k okol 280 evrov
fx-8150 pa okol 260 evrov
Demurall ::
sorry... fail...
Demurall ::
Operacijski sistem Windows 7 Home Premium DSP 64BIT, slovenska verzija(Operacijski sistemi) 102.78€
Mainboard Socket-AM3 ASUS M4A87TD EVO, ATX(Osnovne plošče) 96.38€
Procesor AMD Phenom II X6 1055T BOX AM3(Procesorji) 150.76€
DDR3-RAM KIT 8 GB, 1600 MHz, CL9, KINGSTON HyperX Genesis(Pomnilnik) 40.16€
Grafična kartica PCI-E 2.0 ASUS ENGTX560 Ti DCII TOP/2DI/1GD5 Battlefield 3, retail, 1024MB(Grafične kartice) 278.43€
TRDI DISK SAMSUNG F3 1TB SATA2 32MB/5400 HD103SI*** (Omejena zaloga!!!)(Trdi diski) 122.00€
DVD-+R/-+RW SATA LITEON iHAS122, bulk, črn(Optične enote) 18.10€
OH.COOLER MASTER MIDT HAF 922 BLACK RC - 922M(PC Ohišja) 116.55€
Napajalnik LC Power LC6550GP2 - 550W/14cm V2.2 Silent Giant(Napajalniki) 46.41€
Kaj pravite na slednjo konfiguracijo?
A bi šel bf 3 na max?
jazbec ::
vzami cenejše ohišje pa z68 plato in i5-2500k če boš navijal
drugače pa i5-2400 pa h67 plato
kmetek ::
pa drugi disk....7200 išči.
pa tudi cenejšo 560ti že dobiš recimo
Demurall ::
ta nvidia 560ti ima zraven battlefield 3 zato sem jo izbral
TOP ::
Demurall je izjavil:
Vzameš MSI 560Ti ki stane 220e in za 18e dobiš BF3 in še ti ostane skoraj za rame.
Demurall ::
kje dobiš bf3 za 18€?
pa ni asusov boljši od msijevega?*
grafično mislim
Demurall ::
a bi na tem sistemu boljše šel bf 3 ?
Operacijski sistem Windows 7 Home Premium DSP 32BIT, slovenska verzija(Operacijski sistemi) 102.25€
7150 Mainboard S-1155 GIGABYTE GA-H67M-UD2H-B3, Micro-ATX(Osnovne plošče) 99.64€
6677 Procesor INTEL Core i5 - 2500K, 3,30GHz, LGA1155, Quad-Core, Boxed(Procesorji) 215.00€
8891 DDR3-RAM KIT 8 GB, 1333 MHz, CL9, KINGSTON HyperX blu(Pomnilnik) 36.14€
8776 Grafična kartica PCI-E 2.0 POINT OF VIEW GeForce GTX570, retail, 1280MB(Grafične kartice) 329.30€
8977 TRDI DISK SAMSUNG F3 1TB SATA2 32MB/5400 HD103SI*** (Omejena zaloga!!!)(Trdi diski) 122.00€
8719 DVD-+R/-+RW SATA LITEON iHAS122, bulk, črn(Optične enote) 18.10€
7119 Ohišje LC ATX MIDI PRO932B LC600H-12(PC Ohišja) 51.00€
6266 Napajalnik Silent Power LC600H-600W/12 V2.31(Napajalniki) 30.02€
sestavljen je bil na sestavi.si
Webeg ::
vidis svojo napako?
Demurall ::
rekli ste da naj bo matična h67 torej sem to izbral... ne razumem
Webeg ::
Model K procesorja je odklenjen procesor za navijanje. Torej se zraven nabavi Z ali P varjanto plate.
Ali pac nabavis i5 2500 brez K na konc pa obdrzis isto plato in racunalnika ne mores naviti.
V obratnem primeru meces denar stran, oziroma kupujes nekaj kar ne bos mogel koristiti.
  • spremenilo: Webeg ()
TOP ::
grafično mislim
BF3 za 18e sem jaz kupil pač samo key in to je to.Kar se tiče grafe,kako je Asus bolši od MSI,grafi imate enake čipe gor samo hlajenje je drugačno,mislim pa da je MSI malo več tovarniško navita.
Sssaga ::
Tovarniško navita ali ne, vse je glih! Folk recimo raje kupi grafo, ki ima GPU navit z 607 na 630 pa čeprav je za 20€ dražja a z istim (stock) hlajenjem.
Raje zmeraj kupi najcenej varianto (če si s hlajenjem zadovoljen) in jo sam navij. Sam sem s 607 navil na 850 in to pri referenčnem hladilniku. Pol ti pa 630 prodajo z oznako ''OverClocked Edition''. Marketinška poteza.
Če je seveda razlika v ceni. Vkolikor je ''ušmekana'' grafa le malenkost dražja, se jo pa splača kupiti.
Demurall ::
torej kero grafiko suggestate?
mislim priporočate
Alessio983 ::
kdo pravi da na ultra ne dela BF3 z 6850 se močno moti. Imam takšno konf. in dela na ultra vse brez zatikanja.
glede grafične : priporočam ti 6850-70 odvisno kolko misliš odšteti, če imaš na razpolago še več pač daj še več zanjo :)
Nwanko ::
Na kaki resoluciji?
Demurall ::
hvala zanima me še če je v ta video štet tudi antialiasing in podobno ker rečejo da to pokaze pravo lepoto bf3
Demurall ::
a ti na sestavi.si sestavijo celoten računalnik ali pa moram vse sam sestavit ali pa samo eno komponento morem not dat?
alpha1 ::
Lahko sam sestaviš ali, če pa hočeš pa ti lahko oni.
Demurall ::
torej dajo not vse komponente? ker je prej en pisal da to zakon prepoveduje
zoot ::
Notri daš lahko katerekoli komponente, je pa seveda fajn da so skladne med seboj. In ne, tega "zakon" ne prepoveduje.
Berserker ::
Jaz sem oktobra kupil pc pri eni spletni trgovini(mislim da se reklame na tem forumu ne sme delati brez dovoljenja) , tam so mi ga v celoti brez problema sestavili po mojih željah (takrat sem bil v tujini in sem ravno kupoval za bf3). Ne vem od kod vam ta blesav zakon.
69charger ::
Sestavijo ti ga lahko,ne smejo pa prodajat že sestavljenih računalnikov brez certifikatov.
Berserker ::
69charger je izjavil:
Ah, torej ne sme računat računalnika kot izdelek, ampak vsak del posebej, le da sem dobil sestavljenega.
Demurall ::
aha hvala
Demurall ::
pravkar sem bral da bodo kmalu izšli novi radeon gpu-ji. Nevem se splača čakat ker bi morda cene trnutnih grafičnih padle ali ne?
Tim55 ::
po vsej verjetnosti bodo padle ja...
Pomoč pri Pcju !
61354 (1268) Silvester0
Pomoč pri nakupu novega pcja (strani: 1 2 3 )
1178515 (7651) Šmexguy
Gamerski računalnik do 1500€! (strani: 1 2 )
8216492 (14426) s51as
gaming pc 850eu? (strani: 1 2 3 )
10915624 (14113) eieieie1
Shark-3
153749 (3517) klinker
