Forum » Pomoč in nasveti » Adobe Acrobat - število licenc
Fifty ::
V firmi imamo Adobe Acrobat, in sicer z eno serijsko številko. Se da to serijsko uoorabljati na 3 računalnikih hkrati ali velja pravilo 1 licence. Ne najdem pa nobenega podatka, ker imam na voljo samo CD, lp
Ne. Kolikor vem, se lahko licenco uporablja na dveh računalnikih, recimo en namizni in en prenosni (a ne hrakti).
Poglej točko 2 (license grand), točke a, b in znotraj teh še A, B in C:
http://www.adobe.com/products/eula/tool...
Oziroma tukaj je še bolj poenostavljeno:
http://www.adobe.com/aboutadobe/antipir...
Can I allow others to "walk up" to my workstation and use my licensed copy of Acrobat?
Yes, with some important restrictions. Acrobat is licensed per computer, so you or other people may use the copy of Acrobat installed on that workstation. However, you may not allow other people or computers to: (1) access or use the software via an internal network (even if such people or computers are taking advantage of Acrobat network features such as "watched folders") unless such users also have valid licenses or (2) access or use the software through any other network resource (such as via the Internet or other public network). In addition, you may not automate any function or feature of the software (including but not limited to the creation, viewing, manipulation, securing or printing of PDF files from your computer) if such automation processes requests from other unlicensed users and/or machines (including, without limitation, automation through use of scripts and batch processing).
| » | Dual boot 2 x windows xp in licenceOddelek: Operacijski sistemi | 1697 (1465) | ender |
| » | Legalno ali nelegalno?Oddelek: Programska oprema | 2411 (1709) | poweroff |
| » | Kje kupit Windows XP Pro in koliko stane?Oddelek: Operacijski sistemi | 5342 (4292) | bond007 |
| » | Gentoo setup problemOddelek: Operacijski sistemi | 2198 (2022) | G2 |
| » | Poziv za zaščito Whois bazeOddelek: Omrežja in internet | 4944 (1956) | Bakunin |
