Forum » Pomoč in nasveti » DMA ne dela *!"*!
DMA ne dela *!"*!
Heisenberg ::
a mi lahko kdo pove zakaj mi DMA ne dela, ampak smao PIO mode ??? imam pa vse vklopljeno (DMA where available)....
to sem pogruntal sele sedajle sistem sem formatiral pred kakim mesecem takrat je vse delalo
na kontrolerju imam pa na 0 cd rom teac in na 1 cdrw LG
10x
10x
ali3n ::
Si naložil nove voznike za čipset (ala Via 4 in 1)?
- "Rozi vidm." "S psom!"
govno ::
naredi:
If you have problems with Ultra DMA settings for devices in Windows 2000 or XP:
Originally posted in the MS Newsgroups:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E96A-E325-11CE-BFC1-08002BE10318}\000x
Last four digits are likely 0001, 0002. Under those keys you will find
MasterIdDataChecksum, SlaveIdDataChecksum.
Delete the value corresponding to your drive. It will make the OS to redetect the device
DMA capabilities after reboot.
hvala,
hvala,
TineL Studio :: http://tinel.stjost.si
TineL Studio vici :: http://tinel-vici.stjost.si
TineL Studio wap :: http://tinel-wap.stjost.si
| » | Na pekaču ne morem vklopiti DMA mode (sedaj je PIO)Oddelek: Pomoč in nasveti | 1908 (1651) | smile- |
| » | Pekač in UDMA2Oddelek: Strojna oprema | 1530 (1407) | soko |
| » | Windows XP in (Ultra)DMAOddelek: Pomoč in nasveti | 1480 (1361) | bf4ed |
| » | CD-RW problem snemanjeOddelek: Pomoč in nasveti | 1383 (1244) | icek |
| » | teac w540e & problemiOddelek: Pomoč in nasveti | 1584 (1361) | fictionel |
