DMA ne dela *!"*!
DMA ne dela *!"*!
Heisenberg ::
a mi lahko kdo pove zakaj mi DMA ne dela, ampak smao PIO mode ??? imam pa vse vklopljeno (DMA where available)....
to sem pogruntal sele sedajle sistem sem formatiral pred kakim mesecem takrat je vse delalo
na kontrolerju imam pa na 0 cd rom teac in na 1 cdrw LG
10x
Primoz78 ::
Ka OS pa mas gor? a mas kabel za ATA 66 al mas navadnega ?!?!
lp Primoz
ali3n ::
Si naložil nove voznike za čipset (ala Via 4 in 1)?
- "Rozi vidm." "S psom!"
govno ::
naredi:
If you have problems with Ultra DMA settings for devices in Windows 2000 or XP:
Originally posted in the MS Newsgroups:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E96A-E325-11CE-BFC1-08002BE10318}\000x
Last four digits are likely 0001, 0002. Under those keys you will find
MasterIdDataChecksum, SlaveIdDataChecksum.
Delete the value corresponding to your drive. It will make the OS to redetect the device
DMA capabilities after reboot.
hvala, :D
TineL Studio :: http://tinel.stjost.si
TineL Studio vici :: http://tinel-vici.stjost.si
TineL Studio wap :: http://tinel-wap.stjost.si
Heisenberg ::
danes sem imel koncno cas tole sprobat in DELUJE !
najlepsa hvala Govno :D
Na pekaču ne morem vklopiti DMA mode (sedaj je PIO)
141908 (1651) smile-
Pekač in UDMA2
91530 (1407) soko
Windows XP in (Ultra)DMA
71480 (1361) bf4ed
CD-RW problem snemanje
81383 (1244) icek
teac w540e & problemi
111584 (1361) fictionel
