Forum » Pomoč in nasveti » Kernel-Power
Kernel-Power
eddy22 ::
Pozdravljeni!
Kar naenkrat se mi je pojavila ta zadeva in sicer da se kar sam od sebe računalnik kar ugasne in ko ga prižgem nazaj se prijavlja kot da bi ga nekdo dal v mirovanje.to se mi je sedaj zgodilo 3* danes.Nič nisem spreminjal. Uporabljam WIN 7 64bit že kar nekaj časa (1 leto najmanj)
Pa še to ko se to zgodi ne delam nič ne igram ne brskam po internetu skratka nič.
Event mi je dal to napako.
Kaj bi lahko bilo?
Hvala za pomoč
Log Name: System
Source: Microsoft-Windows-Kernel-Power
Date: 26.7.2011 12:59:17
Event ID: 41
Task Category: (63)
Level: Critical
Keywords: (2)
User: SYSTEM
Computer: Erik-PC
Description:
The system has rebooted without cleanly shutting down first. This error could be caused if the system stopped responding, crashed, or lost power unexpectedly.
Event:
System
Provider Name="Microsoft-Windows-Kernel-Power" Guid="{331C3B3A-2005-44C2-AC5E-77220C37D6B4}" /
EventID41/EventID
Version2/Version
Level1/Level
Task63/Task
Opcode0/Opcode
Keywords>0x8000000000000002/Keywords
TimeCreated SystemTime="2011-07-26T10:59:17.828125000Z" /
EventRecord ID206803/EventRecordID
Correlation /
Execution ProcessID="4" ThreadID="8" /
Channel System /Channel
Computer Erik-PC /Computer
Security UserID="S-1-5-18" /
EventData
Data Name="BugcheckCode">0 /Data
Data Name="BugcheckParameter1" 0x0 /Data
Data Name="BugcheckParameter2" 0x0 /Data
Data Name="BugcheckParameter3" 0x0 /Data
Data Name="BugcheckParameter4" 0x0 /Data
Data Name="SleepInProgress" false /Data
Data Name="PowerButtonTimestamp" 0 /Data
/EventData
/Event
Kaj bi lahko bilo?
Hvala za pomoč
Log Name: System
Event ID: 41
Task Category: (63)
Level: Critical
Keywords: (2)
User: SYSTEM
Computer: Erik-PC
Description:
Event:
System
EventID41/EventID
Version2/Version
Level1/Level
Task63/Task
Opcode0/Opcode
Correlation /
EventData
/EventData
/Event
DeeCoy ::
http://social.technet.microsoft.com/For...
Znaš slučajno angleško ali moramo prevajati?
Več zadetkov:
http://www.google.si/search?q=0x8000000...
Več zadetkov:
| » | Težava Microsoft-Windows-Kernel-Power (strani: 1 2 )Oddelek: Pomoč in nasveti | 10260 (7270) | Anney |
| » | Tp-link wn722n zmrzuje internetOddelek: Omrežja in internet | 1095 (954) | BorutK-73 |
| » | Težave z Računalnikom!Oddelek: Pomoč in nasveti | 7096 (6723) | dogo |
| » | Windows 7 non-stop zmrzujejoOddelek: Pomoč in nasveti | 2001 (1860) | darkolord |
| » | Vista Business - počasen zagon in zakasnitev odpiranja (explorer)Oddelek: Operacijski sistemi | 2744 (2744) | miteq |
