google domena
google domena
ridder ::
pozdravljeni.
pri googlu imam narejeno spletno stran, pa me sedaj zanima, kako povežem to spletno stran z domeno, ki sem jo kupil pri neoserver.
kaj napišem pod primarni in sekundarni server.
če bi kdo pomagu, bi lepo prosu :)
element ::
ridder ::
ta link poznam. ampak kaj napišem pod primaren in sekundaren dns?
madog ::
v neoserver-ju vpišeš dns-se od googla.
Phenom II X4 955 BlackEdition|M4A87TD EVO|OCZ 2x2GB @1333MHz|Sapphire HD5770 OC
ridder ::
ki pa je?
DamirK ::
Depending on your domain registrar, you may need to make changes to your CNAME record in order for your site to be mapped:
Sign in to the site where you control your own site with custom URL.
Navigate to your Domain Name Server (DNS) management page. The location and name of this page varies by host, but can generally be found in the Domain Management or Advanced Settings section.
Find the CNAME settings and in the section 'CNAME value or alias,' enter the sub-domain you'd like to map the URL to. The sub-domain for www.example.com would be www.
Set the CNAME destination to the following address: ghs.google.com
Save your changes with your domain host.
http://www.gasilci.org/forum/viewtopic....
v primeru iz povezave bi torej zapis :
http://www.taketime.si. 3600 A 213.157.246.137
spremenil v :
http://www.taketime.si. 3600 CNAME ghs.google.com
DC- ::
Google nima DNS strežnikov in moraš uporabiti kakšnega od brezplačnih.
Zabec.net
Siel
Afraid
Tam pa lahko nastaviš CNAME
ridder ::
a mi lahko kdo to naredi preko teamviwerja prosim.
Sem poklicu na neoserver pa je reku da rabim usaj ip od googla
ridder ::
nujno.
tudi plačam, če mi kdo naredi ni problem.
dam geslo, pa username pa use.
denarna nagrada za tistega, ki mi zrihta!
ŠE vedno iščem.
nujno
če prenesem domeno na godaddy bi potem šlo?
  • spremenil: ridder ()
Povezava domene z google sites
121777 (1640) Ales
Lastna domena pri Bloggerju, brez "www" ne dela
Oddelek: Omrežja in internet
51450 (1399) Malcolm_Y
Mapping (preusmeritev) spletne strani z DNS
71892 (1799) NoName
blogspot in lastna domena
Oddelek: Izdelava spletišč
52063 (1954) Nextor
Vpis DNS strežnika v vrhnji DNS
379722 (8213) kronik
