htaccess - ce obstaja - serviraj, v nasprotnem primeru ....
Lion29 ::
Torej tako...
mal me matrajo tejle rewrite rules-i...
namrec, moj namen je tak, da ce datoteka obstaja v file sistemu, potem jo direktno serviraj in USTAVI vse nadaljne preverjanje...
v kolikor ne obstaja, serviraj php skripto in nadaljuj z ostalim preverjanjem
datoteke se nahajajo v root/tmp direktoriju in sicer ena izmed:
D:/root/domena/tmp/cities/find_cities/10/0.json
moj cond in rule:
	RewriteCond	%{DOCUMENT_ROOT}tmp%{REQUEST_URI} -f
	RewriteRule 	^cities/find_cities/(.*).json$ 	/webroot/index.php?page=/cities/find_cities&%{QUERY_STRING} [QSA,L]
seveda mi ne dela (doh, ce ne nebi pisal sem)...
v rewrite logsih imam to:
127.0.0.1 - - [09/Jun/2011:11:11:12 +0200] [og/sid#375fe0][rid#2b221d8/initial] (4) [perdir D:/root/domena/] RewriteCond: input='D:/root/domena/tmp/cities/find_cities/10/0.json' pattern='-f' => matched
127.0.0.1 - - [09/Jun/2011:11:11:12 +0200] [og/sid#375fe0][rid#2b221d8/initial] (2) [perdir D:/root/domena/] rewrite 'cities/find_cities/10/0.json' -> '/webroot/index.php?page=/cities/find_cities&'
in se cel kup navlake naprej...
kje gresim?
prosim PLEASE, PLEASE help... going crazy ;)
  • spremenil: Lion29 ()
misek ::
http://stackoverflow.com/questions/5469...
<IfModule mod_rewrite.c>
RewriteEngine on
RewriteCond %{REQUEST_FILENAME} !-f
RewriteCond %{REQUEST_FILENAME} !-d
RewriteRule ^.*$ /your_path/default.php [L]
</IfModule>
Lion29 ::
torej... meni ta del dela.... ko preverja ce FILETA NI!... problem je, da ko file JE.. takrat namesto da se ustavi, gre validirat se ves htaccess in ga "zjebe" preden ga izpise :|
misek ::
Po moje si zgrešil samo v regularnem izrazu.
Lion29 ::
Torej tako:
	RewriteCond 	%{REQUEST_URI}  !^/tmp/?$
	RewriteCond	%{DOCUMENT_ROOT}tmp%{REQUEST_URI} !-f
	RewriteRule 	^(.*).jsonp$		/webroot/index.php?page=$1&presult=json&%{QUERY_STRING} [QSA,L]
Najprej imam to, ki preverja, da (slucajno) request uri vsebuje tmp in ce file ne obstaja v tmp direktoriju
potem serviraj index.php
TA DEL DELUJE... torej takrat ko fileta ni, se zalaufa PHP. no in php mi generira jsonp file in ga postavi v tmp dir
	RewriteRule 	^([^.]+).jsonp$		/tmp%{REQUEST_URI} [QSA,L]
naslednji del rules-ov.... karkoli ima jsonp koncnico, serviraj iz tmp mape.... Tisti prvi del zgoraj poskrbi da ce file ne obstaja pride request uri v index.php, tako da se ta del kode ne izvede....
ce pa file ne obstaja, se pa ta del kode izvede...
in po logsih dela...
AMPAK, jaz bi rad, da se dodatni rulesi, ki sledijo za temi NE IZVAJAJO v kolikor je jsonp koncnica...
NE morem zdaj jaz pred vsakim naslednjim pravilom dati novi condition, da ce vsebuje .jsonp da naj ga preskoci...
misek ::
Potem pa poskusi v zadnjo izvedeno vrstico dodati last|L' (last rule).
Lion29 ::
RewriteRule ^(tmp) - [L]
samo to sem rabu dodat na vrh.... problem mu je bil, da ko je preusmeril v tmp dir, je zacel znova vse rule-se...in valda je potem ratal rule /tmp/tmp/....etc
tako da sem s tistim NA ZACETKU dopovedal, da mora samo enkrat procesirat, ce ima tmp notrka!
KOOONCNO... matr je slo 3/4 dneva brezveze...
no, ampak zdaj pa leti zadeva :D
Google font - (č,ž,š) delajo local, na hostu pa ne delujejo
Oddelek: Izdelava spletišč
82864 (2656) neoserv
mod_rewrite - prosim za nasvet
Oddelek: Programiranje
71980 (1856) carota
brez .html končnice
122255 (1695) MisterR
Rewrite preusmeritev v .htacess
61286 (1132) Baja
Večni problem na sinfoniki. Ne znajo uredit MOD_REWRITE ?!
51746 (1622) Tody
