Forum » Programiranje » VB - database
VB - database
korenje3 ::
Zakaj tale reč ne dela?
Sem naredil Dataset1 in DataTable1 z vb2010, ampak mi prebere...
Dim newCustomersRow As DataRow = DataSet1.Tables("DataTable1").NewRow()
newCustomersRow("CustomerID") = "ALFKI"
newCustomersRow("CompanyName") = "Alfreds Futterkiste"
DataSet1.Tables("Customers").Rows.Add(newCustomersRow)
MsgBox(newCustomersRow("CustomerID"))Sem naredil Dataset1 in DataTable1 z vb2010, ampak mi prebere...
korenje3 ::
v bistvu samo malo da manipuliram v kodi s tem, pa mi neha delat...
recimo tole mi normalno dela...
MsgBox(DataTable1.TableName)
takole pa ne več...
DataTable1.Rows.Add({"a"})
enako za zgoraj...
takole pa ne več...
enako za zgoraj...
| » | [VB] datagridviewOddelek: Programiranje | 2344 (1727) | korenje3 |
| » | c# - mssql kombinacija / problem pri zapisu row-a v bazoOddelek: Programiranje | 2190 (1999) | darkolord |
| » | vb mysql dataset updateOddelek: Programiranje | 1668 (1548) | korenje3 |
| » | DataView, DataTable, DataSetOddelek: Programiranje | 1499 (1250) | detroit |
| » | [C#] DATA GRID VIEWOddelek: Programiranje | 2335 (2215) | Kekec |
