Forum » Programiranje » VB2010 - class
VB2010 - class
korenje3 ::
Zdravo. Imam še en problem. V klasi sqlhandle ne vem kako bi prenesel fmysqltest.sqladdress.text
načeloma dela, če uvozim iz instance.mysqlconfig.address
v trenutni situaciji mi zazna neskončni loop... prosim za rešitev.
prilagam del kode:
prilagam del kode:
Imports System.Configuration
Imports System.Text.RegularExpressions
Imports MySql.Data.MySqlClient
Imports System.Threading
Imports System.ComponentModel
Public Class fmysql
Dim instance As New mysection
Dim test As New Process
Dim worker As New workers
Dim sqlhandle As New sqlhandle
Private Sub fmysql_Load(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles MyBase.Load
instance = instance.open
sqladdress.Text = instance.mysqlconfig.address
sqladdress2.Text = instance.mysqlconfig.address2
sqlport.Text = instance.mysqlconfig.port
sqlport2.Text = instance.mysqlconfig.port2
sqlusername.Text = instance.mysqlconfig.username
sqlpassword.Text = instance.mysqlconfig.password
sqlpasswordr.Checked = instance.mysqlconfig.passwordr
sqlautoconnectr.Checked = instance.mysqlconfig.autoconnect
End Sub
Private Sub save_button_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles save_button.Click
instance.mysqlconfig.address = Regex.Replace(sqladdress.Text, "[^0-9.:a-z]", "")
instance.mysqlconfig.address2 = Regex.Replace(sqladdress2.Text, "[^0-9.:a-z]", "")
instance.mysqlconfig.port = Regex.Replace(sqlport.Text, "[^0-9]", "")
instance.mysqlconfig.port2 = Regex.Replace(sqlport2.Text, "[^0-9]", "")
instance.mysqlconfig.username = sqlusername.Text
instance.mysqlconfig.passwordr = sqlpasswordr.Checked
If sqlpasswordr.Checked = True Then
instance.mysqlconfig.password = sqlpassword.Text
Else
instance.mysqlconfig.password = Nothing
End If
instance.mysqlconfig.autoconnect = sqlautoconnectr.Checked
instance.save()
Me.Close()
End Sub
Private Sub cancel_button_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles cancel_button.Click
Me.Close()
End Sub
Private Sub connect_button_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles connect_button.Click
If worker.isbusy = False Then
worker.startasync()
End If
End Sub
Private Sub disconnect_button_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles disconnect_button.Click
sqlhandle.close()
End Sub
Private Sub Timer1_Tick(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Timer1.Tick
If sqlhandle.state = ConnectionState.Open Then
ToolStripStatusLabel1.Text = "Connected"
Else
ToolStripStatusLabel1.Text = "Not connected"
End If
If sqlhandle.state = ConnectionState.Connecting Then
ToolStripProgressBar1.PerformStep()
Else
ToolStripProgressBar1.Value = 0
End If
End Sub
End Class
Class workers
Private WithEvents backgroundWorker1 As New System.ComponentModel.BackgroundWorker
Sub init()
backgroundWorker1.WorkerReportsProgress = True
backgroundWorker1.WorkerSupportsCancellation = True
End Sub
Function isbusy() As Boolean
Return backgroundWorker1.IsBusy
End Function
Sub startasync()
backgroundWorker1.RunWorkerAsync()
End Sub
Sub cancelasync()
backgroundWorker1.CancelAsync()
End Sub
Sub dispose()
backgroundWorker1.Dispose()
End Sub
Private Sub BackgroundWorker1_DoWork(ByVal sender As System.Object, ByVal e As System.ComponentModel.DoWorkEventArgs) Handles backgroundWorker1.DoWork
Dim worker As BackgroundWorker = CType(sender, BackgroundWorker)
sqlhandle.open()
End Sub
End Class
Class sqlhandle
Dim sqlcon As New MySqlConnection
''' <summary>
''' kaj tukaj storiti?
''' </summary>
''' <remarks></remarks>
Dim fmysqltest As New fmysql
Public Sub open()
MsgBox(fmysqltest.sqladdress.Text)
If sqlcon.State <> ConnectionState.Closed Then
MsgBox("Connection not closed. First close connection.")
Exit Sub
End If
Try
sqlcon.ConnectionString = "Database=trooptool;Data Source=" & fmysql.sqladdress.Text & ";User Id=" & fmysql.sqlusername.Text & ";Password=" & fmysql.sqlpassword.Text & ";port=" & fmysql.sqlport.Text & ";"
sqlcon.Open()
Catch ex As Exception
MsgBox(ex.Message)
End Try
End Sub
Public Sub close()
sqlcon.Close()
sqlcon.Dispose()
End Sub
Public Function state()
Return sqlcon.State
End Function
End Class
| » | Odpiranje programa v Visual StudioOddelek: Programiranje | 1251 (1109) | darkolord |
| » | vb.net: dynamic textboxOddelek: Programiranje | 1527 (1417) | saule |
| » | Visual Studio - koda za prikaz OS?Oddelek: Programiranje | 1459 (1226) | detroit |
| » | [VB] Komunikacija s serijskimi napravamiOddelek: Programiranje | 2733 (2007) | mNeRo |
| » | VB.net MDI in formi splošnoOddelek: Programiranje | 1977 (1920) | strel |
