PIC16F87XA - iščem interface oz. vmesnik za priklop na računalnik
whatever ::
Kot je omenjeno v naslovu, iščem vmesnik oziroma način priklopa čipa na računalnik in se sprašujem, kje se da zadevo dobiti in koliko stane. Na fakulteti smo imeli eno plato velikosti A4 lista z luknjicami, kjer smo fizično vstavili čip in povezovali s stikali in žicami, in še nek vmesnik, velikosti približno 3.5" IDE diska, ne spomnim se dobro, ali se je priključil na serial port ali na USB. Programirali smo pa v C-ju z nekim softverom od firme Microchip.
Prosim, če kdo ve, kje v Sloveniji bi se dalo ta komplet za programiranje PICa kupiti in za kakšno ceno. Hvala.
Veliko jih je notri, še več jih je pa zunaj.
Bilijarde v šole! - Ivan Kramberger
Abnormal behaviour of abnormal brain makes me normal.
whatever ::
Aja, in pa seveda tudi sam PIC.
whatever ::
Najbrž iščem nekaj od tega, samo ne vem kaj...
16.0 DEVELOPMENT SUPPORT
The PICmicro(R) microcontrollers are supported with a
full range of hardware and software development tools:
o Integrated Development Environment
- MPLAB(R) IDE Software
o Assemblers/Compilers/Linkers
- MPASMTM Assembler
- MPLAB C17 and MPLAB C18 C Compilers
-MPLINKTM Object Linker/
MPLIBTM Object Librarian
- MPLAB C30 C Compiler
- MPLAB ASM30 Assembler/Linker/Library
o Simulators
- MPLAB SIM Software Simulator
- MPLAB dsPIC30 Software Simulator
oEmulators
- MPLAB ICE 2000 In-Circuit Emulator
- MPLAB ICE 4000 In-Circuit Emulator
In-Circuit Debugger
- MPLAB ICD 2
o Device Programmers
-PRO MATE(R) II Universal Device Programmer
- PICSTART(R) Plus Development Programmer
o Low Cost Demonstration Boards
- PICDEMTM 1 Demonstration Board
- PICDEM.net
TM Demonstration Board
- PICDEM 2 Plus Demonstration Board
- PICDEM 3 Demonstration Board
- PICDEM 4 Demonstration Board
- PICDEM 17 Demonstration Board
- PICDEM 18R Demonstration Board
- PICDEM LIN Demonstration Board
- PICDEM USB Demonstration Board
o Evaluation Kits
-KEELOQ(R)
- PICDEM MSC
-microID(R)
-CAN
- PowerSmart
(R)
-Analog
whatever ::
U jebemti, 200 dolarjev...
http://www.microchip.com/stellent/idcpl...
boogie_xlr ::
ICD je In-Circuit Debugger. Če se ne ukvarjaš profesionalno s tem, je bolje, da si narediš nek DIY programator preko serijskega. Imaš shem na netu polno.
rfmw ::
Na PICu uporabis hardwareski serijski port in priklopis preko cross cabla na serijski PCa. Zadeva je zelo enostavna, se posebej, ce imas C compiler za PIC. Gre samo za pravilno nastavitev nekaj registrov, potem pa samo se posiljas tvoj 8 bitni podatek v tx register in PIC bo avtomaticno sam poskrbel za komunikacijo.
Legendary 8RDA+ (reCAPed ;), XP1700+ 2108 @ 1.84 V, SLK900A AS3 @ 2500 rpm
1,5GB Samsung DDR333+Geil DDR400+SuperTalent DDR400 @ DC 200 MHz @ 6-3-3-2.5
mokrikontrolerji.... the begining
203971 (2945) snow
PIC komunikacija
132529 (2238) maticm
Izbira mikrokrmilnika
313892 (3489) BluPhenix
programiranje mikrokrmilnikov?
347666 (7075) radiator
C compiler
Oddelek: Programiranje
192825 (2495) Brane2
